Question about Bose Lifestyle SA-3 2-Channel Amplifier
Bose SA-3 Amp / Blown Fuse
I inadvertently crossed the speaker wires on one channel and from then on, the amp would not power-up. I located a blown fuse and replaced it but the amp still will not power-up (as indicated by the LED). I can trace the power up to the transformer and it's correct at 120v. How can I trouble shoot thru the transformer? What should I expect on the "other" side?
The transformer is "Billion 271728 REV;.01
  • 4,234 Answers
The problem is not the transformer. You now have shorted output transistors at the very least. By corssing the wires you presented a zero(0) ohm impedence load to the output section. It quickly went into overload. Before the fuses had a chance to open up, the outputs fried. This unit will require new output transistors and perhaps the previous driver circuit will require parts as well. Figure on $20-$50 in parts plus hte local labor rate for the repair.
Posted on Oct 01, 2008
  • Dean Hand
    Dean Hand Jul 09, 2017
    Will this happen every time he wires crossed? Or is his case unique?
My Bose SA3 2 channel amp keeps blowing when I raise the volume with non-bose speakers, why is this happening?
Could be the impedence of the speakers that you're connecting. The bose amp was designed to drive 8 ohm speakers.
Aug 31, 2016 | Bose Lifestyle SA-3 2-Channel Amplifier
Where is the fuse on a bose sa3 amp?
It will be on the inside of the amp, located on the power supply board. The are many types of fuses, so it may may not like like you expect.
May 19, 2014 | Bose Lifestyle SA-3 2-Channel Amplifier
Amp 230v 50hz I have blown 3 Amps so far in less than 6 mos.
As long as you are not connecting say an 8ohm amp to 4ohm speakers and the speakers are in good condition, the problem is almost certain to do with the speaker wiring. It could be that the connections are being touched together, perhaps by someone (a child) or a pet messing or moving the speakers or wiring, or some old or bad wiring. Any touching of the cable wires, will blow the amp!
Mar 13, 2014 | Bose Audio Players & Recorders
2010 VW CC factory stereo amp popping sound
If the amplifier itself is making the popping sound I suggest you disconnect it immediately, as it could be an electrical short within the amp. If the popping sound is actually coming from the speakers, it could be due to a crossed wire, blown amp channel, or blown speaker. If you posses the technical know-how, you can test the amp channel and speaker by connecting a different speaker to the channel responsible for the popping sound. If the new speaker makes the same popping noise then it is most likely a blown channel. I hope this helps =)
Where is fuse in Bose SA-3 Amp
If there is not an external round push and turn style fuse port then it is in the unit itself. You will have to take it apart.
Jan 27, 2013 | Bose Lifestyle SA-3 2-Channel Amplifier
Model: st-202+ Speaker wires crossed while amp was
if you have located the fuses )blown) and are glass fuse type then simply take them out and replace with same type fuse if they a crt fuses you will need to know how to de solder and re solder with regards to them they are not pol sensortive
Jun 30, 2010 | Audio Players & Recorders
Bose SA-3 amp and a non bose sub.. I keep blowing the amp..
How many ohms is your sub? The SA 3 Amp can only handle speaker(s) 6 ohms and greater. A lot of subs, as I understand, are 2 and 4 ohms typically. If yours is 2 or 4 ohms, then that explains it. The speaker would be "straining" your amplifier and blowing it.
Oct 02, 2009 | Bose Lifestyle SA-2 2-Channel Amplifier
Quiet Speakers
Check inside the amp you might have blown a fuse in one of the channels
May 23, 2009 | Bose 3·2·1 II System
If no warranty - remove amp and check sub to another amp to isolate speaker from internal amp. Either the amp blew a channel or subwoofer blew. JBL's are typically well built. Has this speaker often been pushed loud often?
Apr 23, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Bose Lifestyle SA-3 2-Channel Amplifier Logo
1,390 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
