Question about Bernina 1008
My bernina!! i discovered one of my hidden talents is sewing and we have a bernina and i cant figure out how to thread it or work the bobbin. if some one could help me that would be great. email me at theshizzx2@aol.com . thanks!
  • 30 Answers
I hope I can explain this in an understandable way!
1. Pull the end of the thread from the spool to the left and "click" it into the little metal guide (on the top of the machine) that is at the back of the long **** in the top. It's easiest to do this by holding the thread tight between your two hands, placing it behind the guide, and pulling forward until it clicks in.
2. for the remaining steps, let the thrread slide between the fingers of your right hand, keeping a little tension on it, as you thread the machine with your left hand.
3. Bring the thread end forward, laying the thread into the ****, and continue downward, along the right side of the vertical silver bar/hook thingy.
4. Bring the thread under that bar from right to left, and go back up towards the top of the wide **** in the front of the machine. As you pull up, the thread will click into the lower bar/hook thingy.
5. Lay the thread along the right side of the wide ****, go over the top of the needle bar (the part that goes up and down in the ****) and bring it down the left side. It will click into the needle bar.
6. Bring the thread back down towards the presser foot. Right in front of the screw that holds the foot on, there is a hook that opens on the left side. Slide the thread behind this hook, and then thread the needle from front to back.
7. Hold onto the end of the thread and run the needle down and back up once. Pull on the thread, and it will pull up a loop of the bobbin thread. Stick the tip of your scissors or seam ripper into the loop and pull the end of the bobbin thread out.
8. Slide your top thread through the slot in the presser foot so it comes out from underneath the foot, and you're ready to go! (Be sure and hold onto both threads for the first few stitches when you start a seam, to keep if from jamming up inside.) For the bobbin, pull the case out of the machine by grabbing the hinged latch on the bobbin case. 2. Turn the case over, drop the bobbin in, pull the thread through the ****, and continue pulling to the left until it pops under the hook thingy that has the screw at the other end. 3. It's important to know whether your model calls for the thread to be coming off the top or bottom of the bobbin when you drop it into the case. On my machine (1630) it comes off the bottom, so that when you pull on the thread, the bobbin spins clockwise. On my mom's old machine from the 1960's, it was supposed to spin counterclockwise. If you don't have the instruction book to tell you this, you can try it both ways and see which one gives you the best tension. Or you could call your local Bernina dealer, give them the model number, and ask them! 4. Slide the bobbin case back in until it clicks in. If it won't click, rotate it slightly left and right until you find the position where it will click in. Let me know if you need any clarification.
Posted on Jun 21, 2009
I have Bernia 180. The bottom thread is puckering. Top thread is perfect. I cannot find help in manual. Please help
Check that the bobbin is inserted turning the proper direction in the bobbin case and that the thread is threaded correctly through the tension control on the bobbin case.
Make sure the upper thread is threaded correctly. The factory standard upper tension setting is midway between high & lower number although this may need to be tweaked for your particular machine.
If the machine is still pulling the bobbin thread too tight, you can try tightening the upper thread tension. If it still isn't resolved, you may need to loosen the bobbin tension.
You might also want to check the presser foot pressure on your machine. That generally needs adjustment when changing from thicker to thinner fabric and vice versa.
Manual: BERNINA artista 180 Support BERNINA
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
How can properly adjust my tension
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Oct 02, 2016 | Bernina Sewing Machines
Deco Bernina bobbin jammed, now bobbin won't work
remove bobbin and reinsert. Re thread needle . Make sure the right size of needle for the material. And check that there is not a wad of fluff under the feed dogs.
Best wishes
Aug 22, 2014 | Bernina Sewing Machines
The lower tension on my bernina 1005 stitches ok for a couple of inches then goes loose for a bit and then back to normal - normal checks done including a new needle?
Is your bobbin case a genuine Bernina bobbin case? If not, replacing the bobbin case will solve the problem. It is a common problem to find a Oriental copy of a bobbin case in a Bernina machine for a number of reasons, such as where the casing was swapped by accident or intentionally. Most often, repair technicians don't know the difference and would rather pay $7.00 for a Chinese casing rather than $56.00 for an OEM casing. Whatever the case may be, if the machine tension nests on the bottom side, stitches erratically, or breaks thread, changing the casing can solve the problem.
The bobbin cases may have similarities but there are subtle physical differences that prevents thread escapement over the bobbin case.
Much more information would be needed in order to discover your problem, however.
Other problems can occur by incorrect starting of the machine such as beginning sewing by holding the top thread rather than turning the machine hand-wheel in the direction so that the take-up lever is at the highest position. Machines like the 1005 do not have an automatic "Needle Stop' function.
There can also be similar problems if an industrial cone spool is used where thread is being pulled off of the spool's side rather than from the top center of the spool.
If the bobbin case is an OEM casing it is possible that the "loop lift (needle and sewing hook) timing" has been knocked out such as having had a collision of the needle with a button, zipper, straight pin, etc. Bernina 1005's and all of the newer machines are not constructed in such a way that would prevent this from occurring. As mentioned, more information would be needed here.
SewTechnical Home
Jul 04, 2014 | Bernina Sewing Machines
Thread bernina embroidery bobbin
The thread sensor eye is probably dirty.
Dec 26, 2017 | Bernina Sewing Machines
Hi I ahve a Bernina H70 model and I've been working for hours trying to thread the bobbin so the top thread picks up the bobbin thread...help!
make sure the presser foot is at it's hightest position, then thread the top
of the machine
change the needle
make sure the bobbin is not over full
that it is turned the right way in the bobbin case
if none of these suggestions work,,it is also possible that the machne is
out of time & needs to be checked at a repair shop
here's a link for a manual
http://www.bernina.com/getdoc/4a3fb7af-a8d3-488a-a76a-0147415042a7/Bernette_50_60_70_75_manual
Sep 07, 2012 | Sewing Machines
My Bernina 1090 keeps breeaking the bottom thread. It sews about 10 inches and breaks. I take out the bobbin and rethread and it sews a while but still breaks. I have had it in for service 3 times and...
Assuming your bobbin tension is not too high, make sure the bobbin case is clean on the inside - use a cotton bud to clean it out. Are you using good quality Bernina bobbins - if not you're on a hiding to nothing ! It is possible that the bobbin case is deformed, but most likely your service man has set up the tensions too high ... look for someone else !
Jan 21, 2012 | Bernina Sewing Machines
I lost the book and can't figure out how to thread the bobbin... it was a gift from my mom and was completely ready to go when she gave it to me...
Hi, after your bobbin is wound insert it into the bobbincase. When you pull the thread the bobbin should turn clockwise. Then slip the thread through the notch and up under the spring. There is a small screw on this spring that adjusts the thread tension on the bobbincase in case you have to adjust it later.
Hope this helped.
Rick
Bernina tech
Dec 06, 2009 | Bernina Activa 130
I have a Bernina 530 Record and i'm trying to but
You would be best to download an instruction manual for your machine as it explains clearly, with diagrams how to thread and insert the bobbin. You probably wont find the 530 manual however download a copy for Bernina 530-2 or 532-2 as they are almost identical to the 530.
Sep 25, 2009 | Bernina Sewing Machines
Purchased a new Bernina 830 and need an easy way to thread bobbin
load your bobbin in, pull thread all the way to the cutter but don't cut it, see that curved bar in front, glide the thread along that curved bar until you feel a slight click, it should be there, when the 830's first came out they didn't include a mirror, if you never received one, ask your dealer.
Mar 02, 2009 | Bernina Artista 180
Bernina 740 favorit timing
boscados 740 840 940 742
Jan 12, 2009 | Bernina Activa 130
Sewing Machines Logo
207 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
