Question about Sony CASSETTE DECK Single Dual Cassette Deck
Insuficient clearance for caset to install
Cassette doors will not close . Inslled neew belt . No improvement. Neither A or B. works.
There is a lock on the door mechanism. Unless the belts are good, the machine will not recycle to move the heads down far enough for the tape to be removed, so the door is interlocked to prevent damage.
Take the case off and push the door release and watch where the release lever hits a small nylon piece. You can pushit down with a pencil or screwdriver and the door will open. This white nylon piece will stay locked down if the blets are good and do not slip. They put the door latch in park allowing the tape to be inserted or removed.
Try to treat the belts with rejuvenator CaiKleen™ RBR Let them sit a while to get rejuvenated enough to not slip and the problem should be solved.
Posted on Nov 05, 2008
Why won't the door to my cassette deck on Victoria tunewriter III close once I have inserted a cassette?
I'm not familiar with this unit but the frequent cause of this problem is that the record/playback head is not retracted from previous use. Frequently caused by drive belt problems - loose, broken or off track. Try running the drive with the door closed and no cassette. This seldom is a problem that the owner can fix. Professional service is recommended.
Apr 04, 2015 | Audio Players & Recorders
Cassette Door open and close but tape won't go down into deck
The loader motor turns a belt to draw the tape out of the cassette. Probably needs replacing.
Jan 13, 2015 | Sony HDR-FX1000 Mini DV Camcorder
A cassette has jammed close the A door of my Sony TC WE675. How do I clear the jam? The tape is probably keeping the door closed.
Please click HERE so that you will be directed to the site where you can troubleshoot the issue.
I hope that this will work for you.
Aug 08, 2011 | Sony TC-WE675 Single Cassette Deck
Cassette will not exit, nor play and does a clicking soud
Cassette will not exit,eject nor play and does a clicking sound, one side of cassette door will not close.
Jun 15, 2010 | Sony TC WE835S Stereo Dual Cassette Deck...
Sony dcr-hc38. inserted tape. hear beeps. screen states to "reinsert the cassette". it continues and wont play or record --Solution #1- change the mechnical assembley of casete ...Can you explain how to do...
try it without inserting cassette if it closes correctly and doesnt load with cassette then 99% problem is with drum motor.look out for drum motor connector remove it clean it with pencil eraser and try again if it works, fine or just replace drum motor
Jun 11, 2010 | Sony DCR-HC38 Mini DV Digital Camcorder
Aiwa cassette deck won't eject
I had this problem on an AD-S40. Turned out to be the drive belts, which had stretched, resulting in the fact that the motors couldn't drive the mechanism through it's various load cycles of opening/closing the captain roller, etc. as required to operate the mechanism. Stuck in mid-cycle, the doors would not open.
After removing the case cover, you can turn the belt driven wheels by hand to complete the cycle, so that you can eject. Then get new belts (several outfits sell belts based on length, on line). You don't need to do much to replace the belts -- after unlocking and getting the tape out, it was only a couple of screws to remove the mechanism, as a unit, and there is no need to fuse with the circuit boards and such. Easier than I expected.
Apr 20, 2008 | Audio Players & Recorders
Denon Dual Cassette Deck DRW-660 will not eject either tape. I put a tape in right side, played a bit, stopped, will not eject. I put another tape in left side, closed, cannot eject. Cannot eject either....
Some dual decks use a common drive belt. It may have become too slack (due to age) to drive mechanism. I am sure its time to change all belts in both decks. This will solve the problem
Apr 05, 2008 | Audio Players & Recorders
Cassette door stuck closed
Firstly: do not think about forcing the cassette door! Look inside the unit. You need to hand rotate the capstan flywheel a bit,( a large-ish metal disc attached to the motor via a rubber drive belt.)That should release the powered deck mechanism and allow ejection. Then buy a new drive belt , so that problem does not recurr. Good Luck
Nov 02, 2005 | Aiwa NSX-A115 Shelf System
104 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
