Question about Timex 27191 Wristwatch
How to clean a twist-o-flex watchband - Timex 27191 Wristwatch
    Problem Solver:
  • 17 Answers
Dish soap and a toothbrush. You can clean it while stretching it. A cheap ultrasonic cleaner works great. You can buy a cheap ultrasonic cleaner at a drug store. You still have to stretch it to get in the tight spots.
Posted on Nov 19, 2008
  • 109 Answers
If you can take the band off the watch do it, if you can't that's ok you just have to be a little more careful. I take a 1/2 cup of HOT water, 1/4 cup of Mr. Clean, and 1/4 cup of ammonia. Hook you watch on a cup so it isn't able to slip into the cup, and let it sit for about 10 min. Take a tooth brush and spread open the links and brush away! Make sure after you brush it that you rinse off REALLY good because if you don't you will find that dust and whatever will stick to the band becuse it will be sticky because of the cleaner. If you find you have anymore problem please feel free to ask. I have been cleaning jewelry , watchbands, and watch cases likr this for twenty years , it works well.
Posted on Oct 27, 2008
Need the replacement strap for Timex watch M805
Timex Watchband - watchbands.com
www.watchbands.com/Departments/Timex-Watchbands.aspx
Original Timex® Replacement watchbands and straps designed to fit Casio, Seiko ... Currently the Timex bands we have are below. Leather Timex Watch Bands.
Jan 01, 2016 | Timex Watches
Removing wrist band
You can remove any watchband using a pocket knife trying to get between the back side of the band and the watch. Gently pry sideways until you see the spring-loaded end coming out. Flex the band back from the watch as you do this action.
Nov 28, 2013 | Fossil CH2332 Wrist Watch
I need an Ann Klein watchband replacement - model 10/9168 (has gold hardware in the band). Where can I go for this replacement?
You can just call 818-2496007 (in LA) and order any anne klein parts you need. For 10/9168 watchband, its price is about 22$.
Oct 19, 2012 | Anne Klein 10 6419SVTT 106419SVTT Watch
My fossil Stella clear watchband needs cleaning how do you get this clean?
Unfortunately it is a part of wear and tear of the that material. The longer you used it with an acidic sweat it will continue to discolor. Try washing it with mild soap and water after every used. That's also my problem before with my watch.
May 08, 2011 | Watches
How to shorten watchband
It all depends on the style of the band.
Go to where the links are all the same size, not tapered at all.
If you have a stretch band, along the edge, unbend the flaps that hold what look liks tiny staples. Pull out what you need removed and put the remailing pieces together.
If you have a non-stretch band, grab a SMALL paperclip about 1/8" from the end. Along the edge of the band you will see the pins that hold it together. Have someone hold the band with the bottom edge of the pin you are removing, over an opening. Between 2 hardback books wirks great. Tap the pliers to drive the pin partially out. Pull it out and do the same to remove as many links as needed. Put the pins back in, in the same direction they came out, from the same side they came out.
Dec 28, 2009 | Seiko Watches
Pin on the watchband is protruding
No need to buy a new watchband friend, you need a new pin. The spring inside the pin has lost its elasticity ... you won't spend a fortune ....
Please rate the resolution.
Mar 18, 2009 | Casio Pathfinder PAG60-1AV Watch
Seiko Watchband to long
Kept looking thru Google and found THIS site that seems to answer the question for MANY styles of METAL watchbands.
http://www.geocities.com/watch_crazy/index.htm
Dec 06, 2007 | Watches
Shorten watchband
I have a similar watch and removing the links are not easy. There are pins in certain links that have arrows on the inside of the band. I used a push pin to remove the pins in the direction of the arrows. Snip the end of the push pin with a wire cutter or pliers so that it fits into the hole and tap the top of the push pin with a small hammer until the other end of the pin is exposed enough to extract it with a set of needle nosed pliers. Repeat for other side of link. When the pin is extracted, twist the link inward and it should snap out.
Remove the link and reverse the procedure, placing the pin in the opposite direction as it was extracted. You may have to tap it gently with the push pin and hammer to get it to go into the holes flush.
It takes a little while and some patience, but if you can get someone to hold the band for you while you tap the pin, it will be easier. Also, if you remove the spring loaded pin from the band fastener so the band can be laid out straight, it will also be easier. Good luck!
Mar 30, 2007 | Timex Outdoor Casual Expedition®...
Timex 27191 Wristwatch Logo
390 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Geoff
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
