Question about Brother Office Equipment & Supplies
Paper jam when trying to send fax using my mfc 4800
    Guru:
  • 558 Answers
Please check the roller and open the cover if any alignment disturbs.
Regard
Ellin
Posted on Sep 26, 2008
How do i clear the fax memory? i can only send a few pages at a time without the fax not working and i think it's because the memory is full
most fax machines will show receiving memory left or transmit memory left, if it showing receiving memory full make sure there are no paper jams and there is lots of paper in paper cassettes and it will start to print all the faxes in memory... if its transmit memory, you will need to clear those documents in memory to be sent, probably waiting in que....
Dec 31, 2009 | Brother MFC-8860DN All-In-One Laser...
"unable to clean"
Hi dbostrander.
First check for foreign objects in the paper path. Check if you have any faxes in memory because you will lose them when removing power; see later.
Pull out the paper tray from the front and check for paper jams or torn paper anywhere inside the machine. Also check the 'jam clear screen' at the back of the printer. Remove the cover, remove any obstacle then replace ther cover.From the front of the machine lift the top cover from the right side till it is fully open on the slide. Check for jams. If the jam is under the print head you will have to disconnect the power (losing any faxes in memory *see below) to move the print head out of the way to clear the jam.Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
Check whether the MFC has faxes in
memory
1.Press Menu/Set, 9, 0, 1.
2. If the MFC has no faxes, disconnect the MFC
from the power source for several minutes
and then reconnect it then do as above.
—OR—
If faxes are present, you can transfer them to
another fax machine
If you have not set up your Station ID, you
cannot enter fax transfer mode.
3.Enter the fax number to which faxes will be
forwarded.
4.Press Mono Start.
5.After the faxes are transferred, disconnect
the MFC from the power source for several
minutes and then reconnect it.
You can transfer the Fax Journal report to
another fax machine by pressing Menu/Set, 9,0, 2 in step 1.
Hope this helps,
Mark.
Mar 21, 2009 | Brother MFC 210C All-In-One InkJet Printer
My fax Machine has lines going each page that prints out
Get a can of air, open the unit and blow it out.
Also, clean the glass.
That should help solve the problem
Jan 08, 2009 | Brother MFC 4800 All-In-One Laser Printer
Fax
cannot copy of memory card glossy paper keeps jamming
Jul 31, 2008 | Brother Multi-Function Center® MFC-215C...
Printer says paper jam, but there is no paper in the printer. (mfc 210c)
If the paper tore when removing it, chances are there could be a small piece of paper still causing the paper jam. Sometimes all you need to do is turn the fax off for a few minutes and then turn it on again and the paper jam message is gone
May 10, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother fax machine Fax-2820 MFC-7225N
Hi. Open the document control panel and look in with a flashlight and see if the jam switch is stuck. also look for a small piece of paper that might be stuck in there. The jam is in where you put documents in to fax out. Lawrence
May 08, 2008 | Brother IntelliFax-2820 Laser Fax
Jamming of paper using the Automatic Document Feeder
You may have a really tiny paper jam. You need to open up unit to get access to feeder properly. Use a torch, jams can be so small you can miss them. cheers lilacgerry
Jan 28, 2008 | Brother MFC 6800 All-In-One Laser Printer
Brother mfc 4800
TRY UNPLUGGING IT FROM THE WALL 12 SEC AND PLUG IT BACK UP
Jan 17, 2008 | Office Equipment & Supplies
MFC-1970MC Check Paper error
The black sensor flags have to move freely. Usually one gets dislodged when paper jams are removed to forcefully.
Aug 15, 2007 | Brother MFC-1970MC Plain Paper Inkjet Fax
59 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
