Question about Panasonic KX-P3626 Matrix Printer
Page Break While the print file is closed the print file has a page break inserted at the end. Is there a way to turn inserted a page break at that time.
    Guru:
  • 558 Answers
Your problem is not clear it is rather written in more confusing way.
Let me know if the file is save on your PC. Then open it and insert the page break and save it before printing.
Regards
Ellin
Posted on Sep 26, 2008
How to delete Page breaks in Excel
Move a page break Important To enable dragging of page breaks to another location in a worksheet, make sure that the cell drag-and-drop feature is enabled. If this feature is not enabled, you may not be able to move any page breaks.
To verify that drag-and-drop is enabled, do the following:
Click the File tab.
  1. Under Help, click Options.
  2. In the Advanced category, under Editing options, select the Enable fill handle and cell drag-and-drop check box, and then click OK.
  3. Select the worksheet that you want to modify.
  4. On the View tab, in the Workbook Views group, click Page Break Preview.
    2. Tip You can also click Page Break Preview za010181030.gif on the status bar.
    3. Note If you get the Welcome to Page Break Perview dialog box, click OK. To not see this dialog box every time you go to Page Break Preview view, select the Do not show this dialog again check box before you click OK.
  5. To move a page break, drag the page break to a new location.
Note: Moving an automatic page break changes it to a manual page break.
Delete a manually-inserted page break Note You cannot delete page breaks that Excel has added automatically. Adding manual page breaks, changing the page orientation, or adjusting column widths and row heights may affect automatically-inserted page breaks.
To delete a manually-inserted page break, do the following:
  1. Select the worksheet that you want to modify.
  2. On the View tab, in the Workbook Views group, click Page Break Preview.
  1. Do one of the following:
    • To delete a vertical page break, select the column to the right of the page break that you want to delete.
    • To delete a horizontal page break, select the row below the page break that you want to delete.
Note You cannot delete an automatic page break.
Jul 20, 2014 | Microsoft Excel 2010
Remove page breaks in excel
We would appreciate if you share with us your Excel version as well so that we can give you a more specific solution to your issue. In the meanwhile, you can refer to the following steps to delete a manually-inserted page break in Excel 2007, Excel 2010, or Excel 2013:
(Important: You cannot delete page breaks that Excel has added automatically. Adding manual page breaks, changing the page orientation, or adjusting column widths and row heights may affect automatically-inserted page breaks.)
2. Go to "View" tab, then go to "Workbook Views" section, and click "Page Break Preview".
(Note: You can also click "Page Break Preview " on the status bar)
(Important: If you get the "Welcome to Page Break Preview" dialog box, click "OK". To avoid seeing this dialog box every time you go to "Page Break Preview" view, select "Do not show this dialog again" check box and click "OK".)
3. Now do one of the following:
a) To delete a vertical page break, select the column to the right of the page break that you want to delete.
b) To delete a horizontal page break, select the row below the page break that you want to delete.
(Note: You cannot remove automatic page breaks)
4. Go to "Page Layout", then go to "Page Setup" section, and click "Breaks"
5. Click "Remove Page Breaks"
(Important: You can also remove a page break by dragging it outside of the page break preview area {to the left or right for vertical page breaks, or up or down for horizontal page breaks}. If you cannot drag page breaks, make sure that the drag-and-drop feature is enabled. To check the status of your drag-and-drop feature, click office button , click "Excel Options" tab, click "Advanced", go to "Editing Options" and make sure you have checked the "Enable fill handle and cell drag-and-drop" option.)
To refer to a pictorial explanation of the above steps, you can refer to "Delete a manually inserted page-break" section on the following Microsoft Support Page:
http://office.microsoft.com/en-in/excel-help/remove-a-page-break-HA102576899.aspx?CTT=1
GuruAid.com
Jun 22, 2014 | Computers & Internet
Page numbering
just insert section break at the end of 2nd page then at the footer of third page there will be option same as privoius just disable that option and insert page number
Apr 01, 2014 | Computers & Internet
Need to eliminate blank pages at end of word document
You can delete a blank page in a Word document by deleting the page break at the end of the page. You can also combine two pages by deleting the page break between them.
Make sure you're in normal view (on the View menu, click Normal). If nonprinting characters, such as paragraph markers , are not visible, click Show/Hide on the Standard toolbar, and then do one of the following:
  • To delete a page manually, select the page break at the end of the page, and then press DELETE.
  • To delete a blank page at the end of the document, select the page break or any paragraph markers at the end of the document, and then press DELETE.
  • To delete a page break placed before a specific paragraph, click the paragraph, and then on the Format menu, click Paragraph, click the Line and Page Breaks tab, and then clear the Page break before check box.
Dec 05, 2013 | Computers & Internet
Wants to give random page number in ms word
Not too sure whether your comment above is the problem or what you want to do.
Do you want to insert a page number, then put in non word doc pages, then have the next page in your word document numbered appropriately? If so, you need to insert a section break at the end of the page where you are going to put in pages, then make sure the page layout for the second section does not have "different first page" turned on. Now break any link between section 2 and section 1 in the page layout. So click off the "same as previous" icon in the footer in section 2. Then insert a new page number and set it to "start at" the page number you need it to be.
If you need several sections like this then just repeat the process.
Remember that if you delete a section break, then all the page formatting will revert to that in the previous section. Horrible but its what Word does. Go to the end of any document with sections and add one section break at the end of your text with the same page formatting as you want through the pages before you remove any section breaks in the document to avoid this.
There is a really good e-newsletter on Office issues, Woody's Office Watch; if you use Office a lot but find some features difficult to master, you'll love WOW, very helpful.
Sep 26, 2011 | Microsoft Office Professional 2007 Full...
My page breage function has disappeared. I need to
Go to INSERT, BREAK & select page break to do this anytime, OR
Click on the down-arrow at the end of the standard toolbar. Click on ADD OR REMOVE BUTTONS, then on CUSTOMIZE, and select the COMMANDS tab. Select the INSERT category. Now drag the icon for the page break function and drop it on the location in the toolbar where you want it to be. Simple and effective!! :-)
Jan 31, 2010 | Microsoft Word 2003 for PC
I would like to know how to stop getting the last page?
Usually this is because the file is just a tiny bit too long or they have a page break at the end...
AS A test, when you get the printer screen before telling it to print, select to print pages from this to that number and bump the last page down one number and see if it deletes that unneeded page...
I know the problem and it is annoying to waste a sheet.
Jan 23, 2010 | Canon PIXMA MP760 All-In-One InkJet...
My document has a cover and a table of contents. I want page numbering with one to start on the third page. I did do the page break for the cover and the contents and was able to start the document on page...
There are two ways to do this. The first way SOMETIMES works. If you don't have luck, try the second method.
Method 1:
  • Delete the page break between the end of page 2 and page 3
  • Position your cursor at the start of page 3.
  • Click on Insert / Break / Next page
  • Select all the text form page 3 to the end of the document.
  • Click on Insert / Page numbers. UNCHECK "show number on first page"
  • Click on <Format>. Make sure "Start at" is selected and the value is "1". Select <OK>
  • Select <OK>
Method 2:
You need to work with the headers and footers. When you are done, you'll have two different footer sections that are NOT connected.
  • Add a "next page" section break as you did above.
  • Click on View / Header and Footer
  • On the Header and Footer toolbar, Click on the icon for "switch between header and footer"
  • page down to page 3. Click on the "link to previous" icon on the header and footer toolbar
For some reason I occasionally have to do this twice to get it to stick but eventually it should work. The key is to make sure you have two separate footer sections; the first section is page 1 and 2 without page numbers then the second section (starting with physical page 3) that has page numbers starting with page 1
Sep 10, 2009 | Microsoft Word 2003 for Students &...
Inserting landscape paper
In most versions of word, to make page 2 of 3 appear landscape instead of portrait.
Create page 1 - assuming the default is portrait
then when near the bottom of page 1 do drop down menu Insert->Break and choose Next Page.
Then on the new page choose menu File->Page setup and select 'Landscape' on the margins tab.
then - when at the bottom of page 2(Lanscape) do drop down menu Insert->Break and choose Next Page.
Then on page three choose menu File->Page setup and select 'Portrait'on the margins tab.
Jun 20, 2008 | Microsoft Office Professional 2007 Full...
Keyboard
Hi
This is great! Did you just "beg" it to cough up the keys? ... Well don't answer ...
Here you go
[Pn Sc][Sc Lk][Pause][Insert][Home ][Pg Up]
[ F10 ][ F11 ][ F12 ][ Del ][ End ][Pg Dn]
Pls copy this to notepad (without any formating) to display properly.
Mike
Apr 13, 2008 | Dell Inspiron B130 Notebook
Panasonic KX-P3626 Matrix Printer Logo
144 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
