Wont let me install printer when trying to add printer this is what it says (operation could not be completed. the print spooler is not running. could u please tell me how to solve this problem so i can use the printer again.
  • 4,338 Answers
Go to the services and check to see that the print spooler is started.
If you don't know how to find Windows Services in Windows XP, click on Start, Control Panel, Administrative Tools, and Services. Scroll down to print spooler. click on start or set it to automatic.
Posted on Sep 26, 2008
On command to print with my epson lx-300+, message reads, "No Printer". When searched on fax and printer and double-clicked "Add Printer", a message came out saying, "It can't...
Hi Basti here,
Try this...
If you are receiving SPOOL.SVC or PRINT SPOOLER ERRORS when trying to uninstall/reinstall your printer, or when trying to print a document or access the printer properties, please follow the steps below.
The following are examples of some of the messages you may be receiving:
Spool.svc is not running. Make the service active and try again.
Printer Properties cannot be displayed. The print spooler service is not running.
Printer cannot be removed. The print spooler service is not running.
Windows cannot print due to a problem with the current printer setup.
(When clicking Add Printer) Operation could not be completed.
NOTE: Only these types of errors warrant the troubleshooting steps clearly defined below.
Resolution:
SPOOL.SVC is an operating system function which carries files through the operating system for printing. It must be STARTED (active) to be able to print or access any printer's functions. This file usually starts automatically with Windows, however operating system issues may cause it to become stopped. You cannot uninstall or reinstall a driver while this service is stopped.
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE.
2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES.
3) Locate and highlight the PRINT SPOOLER on the list of Services.
4) Click START THE SERVICE.
If errors occur and the service cannot be started, there is another issue within the operating system itself.
May 23, 2011 | Epson LX-300 Matrix Printer
Printer spooler
Resolution:
Mar 13, 2011 | Canon Office Equipment & Supplies
Operation could not br completed. The print spooler service is not running
Hi There,
If your print spooler service is not running, then follow the below steps to get it working :
Step 1 :
* Start > run > services.msc > ok
* Select the service name called print spooler from the list.
* Check the status on the print spooler service, if it is stopped, then right click and select start or restart.
* Then the spooler service will start working....
Step 2 : ( NOTE :USE THIS STEP ONLY WHEN YOUR STEP 1 DOESN'T WORK )
In this case, we assume that the print spooler service is gone bad and we would have to recreate the spooler service.
* Start > run > cmd > ok
* Type: sc delete spoolsv (this will delete the corrupted spooler for us to create a new print spooler)
* Reboot the system and after rebooting the computer back.
* Type: sc create spoolsv (this will create a new print spooler service)
* Reboot the system and this time the print spooler service is a new and fresh spooler and it should work normal and perfectly.
Enjoy printing !!
Oct 22, 2010 | Office Equipment & Supplies
The printing spooler service is not running.
Go to the control panel. Select printers and right click on your printer. Select properties and turn print spooling on.
Aug 08, 2009 | HP Hewlett Packard LaserJet 1022 Printer
HP Laserjet 1020 Spooler not starting
First uninstal old drivers then install again.
Then go to start menu then type in run "services.msc" then press enter
then you can seee right pane check there you find Print Spooler just double click on it then set
stratup type as automatic then click on depndancy tab then set restart the service .
then apply and ok.
Jul 15, 2009 | HP LaserJet 1020 Printer
Not find print spooler in my service
Try going to start-->run and type cmd to get to command prompt
From there type:
net stop spooler
net start spooler
Close the window and see if it will install then
Jul 11, 2009 | Microsoft Windows XP Professional
Spooler servis dont work
Resolution:
Aug 25, 2008 | HP Office Equipment & Supplies
SPOOLER SERVICE IS NOT RUNNING
Resolution:
Pls Rate as Fixya if this helps, Thanks!!
Jun 26, 2008 | Dell A940 All-In-One InkJet Printer
Print spoole
has this been resolved?
Jan 10, 2008 | Dell A920 InkJet Printer
Printers vanished and can't add printer
Your shell extensions have a software conflict. The offending piece of software will have to be determined and removed, or at least stopped, before re-booting the computer. You may be able to repair the problem using the System Restore option.
Oct 10, 2007 | Adobe Acrobat Distiller Server V6 for Win...
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
