Question about Rockford Fosgate T20001 bd Car Audio Amplifier
Is my alternator too small
My amp keep tripping out a high volume level 25.I own a 1990 Nissan 240SX with a T20001 amp pushing two T-2 subs and my alternator is only 80 amp. I have a 5 farad capacitor and a 100 farad dry cell battery
  • 631 Answers
If you're running the amp into a safe ohm load, it's likely that the amp is cutting out due to low voltage. You need to check the voltage with a multimeter connected directly across the terminals of the amp. If the voltage is dropping below ~10v, check the voltage across the main battery terminals. If the voltage is essentially the same at the amp and at the battery and it's dropping below ~10v, you need a larger alternator.
Posted on Sep 26, 2008
ProSub 600 tripping off during playback of low bass and turns on after a while but works perfectly if volume is turned down. what could be the problem?
  • The DSW ProSub is a nice amplified sub. The reason it is shutting down is the amp is being worked to hard and it's going into thermal mode and after you turn down the volume and it cools down it's coming back on. To much of this and you will have a nice sub and no amp to run it.
  1. One thing to do is keep the sub/amp in a well ventilated are and put a fan on it if you can to help move the heat away from the unit.
  2. The amp is rated at 250 watts so if you push it to hard it's gonna keep shutting down. So turn it down a little so it runs longer and smoother or add another sub to the set up if you need it louder (like we all like). One sub can only do so much.
  3. Also make sure if the receiver your using has a base setting or an EQ that you keep them levels set a little lower. Most receivers and home theaters already have an amp in them and you don't want to run to much of that into another amp. It's over kill. Find that happy medium.
  • If you have any questions or comments please feel free to ask.
  • Thank you for using FixYa.
Regards, Tony
Jul 20, 2011 | Definitive ProSub 800 Subwoofer Speaker
Rockford t20001 bd amplifier no sound.
Disconnect your subs. Chk the impedance with an ohm meter. They should read apx 4 ohms or 8 depending on woofer. If they chk ok chk the remote turn on for voltage when system is on.
Jul 29, 2017 | Rockford Fosgate T20001 bd Car Audio...
I want to know how to tune my car audio system without making my woofer clip
Start by turning the amp volume down, clipping is not from tuning its from too small and amp then turning the volume too high or a very distorted signal, this then causes the amp to produce high levels of distortion which cases damage to amps/speakers. Make sure the sub frequency is around 60-80hz and the volume is no more then 3/4 of the way up. You may also have a bad signal from your radio or bad RCA cables but I would start with the amp gain first...
Nov 02, 2009 | Jl Audio 1000/1 Car Audio Amplifier
High rpm shifting
Try changing your transmission filter.then replace with new trans,fluid.
Jul 26, 2009 | 1993 Buick Century
System Cuts Off
your amp is tripping out because the subs a drawing to much power get a better amp alpine subs demand a lot of power try a high current amp
Jun 30, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Cuts out at higher volume
Your amp might now have enough power to push the subs or you need to get a better amp kit that will deliver the power the amp needs to operate at a high spl lvl
Mar 04, 2009 | Car Audio & Video
How to adjust the controls and gain on my kenwood 9104d 1800w amp
Hook the speakers in series to decrease your chances of blowing the amp and/or speakers themselves. And at high volumes make sure that the bass control is set for flat response.
Jun 25, 2017 | Car Audio & Video
High distortion
The head unit may be rated at 200 watts but it cannot produce more than ~20 watts of real power per channel. There's no way that it can drive the high end speakers to a level that will be needed to compete with the subs on a 1000 watt amplifier.
Apr 18, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
My Orion 2500D amplifier turns off then back on at high volume
you need a # 4 gauge wire. check the subs conection no less than 1 ohm. check ground. and if the cap is good. 13.8 volts are for max ouput ......this is 1 ohm of charge at 13.8 volts they give 2500 watts butt only at 13.8 volts whit this relation. i¨n think you need other alternator. good look.
Feb 05, 2007 | Orion 2500D Car Audio Amplifier
a possible explanation could be heating. the amp reaches its boiling point and cuts off. in this case, a fan may keep it from overheating. another option is a voultage problem, you may have to readjust the bias current. try measuring it if you know how). the amount of bias current depends on your output stage. something like: 20-50 mA for normal bipolar push pull probabely twice as much for darlington push pull and up to 250mA for MOS FET push pull.
Mar 12, 2006 | American Pro VS1405 Car Audio Amplifier
Rockford Fosgate T20001 bd Car Audio Amplifier Logo
136 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Level 1 Expert
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
