Question about Maytag Dishwashers
Maytag dishwasher model DWU8450AAX
WATER CONTINUES TO FILL INTO DISHWASHER, OVERFLOWS ONTO FLOOR
  • Anonymous Mar 22, 2014
    Not leaking onto floor it's from overflow
  • 1,543 Answers
Replace inlet water valve.
Posted on Sep 26, 2008
Too much sink water causes flooding from dishwasher.
If you let it sit with vinegar and it worked after for a while that tells me it may be plugged up with grease. Might be worth while trying to clean it out with Drain O a drain cleaner. Make sure its washed clean after. Grease and dirt builds up after a while in all machines. If vinegar works might be worth cleaning more often.
Mar 14, 2017 | Maytag PDB4600 Built-in Dishwasher
I have a Bosch dishwasher model SHU66. Clean water slowly pools in the base when the dishwasher is not in use. We need to drain the DW every 12 hours or water will overflow onto the floor. Is this an isue...
IT SOUND LIKE IT IS A WATER VALVE ISSUE.DRAIN AND CANCELTHE MACHINE FIRST THEN TRY TO SHUT OFF THE WATER GOING INTO THE MACHINE PROBABLY UNDER THE SINK. SEE IF THE WATER IS STILL COMING IN TO UNIT. IT SHOULD NOT BE. THEN TURN ON WATER IF THE WATER STARTS TO FILL MACHINE THEN CHANGE THE WATER VALVE.
Mar 27, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Model DU8700-xb purchased 1995 When unit reaches
Please check your overflow float. It may be stuck in the down position. It looks like a little hat or cone in the bottom of the machine. It should move freely up and down. If it is stuck in the down position, your machine may over fill with water and cause your leak. Good luck
Jan 23, 2010 | Dishwashers
New Whirlpool Dishwasher filler overflows.
New Whirlpool Dishwashers will NOT accept the same "volume" of water that was desired by the same products of 25 years ago. Therefore the old 3/8" ID copper supply is too large and will overflow the tub filler/aireator (out the air vent holes). I just installed a new dishwasher supply kit consisting of a new 3/8" OD stainless braded hose with an ID of about 1/4". This delivers less volume than that recommended (in the installation manual) and therfore does restrict the flow a bit. However, the flowrate is adequate and the new dishwasher now works perfectly with no water overflow on the floor . . .
Dec 26, 2009 | Dishwashers
Dishwasher overflows from front
Hi andrew did you get this fixed as it sounds identical to my problem.
Ian
Sep 01, 2009 | Hoover 24 in. HD83M Free-standing...
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
The clean water fill will not shut off and water overflows from the dishwasher onto the floor. We had to turn off the water supply to the dishwasher to get it to stop.
Fill valve is shot , new one required
Ps
Does it still run when you remove the power if so the above applies
If it shuts off then the problem sits with the pressure switch
Jul 03, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Drain pan of refrigerator is filling up and overflowing onto the floor. This never happened before.
Maybe it is because of increased humidity inside the fridge. This could be caused by the door not being properly closed or leaking.
May 31, 2009 | Maytag MSD2656G Side by Side Refrigerator
Water leaking onto the floor
1. If the water is going onto the floor during the drain cycle there is either a hole in the hose or it is completely loose from the DW or a hole in the drain assembly under the sink but if that were the case you would have water under the sink also.
2. If it during the wash or rinse cycle then the seals are not sealing (door is not closed all the way or seals are bad) or the float at the right front of the DW is stuck allowing the DW to overfill with water.(you need to open the door and pull the float up and out as you do so push it up and down and listen for a clicking sound.(which indicates it is making contact with the fill solenoid)..if you here the clicking and the float is full of gunk (old soap and such) clean it out and replace it and run it through a cycle and monitor the DW to see if the fill cycle shuts off before the water reaches the overflow point.
3. the only other option is a possible rust through on the DW and or the drain and motor mount in the center of the DW where the food particles and water are drained...is loose and leaking or rusted through...(how old is the DW).
4. Also check to see there are no large particles around the door seal to prevent complete closure and sealing of the door seal. As well as the door latching properly (when closed can the door be moved or pulled open)?
I hope this helps and let me know if not Please relay model number, age and other specifics you feel are pertinent...thank you and please rate me if this helped...thanks again ...the Fang
Jan 24, 2009 | Maytag 24 in. MDB4000 Built-in Dishwasher
Dishwashers Logo
442 people viewed this question
Top Maytag Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
