Question about Refrigerators
Fridge makes very loud noises when door is closed and motor is on. When the door is opened the noise stops. It sounds a bit like machine gun fire or the motor is about to give out. Do you know what the problem is?
  • dma_spike Sep 26, 2008
    Fridge is a whirlpool, upright with Freezer at the top. 362Litre, with model number wrn38rwg6.
    The noise has been progressively getting louder over the last couple of weeks.
    Genius:
  • 1,268 Answers
When was the last time you defrosted your fridge? Try to defrost it first and please unplug the power while defrosting for couple of hours. If it didn't fix it, more likely its the problem with the motor and the fan. Have it serviced by a ref tech if you can't DIY it.
Posted on Sep 26, 2008
    Genius:
  • 1,550 Answers
It sounds to be the motor .
How old is your Fridge ?
By the way what brand is your fridge ?
model no?
  • 2,071 Answers
A loud sound noise is cause by a defected motor maybe the bearing in the motor shafting is worn out already.
Hope it may help you;
Regards,
VOTIT
  • 943 Answers
Hi thanks for the question yes i do know . its the freezer fan hitting ice build up in freezer remove panel and clean try again if it re occurs you have a defrost problem thanks the appliance doc
    Brigadier General:
  • 6,966 Answers
Initially, would suspect the evaporator fan blades hitting something or a misaligned vent. Pls post back the make & model.
Other areas to check would be:
  • loose covers, flaps or anything outy of the ordinary;
  • compressor support;
  • condenser fan (at the rear) if present;
  • anything else that could be checked visually.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Sep 26, 2008
    Hi again,
    Thank you for the additional information.
    Based on your description of the noise/sound, it could only be a repetitive hard object hitting another hard object. To my knowledge, there would only be two (2) parts in a refrigerator that could make such a continuous sound:
    • fan blades; and/or
    • compressor motor.
    If you are somewhere in Australia or New Zealand, then this model would have to been marketed sometime since 2000 and is is manufactured by Samsung on behalf of Whirlpool to supplement the range of refrigerators manufactured by Whirlpool for your region. You may want to check the rubber compressor mounts. Move the unit to give you access at the back to enable you to locate the source of the noise. It is possible to be internal to the compressor motor.
    If it is the fan blades, then a manual defrost would be required. This would melt the accumulated ice and give you access to visually inspect the fan. The fan's purpose is to draw cold air from the freezer and vent it to the refrigerator section. In some versions/models, the fan has a vent or vane cover that could become loose and obstruct the flow of air or worst hit the fan blades when they rotate.
    If it is the compressor motor, it would be more louder from the rear.
    Incidentally, some versions/models have also a fan at the condenser coils (at the rear).
    Cheers.
Lg refrigerator making loud noise
You can try adjusting the front feet so the fridge is on a bit of an angle.
Nov 02, 2016 | LG Refrigerators
When it is lcooling it has now begun tomake loud vibrations.
it is most likely from the frame of the fridge that the compressor is mounted on vibrating on the floor
I use two door wedges ( available from the hardware shop and I push one under either side a bit to get clearance from the floor
the noise stopped but the problem is that there is nothing available on the market to replace the wedges
rubber buttons under the plate worked but to stop the noise they tend to make the fridge unstable when opening the door or the front of the fridge has to be adjusted up so that the door self closes
try that and if it works the you are on the right rack
if not you may have to get the compressor rubber mounts replaced as they may have collapsed and allow the compressor to hit on the plate
Oct 14, 2015 | Maytag MSD2454G Side by Side Refrigerator
My whirlpool sixth sense fridge freezer is reading F01% (fridge side) the motor seems to be overworking(making noise) but doesn't;t do so when fridge door is open. The freezer seems to be fine and...
the motor is suppose to stop when the door opens and turns on when closing the noise could be ice building up and the fun blade rubbing the ice if unit is empty you should leave the unit disconnected so ice melts and noise will go away when reconnecting if no motor replacement is needed.
Dec 26, 2014 | Whirlpool Refrigerators
Loud humming noise coming from fridge
sounds like the evap fan is hitting something.. or is loose and making noise... I would remove the cover in front of the fan and take motor out and reinstall it making sure all washers and grommets are in place...but I would look for ice build up first, this could indicate a defrost problem..... hope this helped ken
Sep 29, 2014 | Bosch Refrigerators
Fridge sectipon of fridge freezer started making a
Replace the fan motor or at lest take the cober off and cneck to see if there is ice build up or somthing has got to where it hitting the blades.
Jun 06, 2010 | Refrigerators
New refridgerator delivered this morning to replace the same model that was a lemon. The fridge is making a sound on the fridge side. When I open the door to the freezer side the sound stops. When I...
sounds as if there is an issue with the evaporater fan motor, perhaps the fan blade has come dislodged and is makinf noises, normal for the fan to stop when the frig door opened as welll,
Dec 17, 2008 | Refrigerators
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Feb 12, 2008 | Refrigerators
Ice Maker Making Noise
The motor for the auger drive runs pretty slow (about 18 rpm), it could be the drive is running continuously (unless the door is open). Check that and let me know some more info, is the noise real loud, soft, etc. Can you feel anything vibrating or running when the door switch is pressed in?
Nov 05, 2006 | Amana ASD 2624 Side by Side Refrigerator
Refrigerators Logo
157 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
