Question about Goldstar MV-1526 Microwave Oven
Golstar MV-1501V Microwave
The door has turned brown in the inside caused by it appears the steam from cooking even though the fans are always on. Is there a way to clean or remove the staining in the door. Where can I purchase a new door finding it hard to find that part if it cannot be cleaned?
Thank you,
LJ
  • Goldstar Master
  • 9,086 Answers
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Posted on Sep 27, 2008
Dacor DMT2420 Secondary interlock switch fails every several months. Using a clamp meter I measured 13amps and was wondering if that seems high for that switch even though it's rated at 16 amps? The Turn...
The 13 amp current draw while cooking is normal.
What kills the door switch is when people open the door while it's cooking.
Make sure everyone always hits the "Stop" pad first.
See this text file on door switches.
Nov 22, 2010 | Microwave Ovens
Everything seems to be working but will not cook
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
WARNING :
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Apr 13, 2010 | Goldstar MV-1515 Microwave Oven
Over the range Goldstar microwave not working????
(If you need more help than this, please reply back with your model number)
It's probably a bad door switch or door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Oct 02, 2008 | Goldstar MV-1501 Microwave Oven
Microwave running although not turned on
Thought I had answered this, but this is usually caused by either a bad door switch, a loose door switch mount, or possibly a problem on the control panel.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not cooking
I would say you have a bad door switch or door switch mount, or your door is loose or out of alignment.
But since it's new, and under warranty, I would contact Goldstar (LG) customer service to have them repair it free.
Contact LG at 1-800-243-0000 or http://us.lgservice.com
Feb 28, 2008 | Microwave Ovens
I have a LG Microwave oven, model #MV-154SJ. When pressing Time Cook, the Microwave no longer heats. The light comes on like it would start heating but the usual humming sound is no longer there and the...
This is usually caused by either a bad door switch, a loose door switch mount, or a sometimes problem on the control panel.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you need further assistance, please feel free to contact me directly through the links at our site: http://tinyurl.com/yzjozk
Feb 27, 2008 | Microwave Ovens
Microwave on its way out?
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
If you think the problem is on the control panel, which we repair these nationwide for $39.95 postpaid.
Feb 24, 2008 | Panasonic NN-S961 Microwave Oven
Microwave exhuast fan
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
The problem may also be on the control panel, which we regularly repair nationwide for $39.95 postpaid.
Please reply back or contact us directly if you need further assistance.
Jan 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Stops cooking
You can usually find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
Jan 04, 2008 | Sharp R-1500 Microwave Oven
Sharp r-1514 microwave
check control circuit and related circuit.
Oct 25, 2007 | Sharp R-1500 Microwave Oven
Goldstar MV-1526 Microwave Oven Logo
63 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
