Question about Bosch 24 in. SHU43 Built-in Dishwasher
Leaks, doesnt drain properly and cloudy film on glasses
Ok, have had our Bosch for 3 years exactely. Model# SHU43C06UC /17. a month and a half ago it started leaking perfusly and has ruined the floor(pergo) another mistake. , then shortly later about 4 weeks of that it just quit running altogather. I can hear the moter but nothing else, no water no movement etc. Of course we dont use it now but prior to this it ran like a quiet mouse and cleaned beautifully. I have ALWAYS rinsed everything clear prior to washing in the dishwasher so why would this happen? There is nothing caught in the filters or the piping as far as I could tell(my husband has checked). I am sorely disapointed with such an expensive piece and frankly expected higher quality. I am the only one who loads and operates this appliance.
  • 4 Answers
U have water under dw .and overfill switch turninng on only  drain pump all time.second from bosch water  water never leaks on floor.
Posted on Oct 03, 2008
MY BOSCH DISHWASHER MODEL #SHU43C06UC/17 WILL NOT START. NONE OF THE LIGHTS TURN ON AS IF THERE IS NO POWER GETTING TO IT. I HAVE CHECKED THE POWER CORD AND THE BREAKER BOX AND EVERYTHING IS O.K., BUT I...
Hi gwmkjm,
I'm Harvey the Master Plumber.
Your question is: YOUR BOSCH DISHWASHER MODEL #SHU43C06UC/17 WILL NOT START. NONE OF THE LIGHTS TURN ON AS IF THERE IS NO POWER GETTING TO IT. YOU HAVE CHECKED THE POWER CORD AND THE BREAKER BOX AND EVERYTHING IS O.K., BUT YOU STILL CAN NOT GET IT TO TURN ON. AT ONE TIME THE LED LIGHT LIT UP FOR A BRIEF SECOND, BUT NEVER AGAIN. ANY OTHER SUGGESTION?
Yes. 9 times out of 10 it's a loose or broken wire in the d/w junction box under the d/w behind the kick plate on the right. Make sure to turn off the electric before you expose the wirenuts. Remove them and install new.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 28, 2008 | Bosch Dishwashers
Can you tell me why glasses etc., are not cleaning properly. very cloudy
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Apr 07, 2011 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Bosch SHZ46B does not seem to heat water properly - only to 120F. Glasses and dishes are left with whitish film.
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Feb 15, 2011 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Glasses have white film, why? Machine is 2 years old, problem just started 2 months ago.
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
Dec 29, 2010 | Maytag Dishwasher
We have a new Bosch SHE55M15UC. It worked fine for 4 months, now it leaves a dirty looking film over all the glasses. A service guy came buy and said he tested it and everything is working fine. He said...
Nov 17, 2010 | Bosch Evolution 500 SHE55M05UC Stainless...
Dishwasher not cleaning/rinsing properly
try connect a water filter (carbon and particle), and connect the machine on output filter, mormaly resolve this problem. Some old houses has water supplie problems, as dirty water, and contamined problems, check for water purity.
Jan 14, 2010 | Dishwashers
Bosch shu43c06uc-17. Our dishwasher turns off mid cycle, and now leaks from the bottom.
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Nov 28, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Cutlery is cloudy and dirty, some food is dried onto knives and forks. Cups and glasses are cloudy and not clean on inside. Coffee or tea stains are not removed. Plates and soup bowls seem OK , and water...
they must have changed the way they treat the water in your area. those spots are caused by hard water. www.dishwasherfilter.com has a product out for this problem. it filters the water going into your dishwasher leaving them spot free and crystal clear with every load. you will love the way your dishes look.
Mar 21, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
Bosch SHX46A dishwasher
there is a new product out that actually filters the water going into your dishwasher. I use to have ugly,white and cloudy looking glasses until i installed this product. after the first load my glasses looked fantastic!!!! its affordable and you can get it at dishwasherfilter.com.
Apr 01, 2008 | Bosch 24 in. SHE56C05UC Stainless Steel...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
246 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
