Question about Mintek MDP-1770 Portable DVD Player
Problem with CD player working with Television
Hi -
I've hooked up my Mintek MDP-1770 &" TFT Monitor DVD player to my Daewoo tv - with the yellow Video cable but I can't get what's getting played on the DVD player to show up on my TV screen (which was one of the 'quirks' I liked about this equipment.
I'm having a hell of a time with this and it's taking up so much of my time, I'm getting fustrated - and give up (I've tried this many times and failed). I've got the 'clicker' for it and a clicker for the Television set and I'm getting 'clicked-out' here!
Would you please help me out with this? It's a great little player - I'd just like to see the images from the CD-ROM a little bit larger than on a 7" screen!
Thanks a lot,
Billy
SOURCE: MINTEK MDP-1770 PORTABLE DVD PLAYER
did u find a solution yet because i am having the same problem?
Posted on Jun 11, 2008
  • 17 Answers
SOURCE: I want to know if
yes,is same
Posted on Aug 11, 2008
SOURCE: Mintek MDP-1770 Portable DVD is not powering up
Change the battery
Posted on Aug 12, 2008
  • 7 Answers
SOURCE: need user manual for mintek dvd player MDP 1770
stop asking me questions im trying to go to sleep now go somewhere
Posted on Apr 04, 2009
  • 814 Answers
SOURCE: I have sound but no picture, can you help
Please give more information, on how you found the problem. Have you tried the video output connected to another monitor to see if the video processor circuits are still functional. You can do this by using cables to the video output of the dvd player to the input of your television. Usually Three wire connections. The yellow connector is for the video and the red and white connectors are for the audio. Make these connections and use your television on a alternative signal source input. This is usually a function button on the television or the remote control. The function is usually labeled input. You can find the correct set-up information with pictures in the owners manuals of the products. If after testing the video ouput from the dvd player. You find that you do have output, then you may have a connection problem between the main board and the LCD screen. These connectors are usually ribbon cables and are a yellow or golden color. They are connected by a clamping connector. The connector is usually released by using a small screw driver to release the clamping device. You can check the connector and see if it looks like it still working. If the connector looks crimped,torn or bent badly it may need replacement. If they look ok , then you may want to use some contact cleaner to clean the connection points and the connector. You can do this by spraying a small amount of contact cleaner on a cotton swab. Take the swab and wipe the connector, cleaning the connection points and then use a small brush with a small amount of contact cleaner to clean the connector. You can also use a can of compressed air to blow all dust and debris from the connector and the circuit board. Make sure to clean all areas of the board as dust and dirt act as a heat blanket and cause overheating problems on the ciricuit board. If all of this seems over your head. Have a friend help you. Or take it to a repair shop for evaluation. There are many helpful videos on you tube that can show you how to do the disassembly and cleaning of the player . Look under cleaning and repairing portable dvd players. If you have a vidoe processor failure, then it may not be repairable. The expense may be more than the cost of just replacing the dvd player. I hope this information helps you with your problem.
Posted on May 29, 2009
How do I hook it up to a TV so that we can watch a movie on the TV instead of the small screen
On the side there is a video out socket ( sometimes marked AV out and yellow in color ). You will have to get an interconnecting cable to link it to your TV. The back of the TV will have corresponding yellow/red/white sockets. The yellow is for video and the red/white is for left/right audio. Your player comes with this cable along with the AC adapter . bobhifi_56.jpg
Aug 16, 2011 | Mintek MDP-1770 7 in. Portable DVD Player...
How do you hook-up mintek 1770 to tv
Look for a special special connector that may or may not have come with your unit. It will be a Y connector with a plug in jack on one end and VGA (red, yellow, white) jacks on the other. Plug this end into an input on your tv.
Aug 11, 2011 | Mintek MDP-1770 7 in. Portable DVD Player...
I was given a mintek dvd player model mdp-1770 it is say no disc when there a dvd in it i have tryed recalbreting it by sliding back forth four time then loading a cd but it still reads no disc
If the unit plays CDs but not DVDs, then the LED for DVDs is burned out. There are separate LEDs for CD and DVD operation.
If neither plays, there is a more fundamental problem. In any case, only factory service will correct the problem with your "white elephant".
I have exactly this model.
Oct 07, 2009 | Mintek MDP-1770 Portable DVD Player
Need user manual for mintek dvd player MDP 1770
Apr 04, 2009 | Mintek MDP-1770 Portable DVD Player
Minitek portable dvd 1770
On the page your query showed up on, there's a link to www.GoToAssit.com and also a link to http://www.fixya.com/PostQuestion.aspx? Why not give them a try and go from there? Also: www.MintekDvdPlayers.GizmoCafe.com -
Sep 12, 2008 | Mintek MDP-1770 Portable DVD Player
Mintek MDP-1770 Portable DVD Player Logo
Top Mintek Televison & Video Experts
Jaime Hernandez
Jason Morris
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
