Question about Kitchen Ranges
My kyocera knife 7d17-i has afew severe chips in the blade,con it be repaired? mikeg484@hotmail.com
  • mikeg484 Sep 25, 2008
    where can i send ny knife to get it repaired?
    very helpful i'v been on the net for 2 houres trying to find info on kyocera warrenty and repair.thankyou,you helped me greatly
  • 4,472 Answers
Http://global.kyocera.com/prdct/fc_consumer/kitchen/resharp.html
Go to this page and contact them about your issue. Please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
Posted on Sep 25, 2008
  • Lee A.
    Lee A. Sep 25, 2008
    if your in the US
    3565 Cadillac Avenue
    Costa Mesa, CA 92626-1401
    USA
    Knife Resharpening /Warranty Department
    Tel: 001-888-700-7371
    Fax: 001-714-428-3608
    That will get you taken care of. If you have a moment please rate my solution FixYa! as I strive to provide fast and accurate responses.
    thanks again,
    Lee
  • Lee A.
    Lee A. Sep 26, 2008
    You are very welcome glad I could help. Thank you for the very quick response and rating it is greatly appreciated. If you ever need help in the future you can use the ask me feature my page is www.fixya.com/users/leethedeuce
    Thank you,
    Lee
  • Kitchen Ranges Master
  • 6,487 Answers
Yes, that can still be repair and the cost of that is not that much that buying a new unit , so better take this to o repair center near you and let them do the fixing...
Hope that helps..........
BLADES DON'T MEET ON OVERLOCKER
hi there
please see link to download user manual for JUKI MO-644D
http://www.juki.pl/support/HSM/Manuals/MO-654DE_manual_UK.pdf
and you must made upper and lower knife very close to cut material correctly.
regards
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Nov 22, 2013 | Juki MO-644D Mechanical Sewing Machine
What's heavier a German or a Japanese knife?
A German knife is generally heavier. It has a thicker and more robust blade with a more obtuse angle at the cutting edge. A Japanese knife is generally lighter and has a thinner blade, so it should not be used for heavy cutting tasks like chopping through bones as this will most likely chip the blade. Most Japanese knives are best used for slicing and dicing.
Jul 25, 2012 | Camping, Backpacking & Hiking
Chipper Maintenance
Maintenance (excluding the power plant) Your primary maintenance concern with chippers and shredders is their knives. You can re-sharpen chipper knives, whereas you can reverse shredder flail-type knives when dull but you can not re-sharpen them. You must sharpen chipper knives with special sharpening equipment because they are made of high-carbon steel. Maintaining sharp knives can lengthen their life and the life of the machine by keeping power requirements low. An over-dulled or chipped chipper knife will need extensive sharpening, which will remove a large portion of the blade. This obviously will shorten its life. As soon as a blade is slightly dull, you should sharpen it to minimize the amount of blade-material that you remove. All knives need sharpening at the same time to keep them in balance-even if only one is worn or chipped. Also, you must use matched sets to keep the knife the same distance from the anvil for proper chipping and feeding. After removing the knives, clean the area where they are fastened with a wire brush to make sure they will align correctly. Be sure to torque the knife bolts to their proper specifications. You will need to examine the anvil and be sure it maintains a good, square edge. Occasionally, you may need to remove and sharpen it.
Aug 27, 2008 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Savin 2513 sc322
Hi- The S/C 322 (Laser synchronization error)is caused by the following: 1-Poor connection betweeb the LD unit and the BICU 2-Damaged cable between the LD unit and the BICU 3-LD unit out of position 4- LD unit defective 5- BICU defective I really hope that it isn't either of the last two. Most likely cause is the LD unit being out of position. You had to remove it to change the poly motor. Check connectors and position of LD unit. Let me know if this helps. Aloha, Bill Monroe
Oct 06, 2007 | Office Equipment & Supplies
Sharp ar-162
CHANGE TONER CARTRIDGE CHIP
Aug 30, 2007 | Sharp AR 163 Copier
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
