Question about Brother MFC-7820N Laser Printer
Toner marks on papers
New laser toner cartiradge and still getting streaks on papers
Have a look at the laser roller it may just need u to get a small paint brush and brush if there is a line on on the bottom of the roller
Posted on Nov 24, 2008
    Guru:
  • 558 Answers
It might be the Printer roller film which is getting old and burnt out. Check the film and if needed replace it.
Regards
Ellin
Posted on Sep 26, 2008
Black streaks on paper
its either your heater is full of toner or your copy glass is full of dust either way you just need to clean it from the inside
Apr 27, 2012 | Konica Minolta PagePro 1350W Laser Printer
Every copy has large black streaks across the page
Are the streaks horisontal or vertical on the page?
What printer? Laser or InkJet?
If laser, and streaks are vertical, you might have some dirt stuck in teh tomer cartradge or somewhere along the paper path
If laser, and streraks are horisontal, your toner cartridge might be dirty or leaking toner
Aug 23, 2011 | Office Equipment & Supplies
I'm getting black streaks down the left side of the paper. There is plenty of toner left in the cartridge. We've vacuumed out the printer, cleaned the drum - nothing helps.
black streaks the toner cartridge is leaking from the left side which is easy to check pull the tone and look at the gears on the left side to see if toner is present. if these gears have toner on them the cartridge is leaking replace it. check the fuser for wear marks on the hot roller which is the top roller when these get worn through the outer coating they will create black streaks
Dec 05, 2009 | Lexmark E238 Laser Printer
Red light is glowing and its given defeactive cartiradge .if I insert a new cartiradge it is given same message
You got a bad sensor in the unit that needs to be replaced and that sensor is where the toner goes in to make contact with the printer.
Goood luck and please do leave postive feedback for your free answer today. Need more help open a chat and chat with us at very low cost!!
Nov 18, 2009 | Lexmark E120n Laser Printer
Clp-500. toner streaking the paper.
I have the same streaks problem. Any solutions?
Nov 14, 2009 | Samsung CLP-500 Laser Printer
I'm getting a streak of ink down the paper
change a toner.
when you have the toner out. clean the heater element (glass). make sure the printer is off and the heater element is cool before you do this.
May 14, 2009 | Dell 3100cn Laser Printer
Black streaks on paper ML 2150 laser printer
Black streaks usually mean that toner is baked on. Pull out the old cartridge, if it has a lot of toner, vacuumn it out (unplugged of course), and then replace it with a new cartridge.
Apr 28, 2009 | Samsung ML-2150 Laser Printer
Black streaks on paper on samsung ml 2150 laser printer
Could you describe these marks for us please.
Are they small specks or blotches? Bad Toner Cartridge
Are they lines:
Horizontal - Transfer Roller or Charge Roller
Vertical - Bad Toner OR Bad Fuser.
Note: A bad toner cartridge can render all of the parts listed here useless. Check for build up or lines on the cartridge reflective drum. Avoid light, as with film.
If they are a mix of both, the device needs to be cleaned with a can of compressed air. You must remove the cartridge, paper tray(s, and fuser to create clear path.
Apr 28, 2009 | Samsung ML-2510 Laser Printer
An inch wide streak appears on the right side of a laser printer printed page.
If you can rub the toner off the paper it is the fuser.
fuser, the part of a laser printer that melts the toner onto the
medium. It consists of a hot roller and a back-up roller. After toner
is transferred to the paper, the fuser applies heat and pressure to
ensure that the toner stays on the paper permanently. This is why
paper is warm when it comes out of a laser printer.
For toner problem:
Do a half test as follows -
Print one sheet from the fold down tray, just as the trailing edge of the paper
goes into the printer open the toner door to stop the printer. Remove the toner
cartridge, are the marks on the paper that you can see in the printer? If they
are there the cartridge needs replacing.
Jun 03, 2008 | GCC Technologies Elite 12/600 Laser...
Grey background and dark streaks
Change out the toner first and then the drum. Also be sure there is not excess toner underneath where the toner is installed. If so clean that out with a dry cloth.
Apr 18, 2008 | Brother HL-2070N Laser Printer
Brother MFC-7820N Laser Printer Logo
236 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
