I have had the similar problem with a similar model DLP but same make. I had my PS3 hooked up via HDMI and noticed that there was some type of resolution error. I had to use a another tv to lower the resolution. This fixed the problem. I hooked it back up and then increased the resolution to the desired settings. I did however replace both the bulb and the color wheel before the incident happened. Though I can't be sure if it was the tv or the PS3 issue.Hope this helps as a possible solution for you
