Question about Symphonic ST427FF TV
27}" Symphonic Purchased this 3-4-yrs ago.did not need, but great price. Now, older one blew and had to this one..unable to get local channels..only channels thru dish...
  • 3 more comments
  • tme491 Sep 26, 2008
    We get the local channels thru use of an antenna on a pole. It is not the best, but directv tested the area and said we could not get a waiver. Strange thing is however, that about a month ago, we started getting the CBS feed from NY...and we pick up he local news by as stated, use of an antenna. The ABC local channel, just went digital two days ago..so of course we do not get it, even tho all we have to do is tie it into the directv receiver. That is, once we can receive any signal on the tve from either. We put this tv into service about two weeks ago..we are unable to get any signal from local CBS or ABC or PBS. It is just snow..Even plugging ithe antenna directly into the set does nothing. Trust this explains it a bit better.
    Thanx
    Only one foreseeable problem in that...over the years, the manual has disappeared,. We control the tv via the diredtv remote..any suggestions as to how to access the tv menu..the directv one is not able to show air or cable that I can see
    thanx
    Only one foreseeable problem in that...over the years, the manual/remote has disappeared,. We control the tv via the diredtv remote..any suggestions as to how to access the tv menu..the directv one is not able to show air or cable that I can see
    thanx
  • tme491 Sep 27, 2008
    Found a universal remote...menu does not have the settings on it that were mentioned..mot sure why it would not, but alas..it does't.
  • Daniel Jenkins
    Daniel Jenkins May 11, 2010
    unable to get local channels? What is your question and how do you get your "local channels"
    Sergeant:
  • 359 Answers
Oh ok, make sure in the menu of the tv is set to Air and not Cable.. that should fix your issue.
Posted on Sep 26, 2008
  • 1 more comment
  • Daniel Jenkins
    Daniel Jenkins Sep 26, 2008
    You can contact Symphonic Customer Service and see if you can purchase the remote directly from them @ 800-256-2487.
    Otherwise try EBAY, but other than these 2 options it may seem you are SOL.
  • Daniel Jenkins
    Next time if you have a TV laying around it would be good to duct tape the remote to it...
  • Daniel Jenkins
    Kindly rate this solution please.
Engine shutoff on hot days after 45 minutes.
it sounds like the electronic ignition system(under the flywheel) is going bad,that would cause the mower to shut down when it's hot. if you take it back to the repair shop ask them to replace it and it'll be good as new.. Good Luck
don't for get to give me a thumbs up
Apr 06, 2010 | Garden
RCA 27R411T 30" TV - purchased 2004
yes i think the tv is on its way out
could be in the jasks the main board
your picture tube could be on the way out also its most cheaper on you to purchase a new set
Jul 29, 2008 | RCA 27R411T 27" TV
27'' symphonic TV. Sony remote wont work since switched 2 digital
Use the channel buttons on the unit to go down past channel 2, usually you can get to the inputs this way.
Aug 09, 2009 | Sony Televison & Video
Is this tv able to use the convertor box to get digital signals?
Here is the manual: http://www.symphonic.us/pdf/om/SC313D.pdf Follow the instructions for connecting a cable box to connect your converter box. Front panel buttons can be used to make menu selections if you do not have a remote.
Jul 12, 2009 | Symphonic SC313D 13 in. TV/VCR Combo
NO VIDEO INPUT
You will need to get a RF modulator. It has connections for RCA jacks and S-video inputs and converts it to a RF signal (usually channel 3 or 4). Just plug game/DVD player into it and the antenna out to TV. You should be able to get one at any electronics or department store.
Jan 05, 2009 | Philips Magnavox 27MS343S 27" TV
I have an older symphonic 19in portable tv. i have just bought a converter to make it compatable to digital. my prob is i no longer have the antenna. can i buy one in stores? it has been used mostly for...
Digital tv converters and digital tv for that matter require a good signal to operate, a good quality rabbit ears available in a number of stores will get you some local stations. To get maximum reception you will require an outside antenna.
Dec 02, 2008 | Televison & Video
No Picture or Sound
I dont think it's worth getting a repair man to come fix a Symphonic TV... honestly, they are problem prone... and It would cost much less to just buy a whole new one. I have a symphonic tv with no remote, and now, I cant switch into game mode! It's like they designed their tv's to be crappy!
Jun 07, 2008 | Symphonic ST419E TV
My Tv just started doing the same problem
Sounds like the On/Off sitch is bad to me. Be Calm my friend these things happen in life. No point in becoming angry over it. The fact is it was probably the least expensive set on the shelf when you bought it. It came with a warrenty as do the other brands And, this sort of problem can happen to ANY brand of television. That's why you get a warrenty. Also, you could have bought an extended warrenty which would have cost you more than the repair job you need for your tv. Call 18002427158 press 1 be preparred to hold about 4 or 5 minutes and ask them for a service tech in your area. I would think that this should be repairable for about $35-$55 OR look in your yellow pages and take it to any TV reapair shop in your neighborhood. Don't worry, BE HAPPY!!!! Don't forget now, very soon, if you don't have cable or satelite you will need a new tv anyway. The nation is going Digital! WOO HOOO!!!! Have a great day! Symphonic tv's are ok. I have had a 27" here for 13 years now still plays great! Although, my 6 year old Symphonic just pooped the bed. But, that's ok cause I can fix it!
Mar 22, 2008 | Symphonic WF20D4 TV
Symphonic tv's noise
It's shop time if you cannot adjust the set to your liking. Also, the noise that it's making now is a new ocurrence? Definitely needing a service call then...accordianman
Dec 17, 2007 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
Symphonic ST427FF TV Logo
78 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
