Heater will not start up.all it do is run but will not heat.burn light was on one time but will not come on anymore.all i see is E13 flashing.
    Scholar:
  • 121 Answers
What is the make model and serial number
Posted on Sep 26, 2008
  • Edward Boukater Sep 26, 2008
    After thinking about this it sounds like you have an elec. heater which means if your fan and everything comes on an your sequencers are bad.
My delay light has come on and I cant get the dishwasher to start. The delay light goes out after the time has expired but if you try to move it to the start position the light comes on again
The Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). The Control will flash the Clean LED 7 times repeatedly and will disable the Start/Resume key until cleared.
To clear and reset the control press in this order: Heated Dry ? Normal ? Heated Dry ? Normal and then let the unit run for 1-2 minutes and then press Cancel and let the dishwasher complete the cancel cycle. The dishwasher should operate normally again unless it does not detect a temperature rise in the main wash cycle.
It could be caused by a Heater circuit problem if it continues to stop and flash the Clean light.
It could have one of the following failures:
Open in heater.
Open connection or component in heater circuit.
Faulty heater drive circuit on control.
It can also be caused by the wash pump not pumping water past the heater efficiently.
Oct 11, 2016 | Kenmore Dishwashers
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
An error occured we cannot print a document which the orange light was blink semoustanousely
Damage canon printers, can be identified from the number of lights blinking in orange. So, you calculate, how many times the orange light is blinking. Example E2, E3, E4, E5, E8, E9, E13, E14, E15, etc.
Problem
For
the error code E13 = The following ink may have run out black/color
Solution
Press and hold the Reset button about 10 second. E13 error on canon pixma, occurs twice. E13 for black cartridges, and E13 for the color cartridges
Nov 25, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Have a Reddy Heater RCP275 propane gas heater. If able to light - the heater will burn for 1-5 min. but then goes out. Sometimes burner will not light at all when the red pilot button is released. At times...
Sounds like the igniter needs to be replaced. It is normal for a heater to run five or so minutes that means the thermostat is working. then restart when the temp calls for heat but if the igniter does not work it will not light up again.
Jul 27, 2017 | Heating & Cooling
The "clean" button is flashing & none of the other cycles work.
heated dry and high temp wash
toggle till all the lights light up
then hit cancel
you should be able to turn dishwasher back on
you probably have a bad heater
is it flashing 7 times
take kick panel off and look to the rear of the dishwasher
is anything burned
if the clean light keeps blinking replace your heater
Feb 09, 2010 | Dishwashers
I have the Whirlpool Quiet Partner 1 the wash cycle starts and about 20 Min.'s into it the clean light starts flashing or the the start light, one or the other each time and it wont dry the dish's anymore...
If the clean light blinks 7 times thats you heating circuit. Test the heater with an ohm meeting to see if it has open. If so order the heater kit and it comes with the control board.
Jan 12, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Flashing green ''clean'' light and will not start a wash cycle.
the computer senced that the heater did not work last cycle. Push your sani clean, energy saver button s back and fourth a few times. It will run a self diag cycle. let it run for a few min. If it happens again your heater may have burned out.
Nov 11, 2009 | Kenmore Elite 45986 Front Load Washer
Empire GWT-50 creating soot and sometimes flashs when starting
if it giving off soot then it is wrong it sounds like the air mixture is wrong and the flames are light back to the injector that would be the woosh , no heat er should give off soot if combustion is correct
Jan 09, 2009 | Empire GWT-50 Wall Mounted Panel Heater
Have a mpi monitor flashing a e13 code
I have a propane monitor heater just installed 2 months ago and I get an e 13 code and the heater won't stay on???
Oct 19, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
