Question about Adapters.com Serial ATA IDE Converter and IDE to SATA Converter (SSIDEDD1)
RUNNING A SATA HDD ON AN IDE ONLY MOTHERBOARD
One of my desktop PC's is a Dell Dimension 4550 P4 running at (I think) 2.4GHz. Not so long ago I bought a 320 GB Maxtor SATA 2 drive for it with a PCI controller for the SATA drive.
In this configuration I can run the SATA as master, no problem.
In this configuration I HAVE to leave the IDE drive in situ or the thing won't boot - even though the IDE drive is now slave.
Having two HDD's in the unit causes the SATA unit to overheat, shutting the system down.
This was the point where I decided to say enough is enough!
So I bought a Dell XPS 420 ten months ago.
However, I saw recently a card which allows you to run a SATA drive through an IDE interface:
http://www.ebuyer.com/product/139072
So I bought one to see if I could finally solve my original problem.
The drive shows up in the bios, but the pc just will not boot - there are no jumper settings to try, I'm wondering if its because the adaptor card is plugged directly into the IDE socket on the motherboard, and I'm wondering if the absence of a master/slave cable is causing its refusal to have anything to do with the SATA drive?
Anyone know of a SATA to IDE converter that plugs into the cable rather than the IDE slot on the board?
Anyone got any suggestions at all - I feel I am so near and yet so far and I can't help thinking a little tweak is all I need.
Thanks in advance for all help, hints, suggestions & solutions!
Rob H
  • rh2705 Sep 27, 2008
    Problem Solved!
    To confirm your diagnosis, the first thing I needed to check was to see if the boot error message was consistent with solution #1:
    The message was "PRESS F1 TO RETRY BOOT OR F2 TO RUN SETUP - not helpful at all.
    With the help of my Partition Magic and Boot Magic rescue disks, I noticed that the partition on the SATA drive where the OS was was not set as he active partition. I fixed this and then I got NTLDR missing - backing your theory up! So using Boot Magic Rescue floppy I tried to boot through that and this fixed the problem - it booted no problem at all and i now have a single SATA running from an IDE socket!
    Many thanks - I did not think this would be such an easy fix - well worth whatever $10 converts to in English Money (about a fiver ish).
    Top Marks mastersaintx!
    Master:
  • 441 Answers
Why don't you just buy a SATA enclosure for your drive? Then you can just plug it using the USB port on the computer
Posted on Sep 25, 2008
  • 6,487 Answers
The Sata drive are always set to master there's no way to salve it so if you have a Sata drive its always set as the Master hard drive and I will suggest you to get a sata expansion card that works via PCI slot check this link for that product http://www.mittoni.com.au/serial-ata-sata-pci-expansion-card-p-1565.html
Hope that helps.............
  • 928 Answers
If I am not completely mistaken you have to reinstall the OS on the SATA drive on IDE. That is because the first installation was configured for connection on a SATA /PCI then now on the SATA/IDE port converter.
Bought a dimension 4700 at the local goodwill and am having trouble getting it working
It sounds to me like the on-board HDD controllers are dead. Have a look at the motherboard... I'll wager you'll see a fried capacitor right in the middle. Common Dell failure :(
Jul 20, 2014 | Dell Dimension 4700 PC Desktop
SATA on dell dimension 4550 with Debian
look in the devicemanager what does it say.
update thrue the deviemanager or search the internet
May 26, 2013 | Dell Dimension 4550 PC Desktop
I want to install a dvd-rw into my dell dimension 4700, can I use a SATA or an IDE?
You can use IDE. Check the below link for further details:
http://support.dell.com/support/edocs/systems/dim4700/sm/parts.htm#wp1054337
**If this works please rate else let me know in case of further help.**
Jul 05, 2010 | Dell Dimension 4700 PC Desktop
Can i put a amd processors in a dell dimension
Short answer: NO.
Long answer: AMD processors have a different pin-arrangement than found on a Socket 478 motherboard, so they physically will not fit.
Jul 03, 2010 | Dell Dimension 4550 P4 Socket 478B...
I have a dell dimension 4600 what kind of motherboard do i have.
Your Dell Dimension 4600 comes with an Intel motherboard with the Intel 865PE or 865G chipset running an Intel P4 class processor.
Here are the specifications for your machine and motherboard:
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm
Mar 07, 2010 | Dell Dimension 4600 PC Desktop
My Dell Dimension 4550 won't recognize my CPU.
your problem is the same as trying to put a AMD3 into a AMD2 socket, yes it fits and yes i physically should be able to run it it but in reality it won't
Sep 26, 2009 | Dell Dimension 4550 P4 Socket 478B...
Error loading operating system on a dimension 4550
Need new hard drive. If that fails then the controller on the motherboard is shot and its time to buy a new computer.
Jun 05, 2009 | Dell Computers & Internet
Primary hard drive not found
since you already tried removing and reseating the hdds . The problem could be the motherbaord slot. To troubleshoot the same
1. First Disconnect all hardrives and optical drives from the system
2. Go to the system setup or BIOS
  1. Turn on (or restart) your computer.
  2. When the blue DELL™ logo appears, press <F2> immediately.
If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft® Windows® desktop. Then shut down your computer and try again.
3. Hold down the ALT key and press "F"
4. Hit ESC , save changes and exit .
5. SHutdown the system
6. Reconnect the HDD IDE cable to the optical drive connector on the motherboard.
You can refer to the following motherboard diagram
http://support.dell.com/support/edocs/systems/dim4550/techov.htm#1101668
7. Check if the hdd , is getting detected in the system setup
You can refer to the following link on how to read system setup screen
http://support.dell.com/support/edocs/systems/dim4550/syssetup.htm
Thanks
Proton
Jan 30, 2009 | Dell Dimension 4550 P4 Socket 478B...
Hard drive
According to http://reviews.zdnet.co.uk/hardware/desktops/0,1000000973,10004197,00.htm this tower has Serial ATA, or SATA. Just to confirm, you can easily pop open the case and take a look at the hard-drives. If you see a wide thin ribbon-like cable connecting to your hard-drive then you need an Ultra ATA (or just ATA or IDE) drive. It looks like this:
If a thinner red cable connects to your drive, then that is SATA. It looks like this:
May 13, 2008 | Dell Dimension 8300 PC Desktop
Computers & Internet Logo
441 people viewed this question
Top Adapters.com Computers & Internet Experts
Imre Vetro
T-Comtech Repairs
T-Comtech Repairs
Are you an Adapters.com Computer and Internet Expert? Answer questions, earn points and help others
