Question about IBM ThinkPad A21m 2628 Notebook
I got the discs as you instructed.
I downloaded the Bios from Lenova (spsda21m) but no Flash so I went to Bootdisc and they had one. What would you recommend from here?
Thanks
  • Stephen Sep 27, 2008
    Thanks for your response, I hope all this works.
  • Stephen Sep 28, 2008
    http://www-307.ibm.com/pc/support/site.w...
    This is the site where I got the bios (1999 version) but did not see a Flash. I found a Flash on Bootdisc that I hope will work. The instructions on the IBM site did not work the first time I tried, it won't recognize the floppy. It won't even recognize a Win 98 Start Up Disc.I'm Stuck!
    Hope you know something, otherwise it will have to go into a shop. IBM wants more to fix it than it's worth.
    Stephen
    Brigadier General:
  • 5,158 Answers
I'll look for the maker of your bios later today to find the flash utility.... boot disc has the program to make a bios update disc which is what you want. sorry about the delay as i have some prior commitments i have to look after.
Take care
Posted on Sep 26, 2008
  • Roberta Smith
    Roberta Smith Sep 28, 2008
    admittedly i have lost track of the assistance i've given you so far.... it's necessary to know the bios maker so you can get the correct flash utility. did you find one as i have not had a chance to look yet. if you are getting the bios from the manufactuers website it should also have the flash utility for download or tell you which to use.
    Robert
Accidental erase of os without bootdisc of windows 8 toshiba satelite C55-A
If you can boot from CDrom or floppy, you may be able to restore the partition information using a DOS utility. Easus has a program you can download and write to CD (given you have another machine) and use that to boot the machine and restore the partitions. Unless you went hog-wild in erasing, everything is still there and recoverable. Well, almost everything. There are other programs, such as those on sourceforge.net, that can restore erased partitions and others that can restore erased files.
If you have the OS CD, or DVD from Toshiba, boot that... If there was a hidden 'restore' partition, you may be able to access them from BIOS.
Aug 15, 2014 | Toshiba Satellite Computers & Internet
Can not burn photo's from lenova 510 onto a dvd disc
Better do it using special software, for example you can download on torrent NERO software (write in google - NERO torrent) this software is easy to use, try it and if you have more questions - feel free to ask...
Nov 15, 2012 | Lenovo IdeaPad Y510 - Intel Core 2 Duo...
I can't find the bios flash instructions .how do you flash the bios on my toshiba a35s159
You should check the Toshiba WEB site for instructions to how to upgrade (flash) your BIOS, if you make a mistake you may not be able to repair or recover from your mistake.
I have done BIOS upgrades on a few computers.
If your Toshiba has a floppy drive and you can boot up from this floppy drive then the BIOS upgrade needs to be downloaded to a boot floppy. Then boot up from this floppy and run the BIOS upgrade program. When completed, remove the floppy disk and boot up your laptop.
YOU MUST CHECK THE TOSHIBA WEB SITE AS THESE INSTRUCTION MAY NOT BE APPLICABLE FOR YOUR TOSHIBA LAPTOP.
Jun 02, 2012 | Toshiba Computers & Internet
How to update bios
You have to do what is called Flash the Bios. Read the Manual. Also there might be instructions when you download the Bios driver below on how to flash the bios.
Get onlineand got to www.google.com In the google search box type: "ASUSSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the BIOS drivers.
May 14, 2012 | Computers & Internet
I have a HP Pavilion dv6-3120us Entertainment Notebook. A update came from HP for the BIOS and while installing the update, it will not finish. Its frozen at 100% can you assist?
your options are wait for it to complete. Or power cycle it and hops it froze on downloading, and not during installing.
Manually download the bios update yourself and then flash it manually if it does come back up.
If the computer fails to boot up then you will need to use a recovery bootdisc and then to apply the bios update again manually as opposed to doing it in windows.
May 25, 2011 | HP Computers & Internet
CMOS BATTERY LOW CMOS SETTINGS WRONG CMOS MEMORY SIZE WRONG. I was getting that error, and then i went and brought a brand new battery, the CR 2032, the same that came after...After i booted it up, went...
  1. here are the instructions to Flash Your BIOS -
don't forget to read the information that's included and related to flashing in your motherboard's manual. Yes, dig that manual out (or if you can't find it then download it from the manufacturer's website; it's usually available) and read it!
Four of the most common flashers are: AWDFLASH, AMIFLASH, UNIFLASH and AFUDOS (only for ASUS boards). Out of these the UNIFLASH (get it here) is the universal flasher that can usually flash every BIOS; it has awesome compatibility capabilities. Keep in mind that BIOS flashing can be (and is) dangerous, because in the case of a bad flash the data ends up corrupted and your computer won't POST anymore. So I'm recommending wholeheartedly that you use the BIOS flasher that's explained in the manual and provided by the manufacturer of your board. Read the manual, do your research and when you're ready, then and only then proceed to follow the instructions.
After you get your flasher you need the latest BIOS flash file. First find out your motherboard manufacturer's name and your board's exact name and specifications. Visit your manufacturer's website and download the latest non-beta version (betas can be risky and I don't suggest you experiment if you can't fix it if a bad flash happens; we'll discuss that a bit later). These files usually have ".ROM" or ".BIN" extensions. Later on I'm going to call the "latest BIOS file" "newbios.bin."
I'm going to give you examples of how to use UNIFLASH, AWDFLASH, AMIFLASH and AFUDOS. Read them strictly as examples and do not proceed to flash your latest BIOS version before you understand what each option gives and how to use these flashers.
Flashing with UNIFLASH:
A:uniflash.exe newbios.bin
Flashing with AWDFLASH:
A:awdflash.exe newbios.bin /py /sn /cc
Flashing with AMIFLASH:
A:amiflash.exe newbios.bin /A+ /-B /-C /-D /E /-G /I /L /N /R /V
Flashing with AFUDOS:
A:afudos.exe /inewbios.bin
Even though the above commands do work it's always crucial that you read what every command does and understand them. First of all, once you're booted into MS-DOS, execute the flashers without commands and options. Just use a simple "awdflash.exe" or "amiflash.exe"-- then a help screen (which explains all of the available commands and options) will appear. Read that thoroughly before proceeding and follow the instructions.
As a side note, UNIFLASH has a UI (user interface) so it definitely helps beginners. Execute the "uniflash.exe" and the UI will appear and guide you through.
please dont forget to read precautions here
http://www.devhardware.com/c/a/Hardware-Guides/Why-and-How-to-Flash-Your-BIOS/2/
Mar 07, 2010 | Computers & Internet
Manually flashing a Dell XPS 1330..
Ok when you use the BIOS software to re-flash the BIOS THAT file will already be BINARY code. You make a bootable disc, on this disc you have the BIOS Reader/Flasher, and the Binary file to be Flashed. Now you boot up on the disc. When at the prompt, you type in the name of the Flasher, and the binary file name & press enter, if all OK the software wil address the BIOS and re-flash it with the new data. when finished you will reboot and now, hopefully you are back. The BIOS file will be available from DELL's web site usually where the Driver downloads are ... or you could go here I found it for you. http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R178150&SystemID=XPS_M1330&servicetag=&os=WLH&osl=en&deviceid=14178&devlib=0&typecnt=0&vercnt=4&catid=-1&impid=-1&formatcnt=1&libid=1&fileid=242504
Also on that page there is exact installation instructions too. GL
Feb 18, 2010 | Dell XPS M1330 Notebook
How format my comuter
well insert the bootable cd and follow the on screen instruction
Thanks! Sandy
May 09, 2009 | PC Chips M938 (M938ALU3.1/CNR) Motherboard
Need large disc support for old emachine, flash bios? or try restore cds?
flashing a bios, can render your machine/motherboard useless.
You should always ensure any bios download is from a trusted source. if you experience a power failure, or an incomplete bios file. your computers as good as dead.
Windows 95/98 only supports disk drives to a certain capacity. if you updated to windows 2000/ME/XP your problems may be solved. I,d certainly try that first.
Bios flashing Last resort, even after finding a reliable bios update. also ensure the bios file is 256mb-512mb or equivalent. as this is standard bios file size.
Finally check that your hard-drive does not have a jumper ( Small white/black ) plastic block restricting the drives registered size.
When you install windows XP, it will ask you if you wish to enable LBA ( large block Allocation ) Select Y ( yes )
Mike @ compurepair.
Mar 12, 2008 | E-Machines eMachines Desktop PC
Bios flash
This is something that I really would not recommend doing unless you are sure what you are doing as this can seriously harm the computer. The best suggestion is to contact the sony help online and send them your product number and serial number then they know what flash bios you have and can send you a link to the correct download. Through experience when I tried to do a flash bios upgrade my computer went dead until I opened the back and had to shock the dumb thing.
Jan 08, 2008 | Sony VAIO PCG-K23 Notebook
IBM ThinkPad A21m 2628 Notebook Logo
44 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
