Question about GE Dishwashers
Dishwasher problem Model number GSD2200LO1
My brother broke my parents' dishwasher!!
He pushed the start button and at some poing found that it was set on the heated drying option. He pushed the energy saver button without first touching the clear/reset button. Now the dishwasher won't start. It makes no noise, nothing.
thanks for any help you can give.
marcia@cebridge.net
  • 1,543 Answers
No, he didn't do anything wrong. Swithching to energy saver setting only prevents power from going to the heating element during the drying portion of the cycle. I suspect that you have no power going to the dishwasher. Check the household breaker for the dishwasher. If that is not tripped (probably not) then your dishwasher power may be supplied through a GFI (ground fault interupter) protected outlet which has tripped. Look around the kitchen for GFI recepticles, as there may be several. Power may even be fed from a GFI from another room, such as a bathroom. Push the reset on all GFI recepticles you can find. You can purchase a small pen sized tester for under $20 which will show if a wire is carrying power without even thouching an actual wire. Pick one up at a hardware store to help see if power is reaching your dishwasher if you need more help.
Posted on Sep 26, 2008
Replaced the control board in my whirlpool dishwasher model# WDT790SLYM1 and the push panel lights up but when I push the start button all lights go out and the dishwasher will not start.
Hello, We're sorry to hear about your Dishwasher. We recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Dishwasher. If you are in need of help after trying the reset, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 14, 2017 | Whirlpool Dishwashers
The dishwasher is displaying 5H in the time panel is there any way that could happen by pushing the wrong button and is there any way to make it go away
It would help to know the model number to determine the features of your dishwasher. The only guess I can make is that someone pushed the "delay" button and you are now set for a 5 hour delay for starting the dishwasher. Pressing the Delay button a few more times should bring it back to Zero delay.
Feb 28, 2015 | GE Dishwashers
Regency problems
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Touchpad
If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board
The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been ruled out, the main control board might need to be replaced.
Jun 14, 2013 | Maytag Dishwashers
My dishwasher will not start the heated dry light flashes constantly
Hello Daneil, we're sorry to hear about your Dishwasher. We recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Dishwasher. If you are in need of help after trying the reset, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 13, 2017 | Whirlpool 24 in. DP940PWP Free-standing...
Dishwasher won't start, lights on panel just all flash when I push the start button
need the full model number of the dishwasher.
Most likely it is a heater fault or door lock switch is not engaging when you shut.
Feb 11, 2011 | Kenmore Dishwashers
I changed the handel and switch assembly on my dishwasher because the old one was broke.The dishwasher does not turn on. It still doesn't work. it doesnt even light up. although one button does glow a...
check for line voltage at the door switches and from there to the control board thats to the right of the door latch switches for line voltage,if you have line voltages in all these areas then replace the front membrane push button control panel that connects to the control board
Jan 31, 2011 | Maytag MDB9600A Jetclean II Built-in...
It seems when I pushe button to start nothing
Some fault in the dishwasher is causing it to believe the door is not locked.
I would check the door lock.
check this youtube video out for the location of the door switch.
http://www.youtube.com/watch?v=2CqFZ-Ud0nE&feature=related
(quality of video may not be the best but gives an idea of its location).
If you can give me the exact model number I can find out more details of the problem you are having.
May 12, 2010 | Frigidaire Professional Series 24 in....
Kitchenaide builtin - take 20-30 pushes on start button
change the controls you can get at loocal appliance shop take model number when you go
Feb 17, 2009 | KitchenAid 34 in. KUDP01FLSS Stainless...
Frigidaire Dishwasher Energy Star blinking lights.
Hmmm...don't know why this worked, but it did. When the lights were flashing when I tried to start my Frigidaire dishwasher model#FDB1500LF, nothing would happen...just blinking lights, so I went to the house electrical panel, found the switch for the dishwasher, turned off & on again, and now the dishwasher works.
Go figure.
Feb 16, 2009 | Frigidaire 24 in. PLD2560LCC Energy...
Open Questions:
Dishwashers Logo
123 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
