Question about Danby Heating & Cooling
I have a danby 4 season home comfort unit model #DPAC7599 it doesnt seem to blow hot air only warm air and it blows very cold air out of the back of the unit.
heatman101
  • 43501 Answers
SOURCE: Danby DPAC7599 Air Conditioner is not blowing cold
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jun 03, 2010
My mistral reverse cycle mss25ss model does not work at all in heat mode. what would be broken?
firstly is the air comming from the outdoor unit cold or warm? if it is cold then the 3way valve is working and it has changed to heating. If it stays warm then it is still in cooling mode. The indoor fan wont come on until the coil temp gets warm enough, ( so it doesnt blow cold air on you straight up). If it is changing into heat mode then the larger of the pipes connected to the outdoor unit should get warm/ hot. If this is not happening then the unit is either out of gas or the compressor is on hollidays and wont come back to work.
May 22, 2012 | Heating & Cooling
I want all cold air it blows hot out the back why
the back should blow out hot and at the front it blows out hot
the hot is the air in your room
Jul 22, 2011 | Heating & Cooling
2001 grand caravan engine doesn't heat up. doesnt seem like any circulation don't feel anything in top radiator hose.temp gauge doesnt above 1/4 also fluid in radiator is just warm
While engine running, does the air feel warm to hot blowing through the radiator, if it does water is circulading, if it feels cold, replace thermostat.
Dec 04, 2010 | 2001 Dodge Caravan
AC blowing warm
Is it that hot in Sedona. I live in Tucson and thats hot. Have your freon recharged. You can buy the refrigerant at Checker or AutoZone. How do you like our Governor. She really made the national news.
Apr 25, 2010 | 2005 Kia Sedona
The heat from my aircondition is soo intence that my room becomes hot rather than cold air
you need to direct the hot air coming out of the unit out of the room and the cool air into the room. You need to run a duct or tube from the condenser side to outside. Otherwise it is just recycling the air and adding heat from the compressor.
Jul 18, 2009 | Danby DPAC7599 Air Conditioner
Fan blows.. no cold air... no hot air exhaust blowing
This sounds like you either need to clean or replace the filter, but if the filter is some what new you might want to take a look at the coils just past the filter, if the coils do not have a shine to them then you might want to buy some coil cleaner (i found simple green or formula 50 works great), then you will have to spray the coils with the cleaner, let sit about 10-15 min, then give it a very good rinse with warm water. After that it should work like it is brand new. Enjoy!
May 28, 2007 | Sunpentown WA-1210E Air Conditioner
Dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Sep 03, 2006 | Danby DPAC9031 Silhouette 9,000 BTU...
Heating & Cooling Logo
29 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
CheckitRight
CheckitRight
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
