Question about Sony KV-32XBR85 TV
My matsui tv 28WNO5(A) will not turn on from standby
My Matsui tv model 28WNO5(A) will not turn on from standby
It suddenly went on standby and I have tried all tricks but it would not turn on.What do i do pls?
  • 2 more comments
  • mmijind2 Oct 04, 2008
    PLEASE I NEED SOMEONE TO HELP ME.I WAS USING MY SKY REMOTE CONTROL TO OPERATE MY MATSUI 28WNO5(A) TV MODEL BUT FOR SOME REASONS,IT WENT TO STANDBY AND I HAVE NOT BEEN ABLE TO SWITCH IT ON.I HAVE TRIED ALL TRICKS FROM UNPLUGGING TO RECODING THE TV WITH THE REMOTE CONTROL BUT NO SUCCESS.PLEASE HELP ME URGENTLY.
    THANKS.
    THE PROBLEM IS THE MATSUI 28WNO5(A) HAS ONLY ONE BUTTON ON IT WHICH IS THE POWER BUTTON.SO I CAN'T OPERATE IT WITHOUT THE REMOTE CONTROL.
    THANKS.
  • mmijind2 Oct 06, 2008
    My matsui 28wno5(A) TV has only one button on it which is the power button,so there are no other buttons i can use to disable the standby.
    No the tv only shows the red light of the standby when plugged but does not power on.
    Scholar:
  • 116 Answers
Try pressing the small reset button on the back, it works, and you will not loose any stored information which caused the unit to go in the stand by mode.
or
Have you tried turning it off for an hour and then turning it back on. This happens to me quite often and leaving it off for a while ususally allows it to come back on. Also have you tried to press the TV/AV button on the remote as sometimes it switches to TV mode when its on standby and then standby won't work as its on TV mode and needs to go back on to AV mode. Basically just press the AV button on the digibox remote and then try standby.
or
if the batteries are removed and left for about 20 minutes before being replaced again, everything works as it should.
or
if any of the above suggestions does not work then you have to open the unit and on the main board of the tv there is a thin mini tube light like component called fuse you will have to replace that fuse .the fuse is very very cheap and you can easily get it at any electronics shop.and if still the unit does not work then there is a major fault in the power supply board and should be taken to the service center for diagnosing the fault that it is repairable or not.but i hope the above information provided will definately help you to solve your problem.
Posted on Oct 06, 2008
  • 52 Answers
Un plug your sky decoder and tv for 30 min. First turn on the tv, to see what happen, if o.k. turn on the sky decoder. if that don´t work, see the sky control instructions, some time you have different setting in this controls to work the tv, the vhs, the dvd and the sky decoder and some time they have conflicts between them, so reset them and set them again.
regards
  • 1,879 Answers
Not sure if it is the TV or remote that is not working properly.
as part of isolating the issue:
1. have the SKY remote control replaced
or
2. grab a universal remote control (borrow or buy)
  • Sony Master
  • 19,396 Answers
If the TV does not turn on, it can have an internal fault.
When the TV main chip detects a problem, like a faulty component on tv board, it will prevent TV from switching on, and the unit will stay in standby mode. When this happen it is said that the tv is in protect mode.
First ensure that the TV is really in protect mode, replacing remote batteries, and if possible trying to turning it on with the buttons on TV.
If the remote is faulty get a replacement remote here.
If it does not depend on the remote, and the tv is in protect mode, try unplugging tv power cord for one hour or so.
If this does not work it means the tv is faulty, call the number listed on the user manual to have it repaired.
  • 535 Answers
Try to reset on factory setting if problem occurs then u have to open your ckt bord chak the capacitor
Posted on Oct 04, 2008
    Genius:
  • 1,550 Answers
Is your TV functioning normally using the buttons on the front of the set itself. If the TV will not power on with the power button on the set itself, then something is wrong inside the TV. If the set works fine from the front buttons but no longer responds to that remote, then the remote has gone bad you need to go through manual for remote to set it back to normal .
    Genius:
  • 1,268 Answers
Try to remove the battery of your remote for few minutes. On your TV, there's a combination of button which you can use to reset the menu by pressing them simultaneously and from there, you can disable the standby. Another thing is you can use a different remote like universal remote to control the TV.
    Genius:
  • 1,011 Answers
Sir,
It is fault which turned out to be Power Unit Capacitor C315 1000mFd 25volt, rated at 85 degrees centigrade. Its mounted near the heat sink. Look for a slightly domed top of capacitor C315 aluminium case. It should be absolutely flat.
Usual safety rules should be followed. In addition disconnect from the mains while working on the power panel. Give the large electrolytic capacitors time to discharge.
or else try this step.......
unplug it for 5 or 6 hours. Also try with remote control / read manual
thanks
good luck
Matsui tv stuck in standby
Look what category you are in.
Mar 15, 2014 | Sony MDS-JE330 Mini Disc Player
Ho do I retune my matsui M19dvdb19
Go to the Matsui website. They should have a free PDF manual of your model (have the model number handy).
Feb 24, 2014 | Sharp Televison & Video
Matsui Radio Alarm CDCR200 set the clock time, lost instructions
Hold CLOCK SET button down, press HOURS and MINUTES until you get the right time, release CLOCK SET button. This radio alarm unhelpful calls the ON/OFF button "STANDBY"! To turn it on, press the STANDBY button so the standby light is on!
Feb 21, 2010 | Audio Players & Recorders
Matsui TV/DVD MAT15LI618D DVD unlock
where can i get a power supply lead for my matsui 15in tv/dvd player
Jun 09, 2009 | Radio Shack Accurian APD-3955
UNABLE TO VIEW ITV CHANNEL 4 OR SKY SPORTS NEWS ON MATSUI TV
try tuning tv in another room, if it works it is then your cable or socket, try the cable next. If it wont tune its a faulty set.
May 26, 2009 | One For All URC-3445 Remote Control
My Matsui TV is a fairly old model and it does not have the buttons where you change the volume etc. My remote control has stopped working therefore I cannot turn my TV on. I have bought a universal remote...
matsui tv's are usually clones of another make set so you might be able to trace another remote ..try rs components for an original replacement.try switching on using the station up button...farr64
Apr 29, 2009 | Televison & Video
Matsui tv assistance
Have just read up on this. It seems you have to hold the - volume on the front of the TV at the same time as the no 7 on the remote for 5 secs to reset the PIN number.
Sep 30, 2008 | Televison & Video
Televison & Video Logo
1,478 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
