Question about Lands Phones
OT8500 Onetel handset- It keeps saying that there are 4 new calls- however there are no messages and nothing else showing- how can i remove this?
It means you have 4 missed calls, like on a mobile. To get rid of them go to Call List (press the CLI/R button) and delete the number from the Call List or delete the Call List completely (press the menu button for thess options).
Posted on Mar 14, 2009
Retrieve messages remotely on onetel ot8500
check your manual it might not have that capability
Mar 19, 2015 | Lands Phones
My vtech dect 6.0 keeps saying unable to call try again
I had this happen suddenly on 2 out of 3 handsets with a DS6151 base and DS6101 handsets. Well, what happened is there was no dial tone on either of the 2 handsets on either of the 2 lines and a message appeared on the display "Unable to Call Try Again" after some delay, if Line1 or Line2 button was pressed.
Oddly, the 2 that did not work were the ones normally on "extension" chargers and the 1 that did work was the one on the base unit. That caused me to suspect the base unit .. which it still may have been but the solution was NOT. And, also odd, the handsets seemed to still be synched with the base unit in many respects.
Cycling the power on the base unit did nothing.
These are fairly new units and battery life is generally much longer in my experience.
The Solution:
- Remove the battery from the handset that doesn't work properly.
- Re-install the same battery.
Whatever was wrong, this reset it and the handsets started working again.
Easy fix.
Mar 18, 2012 | Vtech DECT 6.0 Digital Cordless Phone
My handsets both show the icon that says I have a voice message waiting, yet I'm unable to get the message...and the base says there are no messages. Also, when I tried calling my own phone, the...
Try resetting the all the handsets by removing all the batteries for one minute. Then, put them back in and try it. This may reset the units. Also, check the batteries to make sure they are still good. You don't mention what kind of handset you have, but I think many of the different brands have built in voicemail. Are you sure you are not using the service voicemail instead of the handset voicemail?
Jun 19, 2017 | Uniden Cordless Phone
Clear missed calls message
You can try this, it worked for us.
Press the key that says CID (Caller ID) to view every missed called telephone number. They disappeared, but we had to do each handset. Hope that works for you.
Dec 04, 2008 | Panasonic KX-TG1033S Cordless Phone
Onetel cordless phone OT350 does not ring
Hi I had a similar problem with my 350, I phoned their support line who said it was not repairable so if you found a solution please let me know?
Aug 29, 2008 | Lands Phones
NEED TO RECORD NEW ANSWERPHONE MESSAGE ON ONETEL OT150
To record a new OGM, on the Onetel OT150
Press "menu" on the base unit, then "up" once to record OGM 1 or twice to record OGM 2.
Press "OK" The existing OGM will begin to play. Whilst this is playing press and hold "MEMO"
Record your message, speaking close to the base unit. Press "stop" (square) when finished.
If you decided you don't like your message then, repeat the process above but when it tells you to record your own message press "stop" (Square) and the default will be reset.
Jun 11, 2008 | Cable_and_wireless CWD4901 Cordless...
Onetel ot150 plus add handset
I don't have a second handset, but I'll quote from the instruction manual - Try this,
Regsiter up to 5 GAP cpmatible handsets to your OT150 base. New handsets must be fully charged.
You can use the same handset at home as well as the office by registering it to 2 bases.
1. At the base: press and hold "FIND HANDSET". You hear 2 beeps and the in use light flashes. Youa re now in registration mode.
2. At the handset: Press "OK". scroll down (with down arrow) to "REGISTRATION" and press "OK".
3. "REGISTER" is diplayed. Press "OK". Any free base numbers will flash. Enter the number of the base you want using the keypad.
4. Enter the PIN Number (default = 0000) and press "OK"
5. The handset searches for the base and when registration is complete goes into standby mode.
To test the handset is registered. Press "FIND HANDSET" on the base and the handset should begin to ring. Press "FIND HANDSET" again to stop the ringing.
As I say this is taken word for word (with a few spelling mistakes no doubt) from the instructions. I Hope that it solves your problem.
If you still have problems or you don't have the PIN number, the helpline number is 0845 226 7794, or e-mail help@telephoneproducts.co.uk
Mar 09, 2008 | Cable_and_wireless CWD4901 Cordless...
Onetel magma 400 phone / answering machine
Hey! To play messages press the clear/mute button then the number 2 button and then press the green phone symbol then your messages should play. To turn off do exactley the same but instead of pressing number 2 press number 8! Hope that helps!
Mar 02, 2008 | Lands Phones
Onetel OT100 Trio
If you havent sorted it yet - I have a handbook here for a onetel sirius 2000 - it says:
1 press OK on the phone
2 scroll < or > to flashing handset symbol
3 press OK again
4 Press & hold the button on the base station until a beep is heard about 2 secs
5 enter the base PIN at the handset - default 0000
6 press OK again - if successful you will hear a tone and the handset name and number will be displayed. If unsuccessful then Not Reg will be displayed.
Hope this works Regards Tony
Feb 25, 2008 | Lands Phones
Onetel OT8500
select menu then am operation, and choose to delete all, then choose record new. Now you have a new answering message/
Feb 14, 2008 | Lands Phones
Lands Phones Logo
184 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
