Question about Lexmark Office Equipment & Supplies
Left cartdrige missing - Lexmark Office Equipment & Supplies
    Guru:
  • 558 Answers
Is the printer running Ok?
Please install the new one and let me know if the error still persists.
Regards
Ellin
Posted on Sep 26, 2008
Color not good after typing especially red
Usually these machines have independent cartdriges for main colors, which could mean that one of the cartdriges are used. Shut down the printer, unplug it, open the front cover and gently pull back the cartdriges and give em a good shake, be careful, sometimes there is some residual toner coming out, dont breath it in it can be harmful to your lungs. Put them in the same order back and close lid, plug back the printer and give it a check.
If its not working use the printers utillity check for level of toner on your printer or just the Maintenance tab.
Jun 29, 2011 | HP Color LaserJet 2600n Printer
My canon mp210 wont let me scan. i have done it before but it is not working now. is it broken? is it fixable? is it a diy? help please.
What error number is show on printer display? May be a software problem, try to reinstall the printer software. If a ink cartdrige is missing or malfunction all the printer function (including scanner) is unusable, you need to replace the broken cartdrige!
May 14, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Error message "no ink cartdrige"
reseat the ink cartdrige
ink cartdrige is bad or malfunction, replace the ink cartdrige
May 14, 2011 | Office Equipment & Supplies
Print cartdrige missing or not detected :S please help
Attempt removing your printer from the printer lists on your computer and add it again. Then try to turn the computer off and turn it back on. Connect all the cables and reconnect it. Good Luck
May 04, 2011 | HP Office Equipment & Supplies
Printer wouldn't work - said cartridge jammed - I took coloured one out - can't now get it back and the other one will not go into middle of printer for me to but the one back into position
Hi Good daY!!! Check your printer if there is something that block your print head. after that turn off your printer and then move the cartridge into the center and then remove the ink cartdriges. after that turn on your printer without the ink cartridges, now your printer will recognize that your ink cartdriges is missing after that insert the ink (insert it properly) and then see if your printer would work now.
Thank you for using FixYa
Please accept if my solution helps you
Nov 14, 2010 | Dell 924 All-in-One InkJet Printer
My black ink ran out so I replaced the ink
Hi:
I have used the printer series that you have for years, and once in awhile, I get a new cartridge that won't immediately print. Often, there is just a bit of dried ink residue on the print head, and that won't allow the cartridge to work correctly.
Some simple things to try are :
1) Remove the black cartridge. and take a damp paper towel and gently swab the print head area. Next, apply some pressure to the sides of the black cartridge, until you see black ink oozing out of the print head. Repeat if needed. Once the ink starts flowing, blot off the excess, and install the cartridge.
If you can't get ink to flow, then the cartridge might be bad. Most of them have an expiration date on the packaging.
Mar 31, 2010 | HP DeskJet 960c InkJet Printer
The cartdrige case is blocked on the right side of the printer and it does not move
Open the cartdrige door and remove the cartdrige from there and then place it gently, it may happen because the cartdrige is not placed properly in the printer.
Feb 25, 2010 | HP OfficeJet R80xi All-In-One InkJet...
My printer is not printing..page comes out blank. inside, all the lights are flashing on the ink cartridges...any ideas what's wrong? thanks
this message means that the cartdriges are empty...
if you have bought new cardridges and lights still flash then the printer just dont recognize them right.
possible cause 1:
dirty cartdrige (or printhead) chip contacts > clean them with alcohol and cotton (switch printer off first).
see the chips in this photo:
https://secure.datatekusa.com/images/canon%20PGI5.CLI8%20refillable%20cartridge.jpg
possible cause 2:
bad printer controller: the chip in the printer that communicates with the cartdriges is gone mad... take the printer to service...
all the above are valid assuming you bought original cartdriges if not then do so...
Sep 03, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
HP Photosmart 3110 All in One says ink cartdriges missing
Follow the instructions in this link.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00409514&prodTypeId=18972&prodSeriesId=3380537
May 18, 2009 | HP OfficeJet J4580 All-In-One Laser...
AKG Model C451 EB Microphone.
I drilled a tiny hole (.038") through the outer shell and the cartdrige where the body of the XLR connector is mounted and screwed a tiny screw into it from a pair of old glasses.
Sep 29, 2008 | AKG (WMS40DIV444US54) Microphone
18 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
