Question about Health & Beauty
Conair ww39 glass bathroom scale won't work- batteries in wrong maybe? Help please!
Fairly new scale Conair ww39. Has worked. How do I know if new coin-shaped batteries are correctly loaded? No read out showing at all, despite tapping in required spot.
  • 1 more comment
  • pmstock Oct 25, 2008
    I just bought the WW39 glass scale and I get no display at all. I have put fresh batteries in, but, it still does not work. Am I overlooking something? I did not get a booklet of any kind with my scales since they were used, I would love any help I can get to get these scales working.
  • Anonymous Mar 23, 2014
    When I turn on the scales they read 0.0 but when anyone steps on them they read ol. We have put in new batteries
  • Anonymous Mar 25, 2014
    How do I get the scale to show the exact weight, I put a 1 oz. silver american eagle coin on it, and it comes up showing 1.4 oz in weight ?
Googled around until I found specifications for an unrelated brand of a similar bathroom scale. It mentioned making sure batteries were flat side uppermost in their compartment, which did the trick.
Posted on Sep 26, 2008
The conair ww39 requires 2 batteries. When replacing what direction do they go?
Hello (revised)
Revision:
If the batteries stack on top of each other, they have to all go in the same direction. Be sure the flat backs are in the direction toward the spring. The protrusion on the other end of the battery will face away from the spring.
End revision.
It is very common to use the following method.
Look into the compartment and you will see a spring where each battery goes. Place the battery's flat bottom against the spring.
Put the compartment cover back on and test your scale. If the batteries are good and the scale works it should be ready for you to use once again.
Best wishes,
Joe
Aug 25, 2016 | Conair Ww39 Digital Glass Chrome Scale
My scale shows that i weigh about 30 pounds lighter than i do.
If this is showing your weight, how do you know how much you actually weigh?
Also, you should be testing on a flat, SOLID surface (bathroom tile works well).
Feb 28, 2011 | Conair Weight Watchers WW-87 Body Fat...
I have a Thinner glass/brass round bathroom scale and I cannot find the battery location. I purchased this about 10 years ago from Frontgate but they couldn't help me. Can you?
I have a 10 year old Thinner bathroom scales also. Apparently the manufacturer designed it to make battery replacement hard so you'd buy a new scales. To replace the battery, if your unit is similar to mine, turn it over, remove all the screws and separate the top and bottom. You'll see the glass window that shows the weight. It is held in place by four tabs that are slightly twisted. Straighten them, lift the glass assembly clear without straining the wires, and turn it over to reveal the round black battery case. It is secured by three small screws and clear epoxy. Remove the epoxy with a knife blade, remove the screws, and separate the two halves of the case on one side being careful not to separate the other side where there is a metal connection piece. Using the knife tip, remove the CR2032 battery and replace it with a new one (available at Radio Shack or similar stores). Reassemble in reverse order; no need to replace epoxy. My scales worked fine after that.
Jan 09, 2011 | Conair WW81 Weight Watchers Body...
Lost instructions for bmi and special feature settings
Conair Support – Online Tech Help to Troubleshoot Problems
by: Guest1223497 in Conair Weight Watchers WW-87 Body Fat Glass Scale | 9 months , 28 day(s) ago | 10 ... Manual or Instructions for Conair CID502 Phone ...
livesupport.maybenow.com/Conair
Oct 04, 2009 | Conair Weight Watchers WW-87 Body Fat...
The numbers on the digital readout are partly
If the display is showing "partial digits" on the display, it means a scale is excessively shaken (sometimes during shipping) it's possible for the LCD to become partially separated from the PCB (Printed Circuit Board). On many models you can gently press on the LCD and it will reconnect. However on many scales it's difficult to reach the LCD (without removing the cover) and thus the scale will often have to be returned to the manufacturer for repair. Contact them at 1-800-326-6247 for the Conair appliance customer service center.
Sep 09, 2009 | Salter 9007 Glass Lithium Digital Scale
Health & Beauty Logo
1,221 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
