Question about iLO (2 GB) MP3 Player
Cannot download I have a 2gb ilo when i plug the usb into the mp3 nothing happens. i also have a 1gb ilo that i can use either usb cable and it downloads fine. my 2gb is not responding to the usb at all.
  • 8,596 Answers
Make sure the lock/hold is not engaged
"Firmware Upgrade" (provided by jwmgotee):
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.)
Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible.
Download the correct Firmware
Click here ( to download the ILO 116 Firmware
Click Open to initiate the download
Double click on the ILO or Siren folder icon. There will be 14 icons.
There will be a Setup icon that looks like a box with a blue line on it; please double click on this.
Then click Run - this will open the Install Wizard.
The Install Wizard has the instructions on the screen as you go through it.
Once the firmware has installed, please click the Start menu, then Programs.
Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware.
It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start".
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
"Found new Hardware 'SMTP3500".
-Tha Mp3 Doctor
Posted on Sep 27, 2008
My USB cable can't be read
Upgrade the firmware by downloading the latest version of the Philips Device Manager from and clicking on the Update tab.
-Tha Mp3 Doctor
Jan 21, 2009 | Philips SA3025/37 Flash MP3 Player
Ilo mp3 player
First check your USB cable for cuts or invisible breaks,its better you replaced a new one.If nothing happens just take out batteries and leave it for 3 hours and put it back again and try to check if it's working.If still not working then do some reset procedure..
To reset the MP3 press and hold both Menu and Select (center button) for about 5 or 10 seconds. If the Ipod is alive this will reset it
Hope this may help you;
Sep 06, 2008 | iLO (2 GB) MP3 Player
Ilo 2gb mp3 player
the computer has not have the right thing to play your iLO. I would look at the owners manuler and see what your computer needs or inserted the iLO CD
Mar 30, 2008 | iLO (2 GB) MP3 Player
I cant download songs
download music to mp3
Jan 31, 2008 | iLO (2 GB) MP3 Player
Innovage mp3 wma 1gb format error
plug in your iLO and go to "start" at the bottom of your screen and go to My Computer then go to Removable Disk and right click. Then go to format
Dec 20, 2007 | iLO (2 GB) MP3 Player
Cant find usb port on mp3 player
if you got it new it would have come in a box with the usb cable (pc to MP3). Plug cable into bottom of mp3 and usb end into your PC. This will charge it up
Nov 13, 2007 | Audio Players & Recorders
Computer doesn't recognize player
Could be faulty usb port or cable try other computers/ports/cable
Aug 31, 2007 | iLO (2 GB) MP3 Player
Computer locks up everytime I connect my USB cable into the MP3 ilo 2GB player.
Take it back to WalMart and get another one. This is broken.
Jun 26, 2007 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
107 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
