Question about Mitsubishi WT-46809 46" Rear Projection Television
Mitsubishi wt-46809 rear projection
I had a code 2-3 deflection failure. I took the board out and found one blown fuse f5a00 along with the convergence ic came unsoldered. So i purchased 2 new convergence ics and soldered them in along with replacing the fuse, and still get code 2-3 horizontal deflection failure. Do you know what else could be causing this? Any help would really be appreciated. Thanks
  • chris leck Oct 08, 2008
    I am havin g the same problem after replacing the ics and pico fuses.
    Scholar:
  • 173 Answers
See if the ics warm up ...out your hand on them if so they getting power.. if cold you lost a resistor or 2.
Posted on Oct 08, 2008
On my mitsubishi wt-46809 the error code is 2 blinks pause 2 blinks. What is this?
it is short protection and means one of the fuses for the convergence circuit is blown.
I can help with this if you want.
SD TECH
Jan 14, 2011 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 Powers Off; Code 2-2
The 2 fuses you mentioned are associated with the convergence IC. If they are open then the convergence IC is either bad or you have a "cold" solder joint on the IC.
Feb 01, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi wt 46809
I just did this repair last week and here's what I did... I took a flat bladed screwdriver and CAREFULLY twisted it underneath each end of the connectors EQUALLY to be sure they raised out without damage.
Nov 25, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Error code 2-3
Good Day;
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection).
Good Luck, big IRISH.
Oct 09, 2008 | Mitsubishi WT-46809 46" Rear Projection...
MITSUBISHI WT46809 WON'T TURN ON
might say like f203 ... just look at all fuses on cov. board and see if wire inside fuses is blown apart .
Sep 09, 2008 | Mitsubishi WT-46809 46" Rear Projection...
WT-46809 will not stay on
Good Day, dimen;
This looks great. Check this out;
SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Aug 29, 2008 | Mitsubishi WT-46809 46" Rear Projection...
WT 46809
22 is a error code for a short protect which is triggering shutdown . Try unplugging the crt circuit boards and seeing if the fuses still blow when you press power.
Jun 22, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 Vertical Deflection Failure
the vertical output IC may need re-soldering or it may be defective and need to be replaced. my guess would be bad solder on the vertical IC.
Apr 23, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Error code 2-2
error code 22 means short to ground. for a start check your power supply to see if anything is shorted to the ground.
Oct 14, 2007 | Mitsubishi WT-46809 46" Rear Projection...
MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
104 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
