Question about Sony Playstation 3 (PS3) Console
Disc will not eject from PS3
The PS3 tries to ejct the disc, with no success. Does not read that disc is in system. Suggestions?
  • 1 more comment
  • Anonymous Sep 26, 2008
    my console will not read that a disc is in there. everything works, just wont read the disc.
  • jerag_kindre Sep 29, 2008
    Disk does not eject; tried turning the power off then turning it back on, then hitting the eject button, It sounded like the mechanism was working but no disk came out.
  • awillads Nov 16, 2008
    I just in a Blu Ray disc rented from blockbuster and have turned it on and off several times and tried to eject, but nothing just noise
  • 55 Answers
Power of and power back on. Then try to eject the disc right away.
Posted on Sep 26, 2008
Ps3 freezing and disc wont read and skips
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
The most common reason for the PS3 not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your PS3 including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your PS3 going again!
Hope this will help...
Take care.
I wish you good luck
Aug 05, 2011 | Sony Playstation 3 (PS3) Console
Disc cant read the disc and will not eject the disc. I tried unplugging it and putting on and pushing eject. no good. what do you think bose 321 system
disc cant read the disc and will not eject the disc. I tried unplugging it and putting on and pushing eject. no good. what do you think bose 321 system ...
Oct 08, 2010 | Bose 3 2 1 GSX System
Ps3 not reading disc..Please help
Do you see the little clock like icon in the top right corner of the screen when you first insert a disc the loading disc icon? if so then it could either just be the drive itself or a software issue in which case you can try a few things before replaceing the drive.
First just reset to factory default settings under system settings.
P.S. i assume its not reading any kind of disc if it isnt reading anything also double check to make sure the disc you are using are still good and not just really dirty or scratched. GIve us more info and what disc your trying to check so we can further help you out.
Justin
Apr 29, 2010 | Sony Playstation 3 (PS3) Console
I never had problems playing cod modern warfare 2 till I downloaded the patch 1.09. My Ps3 gets stuck mid game. What can I do?
I need help too, my when i turn on the Ps3, it runs normally, but the system doesn't acknowledge there is a disc in it. When i eject the disc and put it back in, it reads and i start it up, but about 30 seconds into start up, the game freezes. I already reset the system & recovered memory. Any suggestions?
Apr 26, 2010 | Sony Playstation 3 (PS3) Console
Im unable to install disc in drive
I have seen several suggestions at the playstation*com PS3 forums in the past, such as:
| Zr0_C00L wrote:Try turning it off from the back,
| then hold the eject button while you flip the back
| power switch back on. Worked for my buddies
| when his died (good thing too, it was my game
| in there!)
| i too did the same thing and it worked for me.
This one with multiple discs jammed it sounds like it may apply to you:
"If anyone is having any problems, this is what worked for me. What is more amazing is that my son somehow managed to force 3 discs into that tiny slot...no idea how he pulled that one off.
So after two hours, a pair of tweezers, a fork, and a butterknife, I decided to try one last thing before giving up. I put the PS3 on its nose, disc tray down, held the eject button while it was on, and pushed a disc in and out of the drive. This caused whatever was in there to finally 'catch' as the drive had been trying to force everything out. After 2-3 minutes of play, a disc finally poked out. I pulled what i thought was one and two discs came out. I set it back down flat, tried to put a cheap DVD in (didn't want to test it with a $60 game) and it seemed something was still in there. I hit eject and out came the third disc. I put the DVD in reluctantly and the PS3 took it and loaded it right up. Unbelievable. After all this abuse, it's apparent these things are built like tanks."
You gotta love children.
Hope that helps.
Comments: Oh, one more thing I remembered to try before you ship it off to Sony or open it up. Touch the eject button on the PLAYSTATION 3 system front for 10 seconds or longer to force the disc to eject. After removing and before reinserting a disc into the PLAYSTATION 3, turn off the system, and then turn on the system again to resume use.
Mar 19, 2010 | Sony Playstation 3 (PS3) Console
Ps3 not accepting/'sucking in' discs
I have the same problem. Sony told me that it is a piece of the track gets stuck on the motor shaft and then the motor cant turn to "**** in" discs or spit them out.
Apr 12, 2009 | Sony Playstation 3 (PS3) Console
PS3 is The amazing device by sony but it has some common problems like Disc read error etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Aug 27, 2008 | Sony Playstation 3 (PS3) Console
Ejecting the disc
I had the same problem. In fact, the board connector inside the printer was not really fixed. I just pushed it and it works perfectly now. But you have to open it... It's easy to do
Sep 11, 2007 | TDK LPCW-50 Thermal Label Printer
Jammed cd drive
  • Touch the eject button on the PLAYSTATION 3 system front for 10 seconds or longer to force the disc to eject. After removing and before reinserting a disc into the PLAYSTATION 3, turn off the system, and then turn on the system again to resume use.
  • If the disc cannot be inserted, you may need to send your system in for service, please click on the link below.
  • Aug 27, 2007 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    181 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
