Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore/Fridgedaire refrigerator ice actuator replacement
The actuator on our ice dispenser broke off,so, I ordered a replacement. I have the replacement but not sure how to go about removing the old one and installing the new one. I can remove the front panel but don't know where to go from there.Any help would be very much appreciated.
    New Friend:
The ice actuator is freezing up due not closing after dispensing ice.
Posted on Apr 15, 2013
  • Mike Ainsworth Apr 15, 2013
    The flap that lets ice be disensed to a glass...won't close and lets air in and causes an ice build up at that site.
  • 943 Answers
Hi thanks for the question are you talking about the arm to stop the ice making if so you can just put back in clips on the front of ice maker and at back thanks the appliance doc
Posted on Sep 26, 2008
How do I replace a plastic auger with a metal auger in a Kenmore side by side?
Fridge Dispenser Auger Drum Replacement - Whirlpool ...
? 4:56
www.youtube.com/watch?v=-fUJlQ1BQcs
Apr 12, 2013 - Uploaded by RepairClinic.com
The most common reason for replacing the dispenser auger drum is when ... Whirlpool, Kenmore, KitchenAid, Roper, Estate, Maytag, Crosley, ...
Sep 23, 2015 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refrigerator model 106.57372700
This is usually not hard to fix. Either the tab that hold the dispenser actuator is broken or the ice guide may have come loose. Repairclinic.com has a nice video on how to fix this.
Jul 23, 2014 | Kenmore Refrigerators
Replace dispenser actuator
Not sure I understand . there are several components in the ice dispensing feuture . if it is the ice bucket it just slides in. if it is the auger motor it has to be removed by unscresing and pullin g out if not those it would have to be an electrical diagnosis
Mar 23, 2014 | Kenmore Refrigerators
I have a stainless steel Frigidaire side-by-side refrigerator with an ice/water dispenser in the door. The paddle on the water dispenser broke, and I need advise on how to disassemble the dispenser in...
the front cover will come off. if you dont see any screws then it WILL unsnap. look for a slot on the top or bottom of the cover. good luck some of them can be nasty
Oct 28, 2009 | Refrigerators
Remove faceplate surrounding the indoor ice/water dispenser
under the facial plate, if you get way down and look upward, you can see two slots to insert a flat screw driver. Pry it open and there ya go...good luck
Apr 24, 2009 | Kenmore 54662 / 54664 / 54669 Side by Side...
Broken water actuator
Hi this is tech crazy
the solution to the problem is
You should be able to replace this part yourself. Follow these steps to replace the water actuator:
  1. Unplug the refrigerator to completely disconnect electrical power. Turn off the water supply to the refrigerator.
  2. Remove the drip tray (Key 23 in the image below) from the bottom of the dispenser.
  3. Remove the screws (Key 43) from the bottom of the dispenser module cover (Key 4). NOTE: You model may not have screws at the bottom of the dispenser cover. If not, push down on the top of the dispenser cover and pry out on the bottom of the cover with a flat tip screw driver to remove it.
  4. Pull to dispenser module cover up to release the top clips and remove this cover and set it aside.
  5. Remove the screws (Key 17) that are on each side of the dispenser module (Key 8).
  6. Carefully pull the dispenser module out slightly from the door. It will have wires attached. Pay attention to how the water tube and the ice door assembly are positioned. Pull this module out far enough to remove and replace your water actuator (Key 24).
Reverse the above process for reassembly.
Jan 25, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Side my Side Refridg- Ice Dispenser Freezing Up
Check the pin that holds the flapper in place.
I'll bet the plastic is broke that holds spring and flap inplace
I have same problem
Aug 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
355 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
