Question about JVC AV-48WP30 48" Rear Projection Television
Blurry shadows in red and teal.
Characters on picture look double and the colors red and teal are dominant on the screen. I tried to adjust the convergence menu but the bottom left red cross will not overlap the green. It will not move left or right only up and down. Also the red cross in the upper right hand corner will not overlap. It will not move left or right. Please let me knpw if I can fix this myself or what needs to be done. Thanks for your help.
  • Anonymous Sep 26, 2008
    I'm having the exact same problem. Blurry shadows in red and teal. my problem in more on the right side. HELP!!!
  • 2,071 Answers
Just click below for convergence repair kit;
Picture look double and the colors red come out the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Posted on Sep 25, 2008
I have a 55" rear
U tries go into the tv colors setup and turn down the color RED,might help?Tv could have a problems known a convergence problems,it dead very common problems for old DLP tvs.The tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board.The tv convergence board require changes 2 STK convergence ICS and some or all of it resitors too.For fixing the convergence board to solved convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 08, 2011 | Hitachi Televison & Video
On left half of the screen [ KP51WS510 ], a redish shadow showing
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
Apr 07, 2010 | Sony KP-51WS500 51" Rear Projection...
Characters on picture look double and colors not lined up
HI, the convergence board or unit is failing at this point. you will need to replace the entire board in this case. most of the components are damaged.
The convergence board is the main regulator of the RGB stream. it also controls color focus as well. replace the convergence board asap.
Jul 22, 2009 | JVC AV-48WP30 48" Rear Projection...
Color adjust
Adjusting the picture tubes is a scary proposition, but since you have already done it...
The easiest way to balance the gray scale is to turn the color all the way down on the set. The next part is easier with two people if the screen controls are on the back of the set. This is the part you saw that has six small knobs on it. There are control for the focus of the red, gree and blue and for the screen level of the red, green and blue. You will want to adjust the screen controls in an effort to get the picture black and white (this is why you turn the color down), hence the term "gray scale". Just make slight adjustments, take your and be patient. It will take some time, but you will get your picture balanced back out in time.
Hope this helps!
Jan 15, 2009 | Philips 50P8341 50" Rear Projection...
Rca d61w20 dominate red & blue screen also very blurry picture
Red and blue present, but no green = bad green CRT is
best guess.Remove lower front panel = adjust screen and focus
controls for best pix..................T.
Oct 30, 2007 | RCA P52926 52" Rear Projection Television
Has a shadow on picture. Red, Green is not alligned
You need to set your convergence. Check your owner's manual on how to do it. I'm not sure the exact procedure on that model, but usually you can find it in the setup menu of the tv. What you're trying to do is line the red and the blue up perfectly with the green so that they all blend together to give you one picture.
Oct 20, 2007 | Hitachi 61UWX10B 61" Rear Projection...
HCL4715W Rear projection blurry
The focus controls on this set are in the front behind the bezel. I'm not sure, but, I think on this age of Samsung, the screws to the front bezel are on the back side of the set. After removing the screws from the back, the front bezel snaps off and the door behind the bezel need to be removed. Watch the wires connected to the bezel, they need to be attached in order to turn on the set. The focus controls are on a black control block (there are three of them, one for each color). Adjust each color for sharpest picture. I use words on the screen for alignment. Each CRT board has a screen control (Adjust each slowly until retrace lines appear on the screen and then back off until they disappear). You may turn off the color and make sure that the picture is black and white. If it is not, then, which ever color is dominant, back it off a bit with that screen control. Facing the set, Red is left, Green is middle and Blue is on the right. Use only one hand inside an operating television. Do not touch the board, just the controls. This concludes television alignment 101. Any questions respond to this post and I'll reply.
Aug 26, 2007 | Samsung HCL4715W 47" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
226 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
