Question about Sanyo PLCXU30 Multimedia Projector
Convergence error Sanyo PLCXU30 proyector
Hi friend´s . My problem is the double image on display with the blue color desplaced to left. I look on the prism an lens for mechanical integrity and all are ok. I suposed in a interface or service position for electronical adjustement o software adjust.
Please help me with these trouble, and excuseme for my very bad english.
My Name is Walter and i live in Rosario city Argentina.
Thank´s
  • neurator Oct 22, 2008
    I'm having these red vertical lines, which appear as a shadowing to the left of text, and along the borders of certain tones when watching a movie. Is this the same as the convergence error? And if so, is there any advice on the process of moving the panels so that they provide a balanced image?
    Note that this shadowing happens to the menu as well, with nothing attached, so its definitely NOT a cable problem.
    Thanks!
  • tjpterryp Nov 26, 2008
    Same problem on my NEC and getting worse. How to do this adjustment?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
This can only be solved by mechanical readjustment of the blue lcd panel .
be extremely carefull doing this!! a small move means 1 cm or m ore on the sreen
Posted on Sep 26, 2008
Double images, especially with red.
hi.
double image is caused by a faulty convergence circuitry. It needs repair, if you have a basic knowledge in electronics you can do it, just replace it with the new convergence kit.
Nov 22, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Double Image blue color
Need to have the convergence board repaired it will require 2 ICs and various resistors, expect to pay around $300 Julio milleniumtvsvc@gmail.com
Jul 22, 2009 | Panasonic PT-47WX49 47" Rear Projection...
No audio ,double image bow with redish color at bottom of screen ,on my phillips big screen tv model # 55p8342
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 18, 2009 | Televison & Video
Wavey line and double image
Your TV most likely has a problem in the convergence circuits. ( common problem )
  • Screen looks 3D
0667c5f.pngSOLUTION
May 19, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Getting "red" double image
Your TV most likely has a Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Apr 27, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Double Image Red and Green
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 08, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Replaced Convergence but pictures still display with double images
i went to converge my mitsubishi ws 73903 and the blue line wont go down to match the other ones
Oct 09, 2008 | Mitsubishi WS-73903 65" Rear Projection...
ALOT OF BLUE ON THE SCREEN!!
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Aug 20, 2008 | Philips 60PP9200D Television
COLOR OUT OF ALIGNMENT ON LEFT SIDE OF TELEVISION
are you able to adjust the convergence in all 4 directions for both red and blue? If not the Convergence ICs are bad and need replacing. If you ned more info let me know.
Apr 08, 2008 | Televison & Video
150 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
