Question about Thermador C301U Electric Single Oven
Oven Stays Cold - Intermittent Problem
When this intermittent problem appears, our oven will not heat, broil nor clean. However, there is no error code, the display pretends the function is engaged properly, the cooling fan turns on, the door locks (in the case of the self clean mode).
This problem will sometimes disappear by fiddling between modes, or turning off the circuit breaker for over an hour, but there is never a sure way to make it go away. Today, I have tried everything and its not gowing away. I am turning to you for a *permanent* solution.
What is going on? What should be repaired or replaced to fix the problem?
  • Anonymous Jan 12, 2009
    I have a similar problem (however, mine is not intermittent, but I may try to turn off the circuit breaker for more than a quick flip of the switch and see what happens). Mine stopped working after I used the self-cleaning function.
  • 943 Answers
Hi thanks for the question look at the cord that plugs into the wall you could have a bad connection in that outlet remove the plug from the wall and look at the prongs if its a bad connection they will be discolored check that the appliance doc
Posted on Sep 25, 2008
The bottom oven is not functioning properly. When turned to fan oven the fan works intermittently and the element intermittently glows red hot
1.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
May 04, 2015 | De Dietrich Ovens
My samsung flat top electric oven or broiler want work and it's reading error code E-08
E08 is a oven heating error which basically means there is either a problem with the heater or the oven sensor. In this case i would check the oven sensor with an ohms meter. should read around 1080 ohms at room temp. Also try unplugging the unit for 30 seconds.
Apr 14, 2015 | Samsung Ovens
Oven
THINGS TO CHECK:
the broil element
The bake element
Apr 07, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
UPPER OVEN WORKS, LOWER OVEN DOES NOT, NOT ERROR CODE
THINGS TO CHECK:
the broil element
The bake element
I offer free advice bcuz God is so good!
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start
Jan 14, 2013 | Thermador C302U Electric Double Oven
Oven shows an F2 flashing after self cleaning along with a beeping sound.
Hello there and thank you for choosing fixya
The F-2 error code Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem. · Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
· Look for electrical noise interference in the oven temperature sensor circuit (Ham radio, cordless phone, etc.).
Jun 29, 2011 | GE JKP15 Electric Single Oven
While baking oven starts broiling with no input from controller. f2 is displayed on screen
Hello there:
F2
Note: Also see fan thermal switches Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
Sep 27, 2010 | GE JKP15 Electric Single Oven
Oven won't heat past 290 after that we get an error message
Your oven is in celcius mode to change press bake and broil at the same time SF will appear then press broil and cooking time at the same time a C will appear press again to toggle to farenheight then press start to lock it in that mode. Some models when you press the bake and broil the sf will appear if it does press the press the broil button to toggle between C & F then press start.
www.appliancehelponline.com
May 21, 2010 | GE Profile JTP18 Electric Single Oven
The oven wont heat up.
Hi.
Since the oven has two heating elements, if the oven does not heat up on any condition, and both broiling and baking element are not working, then the most common fault causing the problem is a faulty temperature probe.
The temperature probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electronic oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reaching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Mar 03, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Neither the oven or broil element comes on. No error code appears, any thoughts?
Hi.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electroning oven control to baking and broiling element.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
Regards.
Mar 02, 2010 | KitchenAid Ovens
Thermador S30 Will Not Heat
You need to give us the model number. Check that the air flow switch in the electronics compartment is actually picking up.Other wise you may be having a problem with the relay board. Post the number so we may be able to offer more help
Regards
Dont forget to rate
Sep 25, 2008 | Ovens
Thermador C301U Electric Single Oven Logo
172 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
