Question about Kenmore 62602 Electric Dryer
Ken more 90 plus serious
Cant get belt on
  • 943 Answers
Hi i assume you cant get on the pulleys . double the belt ant slide your doubled belt under the idle and to the motor you will feel the tension when you put the belt on the motor pulley
Posted on Sep 25, 2008
2002 isuzu rodeo cylinder head torque lbs. for 2.2
Print
Removal & Installation
2.2L Engine
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Drain the cooling system.
  3. Relieve the fuel system pressure.
  4. Remove or disconnect the following: Negative battery cableIntake Air Temperature (IAT) sensor connectorPositive Crankcase Ventilation (PCV) valve and hoseAir intake assemblyUpper radiator hoseAccessory drive beltExhaust front pipeAlternator and bracketsCrankshaft Position (CKP) sensor connectorKnock sensor connectorHeater hosesWater bypass hoseFuel linesEvaporative Emissions (EVAP) valve connectorCanister hoseIntake manifoldEngine wiring harness connectors at left rear of the engine compartmentPower steering pump pressure switch connectorFront coverSpark plugs and wiresCamshaft Position (CMP) sensorValve coverTiming belt. Refer to the Timing Belt unit repair section.Timing belt idler pulleysTiming belt rear coverOil pressure switch connectorCamshaftsCylinder head. Remove the bolts in reverse of the tightening sequence.
    Negative battery cable Intake Air Temperature (IAT) sensor connector Positive Crankcase Ventilation (PCV) valve and hose Air intake assembly Upper radiator hose Accessory drive belt Exhaust front pipe Alternator and brackets Crankshaft Position (CKP) sensor connector Knock sensor connector Heater hoses Water bypass hose Fuel lines Evaporative Emissions (EVAP) valve connector Canister hose Intake manifold Engine wiring harness connectors at left rear of the engine compartment Power steering pump pressure switch connector Front cover Spark plugs and wires Camshaft Position (CMP) sensor Valve cover Timing belt. Refer to the Timing Belt unit repair section. Timing belt idler pulleys Timing belt rear cover Oil pressure switch connector Camshafts Cylinder head. Remove the bolts in reverse of the tightening sequence.
To install:
Fig. Cylinder head torque sequence-2.2L (VIN D) engine
NOTE Use new cylinder head bolts for assembly.
  1. Install the cylinder head with a new gasket. Tighten the bolts in sequence as follows: Step 1: 18 ft. lbs. (25 Nm)Step 2: Plus 90 degreesStep 3: Plus 90 degreesStep 4: Plus 90 degrees
    1. Step 1: 18 ft. lbs. (25 Nm)
    2. Step 2: Plus 90 degrees
    3. Step 3: Plus 90 degrees
    4. Step 4: Plus 90 degrees
  2. Install or connect the following: CamshaftsOil pressure switch connectorTiming belt rear coverTiming belt idler pulleys. Tighten the bolts to 18 ft. lbs. (25 Nm).Timing beltValve coverCMP sensorSpark plugs and wiresFront coverPower steering pump pressure switch connectorEngine wiring harness connectors at left rear of the engine compartmentIntake manifoldCanister hoseEVAP valve connectorFuel linesWater bypass hoseHeater hosesKnock sensor connectorCKP sensor connectorAlternator and bracketsExhaust front pipeAccessory drive beltUpper radiator hoseAir intake assemblyPCV valve and hoseIAT sensor connectorNegative battery cable
    Camshafts Oil pressure switch connector Timing belt rear cover Timing belt idler pulleys. Tighten the bolts to 18 ft. lbs. (25 Nm). Timing belt Valve cover CMP sensor Spark plugs and wires Front cover Power steering pump pressure switch connector Engine wiring harness connectors at left rear of the engine compartment Intake manifold Canister hose EVAP valve connector Fuel lines Water bypass hose Heater hoses Knock sensor connector CKP sensor connector Alternator and brackets Exhaust front pipe Accessory drive belt Upper radiator hose Air intake assembly PCV valve and hose IAT sensor connector Negative battery cable
  3. Fill the cooling system.
  4. Start the engine and check for leaks.
  1. Before servicing the vehicle, refer to the Precautions Section.
    Negative battery cable Intake Air Temperature (IAT) sensor connector Positive Crankcase Ventilation (PCV) valve and hose Air intake assembly Upper radiator hose Accessory drive belt Exhaust front pipe Alternator and brackets Crankshaft Position (CKP) sensor connector Knock sensor connector Heater hoses Water bypass hose Fuel lines Evaporative Emissions (EVAP) valve connector Canister hose Intake manifold Engine wiring harness connectors at left rear of the engine compartment Power steering pump pressure switch connector Front cover Spark plugs and wires Camshaft Position (CMP) sensor Valve cover Timing belt. Refer to the Timing Belt procedure. Timing belt idler pulleys Timing belt rear cover Oil pressure switch connector Camshafts Cylinder head. Remove the bolts in reverse of the tightening sequence.
To install:
May 26, 2012 | Isuzu Rodeo Cars & Trucks
I HAVE A KENMORE 90 PLUS SERIES DRYER. IT DOES
check the door switch and also check the belt,if the belt breaks there is a switch inside that turns the dryer off
Mar 19, 2010 | Kenmore Dryers
My Kenmore 90 Plus Series dryer runs (you can hear it when you turn it on) but the drum does not spin. What could this be?
broken belt,remove the bottom panel and get down there with a flash light and see if you can see or feel the belt-mike
Mar 01, 2010 | Kenmore Dryers
How much is the cost to replace a timing belt and how much time should it take?
A simple belt replacement is typically about $400 on your car (02-06 Camry V6)
The belt retails for $52 from Toyota.
The book labor time is 3.6 hours (at whatever your local shops charge, typically around $90 per hour)
Common add-on repairs at the time is the waterpump for an additional half hour plus parts, and the cam shaft seals (which are notorious leakers on this engine!) which is an additional 2 hours labor (plus parts). That time is fairly generous though, and most shops (mine included) typically charge much less to add the cam seals..
Sep 11, 2009 | 2002 Toyota Camry
Overheated a 2000 isuzu rodeo 2.2 litre
  1. Sorry.... I did not see the 2.2 in title. Install the cylinder head with a new gasket. Tighten the bolts in sequence as follows: Step 1: 18 ft. lbs. (25 Nm)Step 2: Plus 90 degreesStep 3: Plus 90 degreesStep 4: Plus 90 degrees
Aug 24, 2008 | 2000 Isuzu Rodeo
Kenmore 62602 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
