Question about Sony BRAVIA KDL52XBR2 Television
Sony bravia 46"
The remote control only turns on the TV. No settings can be viewed unless I press the buttons on the TV
  • toyroy Dec 29, 2008
    The HDMI connection on my SONY 46" LCD KDL-46S4100 produces a real low resolution picture. I mean Extremly Low, like real pixelated. I get same poor with DVD player / or Cable Box. I've tried a dif HDMI cables (Monster) same poor. Component Cables work fine, but my new DVD does Not support Component. I believe I've isolated the problem to be the TV. Don't know if it's just some dumb setting on the TV, or if there may be an actual prob with the TV. I'm about 6 months past warrenty.
  • 320 Answers
It sounds like either the remote is bad, or this TV may have a "showroom" setting to keep people from messing with th TV while it is on display. I would download the manual to see if it mentions a showroom setting, if not, try a new remote
Posted on Oct 18, 2008
HOW DO I CHANGE MY SONY LED TV FROM ARABIC WITH ENGLISH
You would need to do a factory reset
From the Sony Forums:
factory reset to your Television.
  1. Turn on the TV.
  2. Wait approximately 40 seconds for the TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button.
  4. While holding the UP ARROW button, with your other hand reach around the side of the TV and press and release the POWER button on the TV set.( not the power button on the remote) it should be the top button along the side panel.
Sep 06, 2014 | Sony BRAVIA KDL46EX720 46 Inch 3D 1080p...
How do you turn off TV?
Press the Power button on the remote control once, when the set it powered up. It will power OFF. If you want to power down totally, just switch off the main power at its panel.
Jul 28, 2014 | Sony BRAVIA KDL-46EX400 46" LCD TV
RM-GA014 remote can't switch Sony Bravia 46" tv on
Follow this procedure to troubleshoot if the TV does not respond to the supplied remote control.
  1. Remove the batteries from the remote control.
  2. Press each button on the remote control twice.
  3. Make sure none of the remote control buttons are jammed.
  4. Install fresh batteries into the remote control. IMPORTANT: Make sure the batteries are inserted in the (+ and -) direction shown inside the battery compartment.
  5. Make sure nothing is blocking the Infrared (IR) sensor on the TV. IMPORTANT: Some locations can interfere with the IR signal from the remote control. Glass enclosures, as well as fluorescent or halogen lights, may prevent the IR signal from reaching the TV.
  6. Point the remote control at the IR sensor of the TV.
  7. Press the POWER button and other buttons to test TV operation. IMPORTANT: Do not hold down the POWER button too long. Doing so may prevent the remote control from operating the TV.
    NOTES:
    • If some of the remote control buttons operate the TV but others do not, the remote control may need replaced.
    • If all of the remote control buttons work, no further troubleshooting is required. Otherwise, continue troubleshooting below.
  8. Try using the remote control at varying distances from the TV. IMPORTANT: Using the remote control too close or too far away may prevent the IR signal from reaching the TV.
  9. Turn the Light Sensor setting to OFF.
    1. On the TV itself, press the HOME button on the TV.
    2. Using the up arrow or down arrow select Preferences.
    3. Press the INPUT button.
    4. Press the up arrow or down arrow to select ECO.
    5. Press the INPUT button.
    6. Use the up arrow or down arrow to select Light Sensor.
    7. Press the INPUT button.
    8. Press the up arrow or down arrow to select OFF.
    9. Press the INPUT button.
  10. Power reset the TV.
  11. Make sure the TV has the latest system software (firmware) update installed, if applicable.
The troubleshooting steps above should resolve the issue. If you completed all the steps and the issue is not resolved, service may be required or the remote control may need replaced. Contact the Customer Experience Center at (239) 768-7547 to speak with a service representative for further assistance.
Apr 07, 2014 | Sony KDL46EX520 - Bravia Kdl-46Ex520 46"...
How to stop sony demo mode
  • Turn on your Sony Braviaicon1.png.
  • Press and hold the Up Arrow button on the remote control
  • Press the Powerlb_icon1.png button on the TV while still holding down the Up Arrow button. The TV will turn off and then turn itself back on.
  • Release the Up Arrow button. Once the TV turns itself back on, it will restore your Sony Bravia to its factory settings.
  • http://www.ehow.com/how_5855646_reset-sony-bravia-tv.html
    May 17, 2013 | Sony KDL 40CX520 40 CX520 Series Full HD...
    Sony Bravia KDL-46S4100, No Picture No sound
    I have a sony bravia kdl 40v 5100 for less than two years and i did not purchased an extended warranty and now my tv is down.
    I have no picture, no sound just a black screen when i turn the power on, the power (green) light is lite up and the tv turns off by itself for like less than 30 seconds. I have tried to press as many buttons on the remote control and on the side of the TV to get any message but nothing seem to happen. Any suggestions and solutions? Thanks
    Aug 23, 2011 | Sony KDL-46S4100 46 in. LCD TV
    The time on our Sony Bravia has slowly been getting more and more incorrect. How can we re-set it?
    Hello
    To reset your TV to factory settings do the folloing
    Turn on the TV while holding down the "Up Arrow" button on the remote control, press the "POWER" button on the TV. [The tv will turn itsef OFF, then back ON again]. Release the "Up Arrow" button.
    Warning: The reset will clear all of your customised settings including parential lock settings.
    OK
    Jan 29, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
    Volume control not working
    Most of the time one of the switches under the control buttons are bad on the control panel of the TV.
    Jul 05, 2009 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
    Remote code needed (sky+) to sync with Sony bravia kdl32v2000
    1. Press tv on your Sky remote control.
    2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
    3. Press tv again
    Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
    Sony Code: 0000
    4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
    5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
    Jan 16, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
    Sony bravia 46" remote control turns on the TV but no other buttons work
    First, change the batteries on the remote with e new set of batteries. Check to see if you can bring up the menu using the buttons on the TV itself. Let me know what happens
    Sep 25, 2008 | Sony BRAVIA KDL52XBR2 Television
    Sony BRAVIA KDL52XBR2 Television Logo
    90 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
