Ineed to open my laptop to change broken power jack
  • 79 Answers
Hi there
the power jack is soldered to the motherboard which has to be removed to fit a new jack.
this involves a lot of time and you have to rember where all the screws came from as they are all different. one screw in the wrong hole can crack the motherboard ! it is not a job you should undertake unless you know what you are doing. my advice is get a pro to do it as its too risky unless the laptop is really old and not worth much. if you do get it repaired make sure everything is backed up first as the hard drive getting wiped is quite a common event.
good luck
beergut 707
Posted on Sep 26, 2008
Laptop is charging but cant turn on
When you say "you fixed the thingy" (ac jack), how did you fix said "thingy", did you open the laptop and replace the damaged/broken "thingy"? Need more info. Perhaps the "thingy" isn't fixed? Try remove any DVD,CD, USBs from the laptop, removing the "thingy" , remove the battery, Hold down the on/off button for 10 seconds, replace the battery, replace the "thingy" push the on/off button. That said, When you fixed the "thingy" was ALL power removed from the laptop AC plug, Battery, If not a short may have occurered.
Nov 06, 2012 | Lenovo G470 Core I5 4gb 500gb Hdd Laptop...
Hi when plug in my ac adapter into lenovo x61 the tablet will not turn on i try it on other computer and it will on what happen?
LOL, sounds like your tablet has seen it's better days. See why HP got out of the Tablet business? They are nothing but trouble.
Apr 08, 2012 | Lenovo Tablets & eReaders
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
I changed my powerboard due to a broken dc jack. now pc wont star
This could be several things...
If you weren't EXTREMELY careful to reinstall each screw in the hole it came out of, you may have put a longer screw in a hole it shouldn't have gone in. This can make a shorted circuit and keep the laptop from powering up. It can also cause damage.
open it up again, and carefully inspect where any of the screw ends may have touched ANYTHING. Also, make sure the connectors are all seated properly.
Dec 21, 2009 | Acer Aspire 5500 5570-2609 Laptop
Ineed to access the power jack? How do i get
go to hp.com you can download manuals and drivers for your specific laptop,
on a side note, It has been my experiance that the power jacks are soldered on the mainboard and then thinly coated with glue so they hold position, keep that in mind because with yours being loose the odds are that the glue around your power jack is broken, so when you pull the jack out from the plastic case be careful not to break the solder connection on the mainboard
Sep 27, 2009 | HP Compaq Presario CQ50-110US Laptop
Power jack loose on mother board advent 5303
If the jack is just broken loose then you should be able to disassemble the laptop and resolder the jack back onto the motherboard. If the jack is broken then you will need to get a replacement jack and change it out. You can get power jacks from several places on the internet including Ebay.com If you don't want to try the repair yourself we have a repair service and can do it for you. We charge $55 + return shipping. Let me know if you have any additional questions.
Buddy
Corporate Computer
www.ccl-la.com
Sep 13, 2009 | Televison & Video
I opened my Toshiba satellite laptop to fix the DC Jack. Now it wont power on. Any ideas why
when you fixed the jack did U accidently solder anything else to the connector , sounds like a short, causing a ground fault.
Jul 08, 2009 | Toshiba Satellite A105 Notebook
One of the 3 Male Jack Prongs is broken off.
This will likely require some soldering, if you are referring to the jack on the dc converter (black box) you should exercise care when opening these there coiuld be hazardous electricity in it even if unplugged. (if it can be opened, many are permanantly glued shut) you can order replacements on ebay relatively cheap, usually $15-30.
Jan 21, 2009 | Toshiba Satellite A45-S151 Notebook
Overheating and ac adapter disconnection
try to open laptop and clean the dust off the fan
Jul 18, 2008 | Sony VAIO PCG-K35 Notebook
How can I fix the loose power jack?
The last 2 screws to separate top from bottom are located ynder the 3/8" wide clip on plastic piece above your function buttons. Center screw and right hand side. Be careful of ribbons, plug-ins and wires that attach to both sides. I strongley suggest not doing this if you are not mechanically inclined. You could very easily cause damage to your laptop.
Aug 27, 2007 | Gateway 4530GZ Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
