I cant get my puter to start after i put 4gb ram into machine, both slots work independantly. how can i fix this
  • electrobawz Sep 29, 2008
    Ok, I have a AsRock 4CoreDual-Sata2 motherboard and an intel core 2 duo cpu running dual boot win-xp(32 bit) and vista (32 bit). I'm trying to use 2 x 2Gb of ddr2 667 ram (Kingston), I can only get 1 stick of ram to work at a time, both slots work, as do both ram sticks as they have been tried independantly. The motherboard bios has been updated, and the motherboard can support 4gb ram. I have only got it to work once till i reset my puter then it wouldn't start again,(BIOS POST tests dont start)
    Novelist:
  • 116 Answers
Depends on the motherboard and chipset mainly. Some chipsets/motherboards will not handle 4gb of ram. IF you're running Windows Vista 64-bit it has a serious problem with 4gb of ram and need updated manually before you can run it with 4gb of ram. Most other operating systems can handle it without updates.
Check dimms by booting up with each one in a dimm. If they all start, then it's a compatiblity error with either the operating system or possibly the chipset if the BIOS POST tests do not commence.
Posted on Sep 26, 2008
    Problem Solver:
  • 9 Answers
First need more info on your setup. your puter may not support 4gb. If it does do you have the right ram. Make sure ram is same type. If so take ram out & reseat it. Make sure to shut down & unplug power from back of computer. If this does not work try putting one stick in & start puter
Posted on Sep 25, 2008
Laptop currently has three 4GB RAM sticks, is it possible to use another 8GB stick to upgrade it to 20GB?
It should. But RAM slots have a maximum RAM per slot. Have you checked with manufacturer manual to see what the max ram per slot is? And the max ram per motherboard matters too. Your mobo will only support so much ram.
Dec 07, 2012 | MSI Gt70 0nc-051us
What ram do I upgrade with,,cant seem to find the right pin number etc,..there are 4 slots..can i use them all
The specs for the RAM on this motherboard are:
DDR400/333/266 SD RAM with ECC. Maximum you can use is 4Gb in total (so 1Gb stick in each slot would be fine - just make sure you match them in pairs).
Maximum of 4GMaximum of 4GB of DDR400/333/266 SDRAM with ECCB of DDR400/333/266 SDRAM with ECC
Jul 26, 2011 | Chaintech 9CJS ZENITH Motherboard
Foxconn G31MV board problem. Have 4gb of Ram and a 2.6 Duo core, have just installed a EVGA Geforce 210 1gb into the pcie slot and WIndows wouldnt start up. It went strait to repair or start normally...
The motherboard should support 4gb of ram. Was the computer working before the installation of the video card. This motherboard has integrated graphics on it, this means when you install a new graphics card you have to enable it in the bios(and disable the integrated graphics) the instructions should have come with the card as well as the installation drivers. Normally before you pop the video card in you should setup windows and install the drivers then when they are installed you put the video card in the slot.
If you are installing the ram for the first time you should check if the system recognizes the memory be going into the bios settings and looking at system memory if not I would recommend re-installing the ram.
May 15, 2011 | Foxconn G31MV-K Motherboard
Hi there. I have an HP a6500f. Came pre-loaded with 4GB RAM. Worked fine for a year then started freezing/restarting/BSOD randomly. Ran memory diagnostics and got a BIOME-1 error with both sticks, but...
Try manually setting the ram timings in bios but....
i would think its a motherboard issue too by the sounds of it. find one that has a similar specification and fit it, I will suggest one if you need me to, just give me a list of the hardware you have installed on this current machine
Jan 14, 2010 | HP KQ495AA Pavilion A6500F Desktop PC
Blue screen with 4gb, OK with 3gb of RAM on 6720s laptop Using windows 7 (32 bit) there are 2x slots, but the top slot seems only capable of recognising 1gb of RAM without giving the blue screen at startup...
A 32bit OS and Processor is able to Identify and work with upto 3GB of memory.
That may be the cause of the issue
Even if any computer has more then 3gb of ram it will showup only upto 3gb.
if you install 4gb or more then also it will not show up.
.........and second reason, may the ram that you are using are not identical or one of them is not working properly.
Check the specifications of the ram and also try using one a time.
Thanks and Regards
Jan 03, 2010 | HP Compaq 6720s Laptop
RAM Upgrade
How much memory your Windows OS will recognize depends on which version of Windows you are running. 32-bit versions of Windows will see (and utilize) only 3GB or 3.5GB. To utilize more memory, install a 64-bit version of your OS. More information about OS memory maximums can be found at http://www.crucial.com/kb/answer.aspx?qid=4251
Not only is there a maximum amount of memory that your computer motherboard can accept, there is also a maximum amount of memory that your operating system (OS) can accept. For instance, when you install 4GB of memory in a 32-bit Windows system (the most common version; 64-bit systems are typically used by high-end users), your system reports only 3GB or 3.5GB.
First , we can assure you, there isn't a problem with the memory. While Windows allows for 4GB of memory to be addressed, it does not equate to 4GB of physical memory. Some of the memory (regardless of how much you have installed) is reserved for use by the devices that you are using, such as a graphics card, PCI card, integrated network connections, etc, meaning it is unavailable for use as normal main memory. Upon startup, your system calculates the amount of memory needed for these devices; if you haven't maxxed out the memory in your system, it's invisible to you, and all your physical memory (the installed RAM) is available for use. However if you've maxxed out the DRAM in your system, this amount will be deducted from your physical memory, so you can't use 100% of your DRAM. The maximum memory limitation varies by operating system, For instance, the 4GB memory limitation doesn't exist in 64-bit versions of Windows.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | IBM PC 350 PC Desktop
Extra RAM in emachines 5220
I think you are mixing ram.... Use the same make and module for your ram... when you mix ram, the problem is other ram can be difernt Voltage. some 1.9V, 1.8V, 2.0V, 2.2V to operate. If you have 1.8V and 2.0V the computer won't boot. Hope this helps.
Dec 23, 2008 | Computers & Internet
4gb ram not detected
hey
First of all kindly specify what how many rams slots and how many ram chips are there
like 1 X 4GB or 2 X 2 GB
Generally,
with RAM there can be a few problems
1) the frequency of ram whichmotherboard supports might be less than the freq at which the ramyou are puttin works, hence in this case RAM wont work on this motherboard and ull have to get the RAM replaced
2) some motherboards donot support a 1 x 4 GB RAM where as they might support a 2 X 2 RAM (ifyou do have 2 mem slots for ram)
and then there is the mosttrivial problem of the slot not being clean or arm not being putproperly, i can think of ne other reason for the ram not workingproperly..
For further assistance feel free to mail me at
kushalagarwal22@gmail.com
cheers
Kushal
Aug 27, 2008 | Gigabyte GA-K8NF-9 (890552602964)...
Doesn't start
take out all your ram and put one in the first slot turn on your system. if this does not fix it take out that ram and put another stick into the slot and power on your pc. continue this process with all your ram sticks if this does not fix your issue find a stick of ram you know works and try that
Aug 18, 2008 | E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz...
Can i upgrade my MT3705 to 4GB RAM?
If you get rid of Vista and put in 2gb of Ram your Laptop will not need 4 gb of ram.  You need to get it will not support double sided or ECC this is why you can not have 4gb you need 2GB kit (1GBx2), 200-pin SODIMM, DDR2 PC2-5300 memory module
Jun 12, 2008 | Gateway MT3705 Notebook
Computers & Internet Logo
David Payne
David Payne
