Question about Canon PIXMA MP210 Photo All-In-One Printer
Problem with scanner
I have problems with the scanner of my Pixma MP210, all works right with the other functions, but when i try to scan something appears a message telling me that an error occur with the driver of the scanner and ask me verify the conections betwen the printer and the computer, i do that and everything it`s OK.
I already reinstall the driver but the problem still there.
My OS is Windows XP
  • nandinish Mar 08, 2009
    I've got the same problem, but with a Mac -- I'm running OS X.
  • Anonymous Mar 15, 2009
    Error message:
    Cannot communicate with scanner
    Cable may be disconnected or scanner may be turned off
    Check status
    Scanner drive will be closed
    Problem Solver:
  • 7 Answers
Try installing hp's precision scan utility
Posted on Oct 02, 2008
I have a canon pixma MP495, can't get it to scan. I've installed the driver from the canon website, but still no luck scanning. it worked before not too long ago, but now it won't
if you can print but cant scan, your usb is ok. so its either your pc or your scanner machine has the problem. to isolate the scanner machine if it has the problem, try to scan with the lid or scanner cover is open. observe if the "stick" (with the lights and belt attach to it) can move around the glass (left or right or up and down, depends on how you look at it). if its stuck in one side, then you have a mechanical problem. otherwise, check for your pc for some problem. you can check it by installing the printer driver to a 2nd computer and see if that pc can scan or not. if that 2nd pc cant scan too, definitely your printer is defective
Sep 21, 2013 | Canon PIXMA MP210 Photo All-In-One Printer
My canon mp210 wont let me scan. i have done it before but it is not working now. is it broken? is it fixable? is it a diy? help please.
What error number is show on printer display? May be a software problem, try to reinstall the printer software. If a ink cartdrige is missing or malfunction all the printer function (including scanner) is unusable, you need to replace the broken cartdrige!
May 14, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Hi, I need your help with this problem: the Canon MP210 ran out of color ink. I have removed both the cartridge. Anyway, the problem is not in the E5 error. The problem is, that the scanner does not work,...
The scanner and the printer are connected together.Both need initialized for printing or scanning.You can't scan if you haven't cartridges in printer and you can't print if the scanner not initialized.Put cartridges back and press and hold the resume button for 5 seconds.If you still have E5 error that mean you have a defective cartridge and you need to replaced.
Oct 19, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
MP210: Can I use the scanner without the printer?
yeah same problem here wit a mp160.. will try it with new cartridges, if that fails, i'll never buy canon again
Jan 18, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Printer is not working
The Pixma MP210 does not support a wireless connection. It has a USB port. Some wireless routers do have USB ports and can thus share the printer. Similarly, there are print server options that can be connected to the USB port. However, these will not work with the scanner functions of the all-in-one. Also you would need to confirm that the print server you choose is compatible with the Pixma MP210.
The fastest way to print right now is to connect the USB cord to the laptop. Wait for the drivers to be installed and then send the file to the printer. Moving the cable will let both computers use the scanner features of the all-in-one. A manual USB A/B switch might allow you to share the printer with fewer chances for a damaged USB cable. However, these usually don't support the scanner. Scanning requires bi-directional communication between the printer and the computer. A bad USB cable can turn an all-in-one into a single function printer with a direct USB connection.
Once the MP210 driver is on both systems and they are connected to the same network, you may be able to set up the desktop as a print server for the laptop. This will depend on the OS on both systems. Something like the Windows Homegroup easily allows printer sharing when enabled for systems with Windows 7 and newer on a private network. Both systems need to join the same homegroup. One system starts the homegroup. Then you have to type in the password on the second computer. This works even with one system connected to the wireless network and the other connected to a wired port on the router.
On Vista and XP, you could enable printer sharing as well in the Network and Sharing center. See https://www.wikihow.com/Share-a-Printer for the steps With Windows OS versions, the scanner functions will only be available on the computer with the direct USB connection.
I hope this helps. Please add a comment with the OS versions on both the desktop and the laptop if you need more specific advice.
Dec 22, 2017 | Canon PIXMA MP210 InkJet Printer
Using my scanner
The installation software you installed with your MP210 should have a program call "MP Navigator EX". It is quite easy to use and very intuitive. You can control all scanner functions through it.
Oct 16, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Scanning
well..that means you wish to enlarge it , right? you'll need to use the scanner, save the image, then enlarge it with Photoshop or something along those lines..
http://tinyurl.com/6qcpgy
Aug 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Scanner will not scan to certain programs
Try reinstallying the printer driver, but first remove the printer program.  Then, reinstall everything and try it again.  Unplug and plug the printer in.
Jan 28, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
394 people viewed this question
old marine
old marine
