Question about Samsung SGH-a737 Cellular Phone
Reset the T9 text dictionary
For some reason my t9 dictionary replaces some of my words with numbers and it gets annoying. I just want to know if there is a way to reset the dictionary for t9.
  • angbaby Apr 29, 2009
    I'm wanting to sell my cell phone but there are email addresses saved in the t9 dictionary. Reseting did not work. Any other suggestions?
  • Anonymous Mar 14, 2014
    when typing a text, the autocorrect changes the work. when I had a RAZR, I could tape the word and to dictionary. can't find this feature on this phone.
I ran into this problem as well, and it is extremely annoying. I just lived with it for the longest time and then I finally decided to go looking for a solution. That came to a quick end when I found the Samsung FAQ and it said that there is no way to delete words from the predictive dictionary. However, that got me thinking. If it's predictive, can I teach the predictive to write the correct word? The answer is YES! Open a blank text message, don't worry about a number just go to the text entry portion. Type out the word and press zero to change it to the correct word instead of the numbers. Do this 10-20 times IN A ROW and then the phone will recognize the right word as being most used and change it back to that.
Posted on Oct 10, 2008
How to add words to the t9 dictionary.
Adding words to your phone's T9 dictionary is quite simple.
If you have a newer model phone with newer versions of T9 when you try to enter a word that isn't recognized you should be presented with a prompt that says "Add word" or "Spell".
If you have an older version of T9 don't despair you can still add words. All you have to do in this case is: switch from T9 mode to "abc" mode and spell the word one letter at a time, hit the space key, then switch back to T9 mode. Whatever word you just spelled has now been added to your T9 dictionary.
Jul 24, 2011 | Cell Phones
Tip
Predictive Text on Samsung Soul
If you have accidentally saved a word into the T9 dictionary (ie, "IS" comes up with "47" or "Get" comes up with "HDU", you can teach the dictionary to revert back to the original word.
What you have to do is..... create a new text message, enter the text that is annoying, (ie, "IS"). When you type the word and it comes up with the annoying one, select the word that you wanted and enter a space, and do it again and again - you can do this in the same text message - it can take up to 20 goes but eventually, the dictionary recognises that you actually wanted "IS".
on Dec 08, 2008 | Samsung U900 Soul Cellular Phone
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
How do I delete auto text words from dictionery Samsung GT 8300
No, u cannot delete the auto text word from the build-in dictionary function name T9, but u can disable this auto text mode.
When open a new text message, just press the icon ABC to change the mode to ABC, T9 or number.
YBC (/\)
Oct 08, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Samsung SGH-c225 predictive text malfunction
Nov 13, 2008 | Samsung SGH-c225
Text
Nov 09, 2008 | Samsung U900 Soul Cellular Phone
Predictive text
I had this problem and it was very annoying. What you have to do is..... create a new text message, enter the text that is annoying (mine was is coming up as 47). When you type the word and it comes up with the annoying one, select the word that you wanted and enter a space, and do it again and again (you can do this in the same text message - it can take up to 20 goes and eventually, the dictionary recognises that you actually wanted "is".
Oct 04, 2008 | Samsung U900 Soul Cellular Phone
U 900 soul predictive text
Sep 23, 2008 | Samsung SGH-D900 Cellular Phone
The text dictionary keeps giving me the wrong words and i cant change, how do you knock it off. the phones a samsung d900i
Using T9 mode
T9 is a predictive text input mode that allows you to
key in any character using single keystrokes.
Entering a word in T9 mode
1. Press [2] to [9] to start entering a word. Press
each key once for each letter.
For example, press [4], [3], [5], [5], and [6] to
enter HELLO in T9 mode.
T9 predicts the word that you are typing, and it
may change with each key that you press.
2. Enter the whole word before editing or deleting
characters.
3. When the word displays correctly, go to step 4.
Otherwise, press [0] to display alternative word
choices for the keys that you have pressed.
For example, OF and ME use [6] and [3].
4. Press [ ] to insert a space and enter the next
word.
Other T9 mode operations
• Press [1] to enter periods or apostrophes
automatically.
• Press [ ] to change case. Lower case (No
indicator), Initial capital ( ), and Capital lock ( )
are available.
• Press [ ] to insert a space.
• Press the Navigation keys to move the cursor.
• Press [C] to delete characters one by one. Press
and hold [C] to clear the display.
Adding a new word to the T9 dictionary
This feature may not be available for some languages.
1. Enter the word that you want to add.
2. Press [0] to display alternative words for your key
presses. When there are no more alternative
words, Spell displays on the bottom line.
3. Press <Spell>.
4. Enter the word you want using ABC mode and
press <OK>.
"The faulty interface lies between the chair and the keyboard"
Apr 21, 2008 | Sony Ericsson w580i Cellular Phone
Need help on my lg kg800 chocolate phone
i think its factory defect or try to reset the factory setting///
Feb 03, 2008 | LG KG800 Cellular Phone
Samsung SGH-a737 Cellular Phone Logo
4,647 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
