Question about Dell Inspiron 5160 Notebook
Inspiron 5160 screen is blank
I can power up the laptop with or without the power cord and i hear all the fans come on and under a bright light i can see where the Windows introduction is on the screen and where it prompts me for the password. Someone told me to take out the RAM chips and put them back in and reboot the laptop. Did that, now it will not stay on with battery power or AC power cord.
  • coconutt21 Sep 25, 2008
    Hopefully the problem will be resolved
    Problem Solver:
  • 7 Answers
It seems to me the LCD cable is either not properly unplugged or LCD ha gone bad.
Connect external monitor to the laptop and check if you have the Video on the external monior. If everything looks fine on external monitor then you can get the LCD replaced.
In case system does not power up and there are no indications of power.
Here are the steps:
Connect only the AC Adapter and take the battery out.
Check if you have a green led lit on the AC Adapter.
If AC Adapter does not has a green led please replace it with a known good AC Adapter.
If the AC Adapter has a green led but still no power it can be the system board which has gone bad.
Posted on Sep 25, 2008
Dell Inspiron 5160. When plugged in then power light lights up (before hitting the power button like my 5150) and the battery light is amber. The 5160 will not do anything - not power on at all.
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
May 26, 2011 | Dell Inspiron 5160 Notebook
Dell inspiron 5160 is dim.
This problem can also be due to the corruption of display drivers// assuming that you have checked the contrast and brightness do this step:- goto device manager// click on the display adaptar + sign and on the pop-up driver right click and select uninstall//
once the driver is uninstalled then restart the computer and check//
if that doesnot work then you can also upgrage the grafic card by going to the web site// even if this doesnot work then 100% the problem is with the notebook screen// contact best buy or wallmart or the retail store from where you have bought the notebook//
Jul 01, 2010 | Dell Inspiron 5160 Notebook
Dell 5160 Won't start up or charge battery
I have the dell inspiron 5160 works great a little slow but no big deal. The problem I have as of Monday the power cord will not stay in and now will not charge. Is it the power port? Can this be fixed?
Jun 27, 2009 | Dell Inspiron 5160 Notebook
Dell laptop screen goes blank when ac adapter plugged in
I believe I have found the problem with the 1525 that I am currently working on which has the same problem that you describe. Ultimately I think it's a problem with the inverter in the LCD. When the laptop is powered by battery the brightness is lower than full. When I plug in the power adapter the brightness goes to "full" and I hear a faint sizzle and the LCD's backlight goes off. Same as if you hold the Fn key and press the up arrow to brighten it, it will do the same thing when you reach near the full brightness. So for now I have fixed this problem by going in the Power Options and clicked on Adjust the display brightness on the left. Slide the slider to the left on the "plugged in" part and now when you plug it in it shouldn't make it go blank. I do want to note that I hear a faint buzz coming from the LCD when I plug it in. That must mean the inverter is faulty. WAY TO GO DELL!!!!!!
May 23, 2009 | Dell Inspiron 1525 Laptop
Need to unlock Dell Inspiron 5160. Power is on, screen is blank
Hold down the power button for about 10 seconds untill it powers down and restart entering the correct password..
May 18, 2009 | Dell Inspiron 5160 Notebook
Dell inspiron 5160 wont start
It sounds to me like your Laptop over heated... I cannot be for sure But I would get your Motherboard check because it sounds like its shot.
Mar 18, 2009 | Dell Inspiron 5160 Notebook
Dell computer won't start up.
if you have 2 memory sticks, (i.e. 2 ram sticks that are 2 gb each) try putting on in and start it.  if it does not work try this.
remove all power supplies (cord and battery).   hold down the power button for 30-60 sec.   after that plug the power in and try turning it on.
Mar 09, 2009 | Dell Inspiron 5160 Notebook
Dell Inspiron 5160 Black screen on power up
There is a small board that the power button is integrated into that connects to the motherboard. When this power board malfunctions it will cause this issue with the machine. It can, and quite often does, damage the motherboard when it malfinctions. You should take the machine in for a power board replacement and a diagnostic to make sure that the power board hasn't damaged the motherboard.
Jul 14, 2008 | Dell Inspiron 5160 Notebook
Laptop won't turn on
I am facing a similar problem with 5160 and my power button will not power up the laptop. I presses the shift key, it got powered up (offcourse only fan started but the screen is black)
Try pressing shift key to power up.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Dell Inspiron 5160 Notebook Logo
168 people viewed this question
Alun Cox
