Question about GE JE1590 Convection / Microwave Oven
JE1590 Hi, Just wanted to where can i get this special screw driver so i can open my oven to change the bulb. Thanks for your help.
  • GE Master
  • 9,086 Answers
A special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Some folks just use a hammer to tap and loosen the screw, then a small flathead screwdriver can be used to remove the screw, as shown in the photo.
Another creative solution is to use a hacksaw or a Dremel tool to carefully cut a slot in the head so a flatblade will fit it.
Posted on Sep 29, 2008
My JE1590 BH 02 is only 5 years old and we are having door issues. The door will not open, unless while pushing the door button you also hit the door. It seems the latch is not functioning correctly. ...
Door catches.
One of the latches may be bent/misaligned and is not lifting the other latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Feb 22, 2011 | GE JE1590 Convection / Microwave Oven
How do i change lightbulb?
You will need to remove the outer cover to access it.
The bulb is located in the air cooling duct on the right side of the oven.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 18, 2010 | GE JE1590 Convection / Microwave Oven
How to replace the bulb in our GE Microwave Oven,
the outter cover wrapes around unit remove screws, be careful high voltage is present even with power off just replace bulb reassemble
Jan 13, 2010 | GE JE1590 Convection / Microwave Oven
Ge microwave oven jes1288 light bulb replacement
The light bulb assembly (bulb and socket are all one piece) is part number
WB36X951.
It is located on the air duct assembly where the door switches are mounted.
You can see an exploded view diagram here.
You'll need to remove the outer cover (wrapper) to get to the bulb assembly.
Always unplug a microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
If you're not able to find the bulb assembly at your local appliance parts store, you can order one here.
Jan 21, 2009 | GE JVM1631 Microwave Oven
Changing light bulb in microwave oven
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Oct 11, 2008 | Magic Chef MCD1311ST Microwave Oven
JE1590 light bulb replacement
On this model you need to remove the outer cover.
The bulb mount will be located on the right side next to the side wall of the cooking cavity.
It's above the damper door assembly as shown in the attached drawing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
The bulb should be available at local grocery stores, hardware stores, and places like Wal-Mart and Lowe's.
Sep 22, 2008 | GE JE1590 Convection / Microwave Oven
Light bulb change
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
If you need more help, please reply back with your brand and model number so we can help you.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | Panasonic NN-S676WA Microwave Oven
Countertop kenmore microwave, large, brown, old...whar is model number...I need to manual
Sorry, but you can't get a manual without the model number. You can find help locating your model number here.
If the manual doesn't address how to change the bulb, or you don't see an obvious bulb cover, then you'll have to remove the outer cover.
Be sure to unplug the oven first.
Jul 03, 2008 | Microwave Ovens
Miccrowave dmt2420s
The outer cover (wrapper) will need to be removed.
The bulb is located in the top side of a plastic or metal duct located on the right side of the cooking cavity.
The bulb is common and can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Jun 21, 2008 | Dacor DMT2420SS Microwave Oven
GE Profile JE1590--light bulb
The type of screw attaching the casing is called a Torx Tamper Proof screw. You need a Torx Tamper Proof Screwdriver to remove the screws. These screws and screwdrivers come in various sizes. I think the size you need is T20H.
Nov 19, 2007 | GE JE1590 Convection / Microwave Oven
GE JE1590 Convection / Microwave Oven Logo
228 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
