Question about Sharp AL 1631 Copier
Drum and Toner al-1631
Would you happen to know how to reset this machine to accept my non oem drum and toner? Thanks in advance - Ian Tufts
  • ian78 Sep 26, 2008
    Thanks you very much for the prompt support. It's much appreciated. - Ian
    President:
  • 2,072 Answers
If you add the toner, there is a chip on the back of the toner cartridge that has to be relplaced.
With the drum, you take off the front green cover. There is a set of gears in there. One of them has a flag like tab sticking out of a segmented gear. You have to get the gears and flag set so that the the flag is up and to the right. It will then make one swipe pass the drum replacement switch and reset the counter.
Posted on Sep 26, 2008
  • Rick Kasper Sep 26, 2008
    You are welcome. Glad to help.
  • Rick Kasper Sep 30, 2008
    Your welcome
Toner cartridge spreads toner all over inside
If the toner cartridge is dumping toner it is defective and needs to be replaced.
Dec 08, 2014 | Sharp AL-1631 Drum Unit - 18000 Pages...
I do I remove the old drum in a sharp AL 1631 copier?
You have to open the door on the right side of the machine first, then you can open the front door. Remove the toner cartridge and then you can remove the drum unit.
Jun 02, 2011 | Sharp AL 1631 Copier
Sharp AL 1631 Grayscale Copier Placement of Shutter Film strip
you may have removed the toner receiver strip.you have to removed the drum from the assembly.you can remedy that with .5 inch masking tape.
Jun 09, 2009 | Sharp AL 1631 Copier
Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Nov 05, 2008 | Sharp AL 1631 Copier
Brother MFC-7820N Drum Reset
There is no clear buttom as mention abovee.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Nov 03, 2008 | Office Equipment & Supplies
Won't copy anything now.
the "screen" is actually called a grid, it is supposed to be on a unnit called the "primary" which sits on top of the drum (long silver unit) it may have a screw holding it. It must have been serviced or someone touched it, does not come off by-itself, anyway, it distributes the charge of the primary to the drum.
So look for a unit that sits directly on top of the drum unit and is the same lenght as the drum
Hope this helps (please rate. TNX)
Oct 02, 2008 | Sharp AL 1631 Copier
Sharp AL-1631 - would not copy.
Your unit definetly needs a new drum. The usual yield for this consumable is upt ot 15,000 pages, so at the stated rate, the unit yielded more than average. AL-1000 series share the same toner and drum, so finding remanufactured (or recycled) drum units should be no problem. In Puerto Rico, they are sold for about $79.00.
Oct 05, 2007 | Sharp AL 1631 Copier
Leaking toner
Make absolutely sure you are using new OEM Sharp supplies for this machine. I sell OEM and generic, and I always have trouble with generics leaking in Sharp copiers. Also if the drum unit has toner backed up in the waste channel, it will leak out.
Apr 04, 2007 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
118 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
