Question about Video Game Consoles & Games
System not over heated, hasn't barely been played but is acting as if it has overheated as it implys in the ps3 guide. Left it to cool just incase for over 24 hours, and it still won't come on or open to get the game out.
    Problem Solver:
  • 3 Answers
Ummm if it says its over heated or something try this( u get a vaccuem u know the vents behind+next to the ps3 . just vaccuem that area like outside the ps3 vacuem the vents then it should work . srry if it doesnt work >PS. u dnt open up your ps3
Posted on Sep 26, 2008
My ps3 keeps freezing during games
Problem: Your Playstation 3 console is freezing during gameplay. There are usually two problems that would cause your Playstation 3 to freeze during
gameplay. I will start with the most common problem:
1. The Blu Ray Laser is wearing out. This is a common issue among the newer video game consoles. The laser is constantly lighting up to read the discs while you are playing your Playstation 3 whether you are playing games, Blu Ray movies, or DVD movies. Eventually the laser will burn out. As it starts to wear out, first the games or movies will freeze. After a while, it will not read Blu Ray at all. Finally it will quit reading anything. You can find lasers at the following website starting at $49.95. The same website also performs repairs of the Playstation 3 console:
http://store.richspsxparts.com/pl3paac.html
2. Overheating. This is less common. If your PS3 freezes and you shut it off and back on and it comes on ok, it's probably not overheating. If heat is the problem, it will freeze right away if you turn it back on right away without giving it time to cool off. If it turns on OK with no problem and doesn't immediately freeze up, the laser is your issue. If you turn it back on and it freezes right away, your PS3 may be overheating.
If your PS3 is overheating, the best thing to do is to make sure you do not keep it in an enclosed area. Playstation 3 systems and XBox 360 systems run very hot. You must keep it in the open so it gets as much cool air as possible! You can also upgrade the fan inside of your Playstation 3 with the Whisper Fan which increases cooling. You can also find it at the following website:
http://store.richspsxparts.com/newpl3ps3taw.html
Apr 19, 2011 | Sony Playstation 3 (PS3) Console
Turn system on and will shut down with red light blinking waited about 1 hour to cool down but the same
Hi jrrhoada13,
The PS3 red light is a huge problem and it is caused by the GPU and the CPU overheating, all you need to do is stop the heat build up.
You have 2 ways of doing this:
You can send it in however bear in mind that for the fix you will have to wait for 4 weeks and also pay out $150 as well.
Or you can use a good PS3 Repair guide to fix the problem.
Make sure you check out these reviews of the top PS3 Repair guides first!
Cheers!
Mar 17, 2011 | Sony Playstation 3 (PS3) Console
The unit overheated and stopped working
Let it sit out for a while to avoid any heat damage. It should work once again once it has cooled this is a security for the PS3 to protect the internal components. To avoid overheating place PS3 in a well ventilated place where it can get a steady flow of cool air. Do not place it on carpet or any other surface that might insulate the system. Try to reduce play time take a break once in a while. If you would like longer game time buy an air cooler that hooks up to the PS3 and increases airflow and keeps it cooler longer.
Feb 26, 2011 | Sony Playstation 3 (PS3) Console
Ok, I was playing NHL11 (PS3), then it froze. I turned off my system, and tried to play again. It didn't work. I tried all my other games, and they didn't work either. I hadn't been playing long, I don't...
try to warp it in a blanket for about 30min for it to heated up thin let it cool down fo 15min make sure it get no air for 30min. that should take care of the freezz.Let me know if that works for you
Jan 01, 2011 | Sony Playstation 3 (PS3) Console
Playing any PS3 game and screen goes blank. red light on console blinks.
Common reason is your PS3 has overheated. Turn off system after removing game disc and let system cool. Clear any dust or debris from the vents and if possible, relocate PS3 to more open area.
Oct 28, 2010 | Sony Playstation 3 (PS3) Console
The playstation 3 shut off in the middle of play. Now the little red light just keeps blinking. We unplugged it made sure theere was nothing blocking it to cause it to over heat, we plugged it back in and...
If the system turns on but then turns itself off, beeps at you and flashes it's lights at you then you have over heated the system. The GPU chip has probly pulled itself away from the board. This will require you to diassemble the PS3...... u just fix this by using ps3 repair guide....
click here to download
Oct 11, 2010 | Sony Playstation 3 (PS3) Console
The problem is that i was playing Grand Theft Auto when my ps3 suddenly shut down. Now even when i turn it on it turns off after a while and a yellow light blinks where the normal green power light is....
The PS3 YLoD can be caused by a number of things. Most commonly, it's a result of a hardware failure, overheating, dust build-up inside the system, and occasionally just due to loose cables.
Let's start with the easy stuff first to narrow down the cause. Follow the steps below:
1. Assuming you were playing your PS3 when the YLoD happened, move your PS3 into an open area with a lot of ventilation and let it cool down for 20-30 minutes. Once it's cool, try to turn it back on and see if that helped. If not, go to Step 2.
2. Unplug all of your cables from the PS3 including the A/V and the power cord. Also unplug the power cable from the wall. Now try to plug them all back in and make sure they are all secure. Turn the PS3 back on and check if it's working. If not, go to step 3.
How to Fix PS3 Yellow Light on Your Own
3. Get a vacuum with a hose attachment and vacuum out the vents on the system. Sometimes dust build-up alone can cause your PS3 to stop working properly. You might also want to take one of those cans of air and blow it in there to get some of the stubborn pieces of dust out.
If none of those solutions worked, the problem lies within the PS3 and you will probably need to take it apart to fix it. The most likely scenario is that your heat-shield overheated, the chipsets got shifted due to heat, and your solder could be cracked.
the causes of the yellow light of death
Here are some of the top causes of the PS3 Yellow Light of Death:
* Overheating - The unit gets too hot. Sometimes caused by too much dust buildup in the vents.
* Blu-Ray drive failure.
* Bad power supply.
* Hard-drive critical errors.
* Hardware malfunction on the motherboard - The solder starts to crack due to excessive heating and cooling.
if you have warranty then take it back if you dont then you can either try the repair yourself how ever this is not very easy to do and can cause more harm than good you will need special tools to take it apart and its not easy you also need an understanding of heat seal paste and heat sinks due to this being the part you need to remove and put back
i do the repair for about 25pound plus parts so if you are paying someone to do it then your looking at least that price, i only charge if the problem is fixed so try and get the best price you can.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
b2
Sep 29, 2010 | Sony Playstation 3 (PS3) Console
Yellow Light Of Death. What's involved? Worth
Yellow light of death (YLOD) on your fat PS3 showing that the PS3 is overheated by consistently playing games. If the problem still persist after cooling down then you need PS3 repair guide to fix it.
Feb 02, 2010 | Sony Playstation 3 (PS3) Console
My ps3 starts to turn on for 1 second. Yellow light flashes, system shuts off, and red light blinks. Help?
HI, this is an emergency shut down, due to overheating. the yellow light is an indicator of a previous overheating issue that has damaged the power unit.
unplug the unit and, let it sit for 10 minutes to cool. after the cool off, plug the unit into the wall socket once more and, power up. if it continues to shut down and, flash the red light, this will confirm a major fault within the power unit. Contact Sony for the replacement of the power unit in this case.
***NOTE(If the unit begins to play normally after the cool-down period, you will need to purchase a cooling device to prevent future overheating issues).
Jul 21, 2009 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
27 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
