I have a HP L7780 I left a sheet on the bed and put a piece in the feeder, it jammed, I pulled paper out, then the paper will go in about half way and stop but wheels are still turning. Thank you for your help. Rex
  • rvrconstruct Sep 25, 2008
    sorry about the posting under Tv I'm new here. Yes it is a printer
  • 2,071 Answers
Just click below for troubleshooting;
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00839319&dlc=en&product=2512010
Hope it may help you;
Regards,
VOTIT
Posted on Sep 25, 2008
  • 6,487 Answers
Try first to turn off the printer for 5 minutes then check again for any foreign object that might be causing the paper jam...
Hope that helps..........
    Genius:
  • 1,550 Answers
Are you talking about printer ?
Be clear . It is posted under projection television
  • SAM ANDERSON Sep 25, 2008
    • Turn off the printer and remove all paper from the paper tray & disconnect it from the computer.
    • With the printer off, check for any obstructions such as torn paper.
    • Turn on the printer .
    If the problem still exists
    • Clean the roller and plates .
    SAM ANDERSON
    Try this fold the top 20mm of a sheet of A4 over and loading it so fold is at
    the top facing you. This acts as a catcher for anything stuck in the
    printer. Hold the paper slightly crooked with the left side slightly
    further into the printer and press the copy button . It should draw the paper in now . Check as the top of the
    sheet goes in that the fold is still tight and doesn't open up as it
    feeds in. This will bring out any torn papers and printer will work properly .
Paper feeder pulls multiple sheets of paper
PULL ALL PAPER OUT OF MACHINE EVEN THE SUPPLY, UNPLUG OR TURN OFF THE POWER TO THE UNIT, PUT A STACK OF PAPER IN THE SUPPLY TRAY & GENTLY PUSH FORWARD NOT FORCING IT UNTIL IT STOPS. TURN POWER BACK ON & TRY AGAIN. YOU MAY HAVE TO REPEAT THIS 2-4 TIMES BUT IT WORKED FOR MY HP DESKJET F4180 ALL IN ONE.
Dec 28, 2012 | Canon PIXMA MP460 All-In-One InkJet...
The paper keeps jamming, I cant see anything in the way. any help is appreciated.
If paper doesn't feed correctly when printing, remove it and fan the edges of the paper to separate the sheets. Reload the paper against the right side and slide the edge guide against it. Do not load too many sheets at once.
If paper has jammed: 1. Press x Start to eject the jammed paper. 2. If paper is still jammed, gently pull it out from the output tray or sheet feeder. If paper is stuck inside, press the P On button to turn off the printer. Then lift the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the printer back on.
If documents don't feed correctly in the Automatic Document Feeder, make sure the corners of the paper are not bent, folded, or curled up. Do not load more than 10 sheets of legal-size paper at a time. If documents have jammed: 1. Open the ADF cover and pull any paper out to the left. Caution: Do not try to remove the paper without opening the ADF cover first, or you could damage the mechanism. 2. Select Yes or press OK to clear any messages on the display screen. 3. Reload the paper.
Feb 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Cartrige won't move
    Instructions Things You'll Need:
    • Cup of distilled water
    • Clean wash cloth
      Fixing The Printer Cartridge
    1. Shut down the HP 6480 by pressing the "On/Off" button on the right side of the control panel. Some paper jams will clear themselves just by turning the printer off and starting it again. Wait a few minutes after the printer has shut down and then turn it on again.
    2. Remove the paper feed tray. If the printer does not clear the paper jam by itself, shut off the device again. Be sure to pull the tray out gently to avoid damaging the device.
    3. Lift up the automatic document feeder. The feeder makes up the top half of printer, and it can be opened like the hood of a car. Lift the sides of it slowly. This exposes the printer mechanism and ink cartridges. Pull the jammed paper up and out of the printer mechanism with both hands. Pull it gently to ensure you don't damage any components.
    4. After removing the paper, clean off the cylindrical, silver printer roller. Dampen a clean cloth with distilled water, and gently wipe any dirt, ink or paper off the roller. Rotate it when you're done cleaning one side, and continue rotating and cleaning until the roller is clean on all sides.
    5. Close the automatic printer feeder. After removing all paper, close the top printer feeder and shake it to ensure it's fastened. Re-attach the printer tray by lining it up with the arrow markers on both sides of the printer.
    6. Put one sheet of paper into the printer tray, and reset the HP 6480 by pressing and holding the "On/Off" button for 15 seconds. The printer should automatically restart and return to factory settings. It will run diagnostics and the printer cartridges should begin moving again as they print a test sheet.
    Dec 21, 2010 | HP PSC 1350 All-In-One Thermal Printer
    . There is a piece of paper that's jammed up in
    tweezers or needle nosed pliers are your best bet. the process of releasing the wheels usually requires partial disassemble.
    Dec 15, 2009 | HP LaserJet M1522nf Multifunction Printer...
    Epson stylus DX3800 All in one printer, scanner Unable to print
    Open the printer cover and look closely for tiny paper shreds that might got stuck between the rollers. If you have a canned air, try blowing out the paper path as those tiny piece of paper might be blocking the paper sensor.
    Sep 20, 2009 | Epson Stylus Multifunction Inkjet Printer/...
    Documnet feeder jam
    Check input paper feeder at top too - easy to miss. Top flips open with a firm (but not excessive) pull, so you can look there.
    If you are sure you've opened and looked under every available panel on the printer (there are many!), turn it off and unplug for half a minute. Make sure all panels are back properly in place, but leave out the paper tray (and no paper either in the rear input paper feeder).
    Plug in and turn on. Wait for it to finish its start-up sequence - it should complain about no paper.
    Check the paper is flat and straight in the paper tray, and no excess room between paper and guides, and put it in again.
    Print test page.
    How is it now?
    Sep 15, 2009 | HP LaserJet 3055 All-In-One Printer
    Paper jam in auto feeder
    Well you should be able to pull out the whole sheet of paper. If the jammed paper has a piece missing, then you did not clear the jam completely and will have to in ther and retrive the torn piece of paper.
    The source of the jam can be a worn p/u roller or an obstruction in the paper path.
    Jan 06, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
    Paper jam issue
    I finally fixed the problem by running two sheets of heavy card stock through at the same time.  With the machine off, I positioned the two sheets in the feeder so that they would be pulled in when the printer was turned on.  When I turned on the printer, it drew the two sheets through and I guess this reset the paper sensor.  I previously found that only one sheet at a time did't work.
    Nov 26, 2007 | Canon PIXMA MP460 All-In-One InkJet...
    Paper jam light is on
    Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
    Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
    Televison & Video Logo
    37 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
