SOURCE: I am looking for the serial number for the Canon
The serial number is located on the top surface of the battery compartment cover.
Refer to:
http://gdlp01.c-wss.com/gds/7/0300001917/01/fs20-21-22-200-nim-en.pdf
Go to Page 14.
Thanks for using Fixya.
Please take a moment to rate this solution. Thanks!
SOURCE: serial numbre installing ImageMixer for Canon HF-10
After using the serial number under the batteri the problem was solved for me.
SOURCE: Install. ImageMix. (Canon HF-10), not accepting the serial number
I found another serial number under the batteri, and then it worked out fine.
SOURCE: where is the serial no.
To find the serial number remove the battery and look for the serial number next to a qr code.
The lens cover mechanism in these cameras is susceptible to debris and requires disassembling the camera to repair. This can be repaired fairly inexpensively. However, it's not a user serviceable problem due to the fact that the camera will need to be partially disassembled and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com
