Question about Pioneer DEH-P2000 CD Player
DEH-2050MPG i have followed the instructions, but CANNOT set the clock Book says press FUNC and then select clock - this does not work HELP -
  • Adele21 Jan 24, 2009
    Hi - I have the same problem as the person above. I've followed the instructions, but I can't find the clock function that is supposedly there, and so I can't change the clock...
Yesterday I installed the Pioneer DEH-2050MPG in an old Beetle I just bought, and had the same problem. The instructions were completely useless; Ignore them.
Here's how to set the time...
1. Hold the source button down until clock starts flashing.
2. Use arrow buttons to set time.
3. Press source again to save.
That's what worked for me.
Posted on Dec 11, 2008
  • 706 Answers
Try this method:
To set the clock, please follow these steps:
1 Press SOURCE and hold until the unit turns off.
2 Press SOURCE and hold again until the clock appears in the display.
3 Press FUNCTION to select one of the initial settings.
Press FUNCTION repeatedly to switch between the following settings:
Clock AUX1 (auxiliary input 1) AUX2 (auxiliary input 2) R-SP (rear output and subwoofer controller)
Use the following instructions to operate each particular setting.
# To cancel initial settings, press BAND.
# You can also cancel initial settings by holding down SOURCE until the unit turns off.
Posted on Sep 26, 2008
I can't find my instructions book for my canon powershot a560 and i'm not sure what mode i should have it in, on the top button, to be able to use the timer
Press the FUNC/SET button. Use up/down to select Drive Mode (the rectangle, third item from the top). Use left/right to select the desired delay and press FUNC/SET. Start the self-timer by pressing the shutter release button.
The self-timer should work in just about any mode.
Jun 18, 2011 | Cameras
I HAVE A CANON POWER SHOT A610 AND I DONT KNOW HOW TO DATE STAMP MY PICTURES. PLEASE HELP
The date stamp will only work when the camera's resolution is set to postcard mode. Press Func/set, scroll down to the bottom, then across to the icon with the clock and mountain. It will say "postcard". Press Func/set again. Then press Menu, scroll down to "Date stamp" and across to select date or date and time, then press menu again.
Feb 05, 2011 | Cameras
How to set date stamp on a a590?
Jan 18, 2011 | Canon PowerShot A590 IS Digital Camera
I have a cannon Ixus 75 digital camera, which I have had for several years, and cannot get the date to print on the photo's. I have set the date and time as instructed in the namual, but when I go to...
Dec 27, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
How do I get the date/time stamp to show up on the picture file on my cyber shot DSC W80. Help!! Thanks Darren
Dec 14, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
How to turn on date stamp
The date stamp will only work when the camera's resolution is set to postcard mode. Press Func/set, scroll down to the bottom, then across to the icon with the clock and mountain. It will say "postcard. Press Func/set again. Then press Menu, scroll down to "Date stamp" and across to select date or date and time, then press menu again
Dec 11, 2010 | Canon IXUS 860 IS Digital Camera
I can't figure out how to set the 10 second timer for my Canon A410..HELP!!!!
With the camera in the shooting mode:
1. Press the Func/Set button
2. Use the up or down arrows to select the Drive mode (normally a single square)
3. Use the left or right arrows to select the clock/10 icon (10 sec delay)
4. Press the Func/Set button again
To cancel, follow the same instructions but select the single shot mode (single square) at step 3
Aug 28, 2009 | Canon PowerShot A410 Digital Camera
Put the clock
1.
Press and hold SEL (select) for more
than 2 seconds.
“CLOCK H,” “CLOCK M,” “SCM LINK,” or
“LEVEL” appears on the display.
2.
Set the hour.
1 Using the << / >> button, select “CLOCK H” (hour) or "CLOCK M"
Use the + / - button to adjust the hour/minute
3.
Press SEL to finish.
4.
To check the current clock time or change the
display mode
Press DISP (display)
repeatedly
During tuner operation it will show the frequency or time.
During CD playback it will show elapsed time or time.
Follow this link to download the manual for your unit in .PDF form
Mar 30, 2009 | JVC AM FM CD DET FACE CAR STEREO
Timed shots/canon s45
1. Press the WB / Func button.
2. Scroll down to the Drive Mode icon (usually a single rectangle)
3. Scroll over to select the Clock/2 or Clock/10 icon (2 second or 10 second delay)
4. Press Set (on the multicontroller button)
Now, when you press the shutter button, the camera will delay 2 or 10 seconds before taking a picture.
To return to normal, follow the steps above, but select the rectangle icon (single shot) in step 3.
You can download a manual (Camera User Guide) for your camera here.
Sep 19, 2008 | Canon PowerShot S45 Digital Camera
How to set a deh-p4000ub car radios clock
try this:
Adjusting initial settings
Using the initial settings, you can customize
various system settings to achieve optimal performance
from this unit.
turns off.
2 Press SOURCE and hold until function
name appears in the display.
settings.
Clock—AUX (auxiliary input)
particular setting.
Setting the clock
Use these instructions to set the clock.
1 Press FUNCTION to select clock.
2 Press c or d to select the segment of
the clock display you wish to set.
Pressing c or d will select one segment of the
clock display:
Hour—Minute
3 Press a or b to set the clock.
Turning the clock display on or off
You can turn the clock display on or off.
! Even when the sources are off, the clock
display appears on the display.
% Press CLOCK to turn the clock display
on or off.
Each press of CLOCK turns the clock display
on or off.
Aug 05, 2008 | Pioneer Audio Players & Recorders
Pioneer DEH-P2000 CD Player Logo
1,252 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
