Question about Oreck XL Ultra Bagged Upright Vacuum
My Oreck's roller won't turn
Changed the bag, belt is new. Now won't pick up anything and smells like something is burning. I have three dogs and the Oreck is not for pet-owners I have discovered. (cut all the hair from the roller btw)
  • Anonymous Sep 27, 2008
    I have the same problem
3 Suggested Answers
SOURCE: burning smell
I had burning smell and some visible smoke which I tracked down to the handle area. The mains socket at the bottom of the handle had burned out. When I pulled the plug out I noticed that the prongs were blackened and scorched. I will replace the socket.
Posted on Jan 05, 2009
  • 85 Answers
SOURCE: Oreck XL intellashield smells hot and smoky when
If it smells like burning rubber with white smoke its the belt make sure the brush spins freely. If its a electrical burning it will smell real bad you WILL be able to tell which then its a motor issue you can remove the bottom plate 5 phillips head screws opposite the motor youll see 1 screw remove it pry the duct out and look to see if there's anything stuck in the fan if not its the motor its self
Posted on Dec 17, 2009
Just replaced the roller on my oreck XL, and it is smelling like burnt rubber
If the roller bearings are starting to seize the the belt may be slipping
Oct 25, 2012 | Oreck XL Ultra Bagged Upright Vacuum
MOTOR RUNS WITH NO VACUUM PRESSURE
Sounds like the belt should be replaced. It maybe turning the brush, but if you smell burning rubber, its slipping and not turning the brush with as much force as it should. Changed the belt. Check the air suction path. If the suction is reduced, something is blocking it. Check the bag (if it has one) and all filters. If the machine picks up any liquid, it will reduce the air flow through the filters and bag. Change the bag and filters. If this is an upright, you may find caked on dirt under or in the area of the brush.
Nov 28, 2011 | Hoover Vacuums
Oreck XL intellashield smells hot and smoky when operating. New bag and belt and no clogs. About a year old.
Dec 17, 2009 | Oreck XL Ultra Bagged Upright Vacuum
My Oreck Vacuum cleaner keeps burning up belts. I
I am having the same trouble. I bought the vacuum new in October 2007 when my wife and I purchased a newly constructed home. Since it is only two of us, she only has to vacuum once a month. I have taken it in three different times and get the same story. It needed a new belt. Mine has white smoke coming out of it and smells like burning rubber. I contacted Oreck and got no results. They refused to let me discuss this with Dave Oreck, stating that he nevers talks with customers! Gary Neeble
Jun 05, 2009 | Oreck XL2000 Bagged Upright Vacuum
My Oreck XL was working fine, then when I vacuumed a shag rug is started smoking and smelled like something is burning. (I changed the bag, checked for clogs--none found, and roller brush is turning. It...
Even though the brush is spinning, the belt is probably worn out and stretched. when you vacuum the shag carpet, it puts more drag on the brush. try running it on a shorter carpet or hard floor for a few minutes. if it doesn't smoke, then you know it's your belt. if it does smoke, then it's probably the motor burning up.
Jim
Jun 02, 2009 | Oreck XL2000 Bagged Upright Vacuum
Burning smell
Nov 02, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Burning smell and not picking up
check for blockabe in bag inlet area, or bottom of unit by intake pivot.
ez check is to feel if bag blows firmly up with air when on, if not, you have a blockage.
Nov 02, 2008 | Oreck XL21 Bagged Upright Vacuum
Oreck Vacuum Cleaner problem (upright)
The best solution to any Oreck vacuum problem is to replace it with another brand. You are going to continue having problems with the Oreck..Not that other brands don't have problems. But, at least with
other brands the problems don't occur as often. Belt burning up. clogs, roller brush bristle wearing down prematurely, cord breaking internally, etc.
P.S. Oreck is good at one thing. Marketing!
Aug 30, 2007 | Oreck XL2200 Bagged Upright Vacuum
Oreck XL Ultra Bagged Upright Vacuum Logo
487 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
