Question about RCA S1000 MP3 Player
Does not power up
I have replaced the battery with a new battery. When I press the "p" button and cannot get my player to power up.
I found the right button to power up the unit. "P" is not the power button. Sorry.
Posted on Sep 27, 2008
C150 as not working what's solution?
Check the orange "Hold" switch on the left side of the Sansa C150, if you cannot turn on the MP3 player or if none of the buttons is working. When the "Hold" switch is up, the buttons are disabled. Slide the "Hold" switch down to activate the buttons again.
Press and hold the "Power" button until the LCD screen lights up when turning on the MP3 player. Pressing the button quickly does not turn on the device. The "Power" button is located on the front of the device, under all the other control buttons.
Replace the AAA battery, if you cannot power on your MP3 player. To replace the battery, remove the battery cover from the back of the device by pressing in on its tab and pulling it off. Remove the old battery, insert the new battery and replace the cover. One AAA battery provides approximately 15 hours of power for your Sansa C150.
Change the backlight settings to conserve battery life. This is useful if you find the battery loses power quickly during normal use of your Sansa C150. To change the backlight settings, choose "Settings" to bring up the "Settings" menu. Select "Display," "Backlight" and then a shorter backlight time. The backlight will shut off after a period of inactivity that matches your backlight setting.
5
Review your music purchases to understand what rights you've purchased to the content, if you are unable to play a track back on your Sansa C150. When you purchase music, it comes with certain rules for how you can store and play it. You may not have paid for the right to transfer the song to a portable media player.
6
Reset the Sansa C150 if it acts erratically or if you have other problems. To reset the device, open the "Settings" menu and choose "Reset All." Choose "Save" to finish restoring the MP3 player to its factory default settings. If you decide not to reset the device during this process, select "Cancel" instead of "Save."
~KenjiFox
Jan 07, 2011 | SanDisk Sansa c150 MP3 Player
WHEN I TRY TURNIN IT ON IT JUST STAYS ON THE SANDISK 256MB WELCOME SCREEN HOW CAN I UN FREEZE IT?
Reset the device. 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
Power cycle the device.
The power cycle discharges excess/residual power from the player; with the use of a new battery, it should be able to power on the MP3 player properly.
STEP 1 - Remove the battery STEP 2 - Power cycle the player 1. Connect the player to the PC. 2. Leave the device connected for about 2 minutes.
STEP 3 - Turn on the device 1. Unplug the player from the PC. 2. Insert a fresh AAA battery into the player. 3. Turn on the player.
Dec 29, 2010 | SanDisk SDMX1 MP3 Player
How do i turn it on? I lost the manual. I tried the "m" button and the "play" button. But it wont work. And i charged it/
The MP300 uses one not rechargeable AAA battery, that will not be charged when connecting to the USB port of a computer.
When the player has abnormal behaviour, RESET the player as next:
1. Disconnect your player if it is connected to a
computer.
2. Remove the battery from the player. Wait 10
seconds, and then replace the battery.
3. Power ON the player, push the play/pauze/stop button >|| .
note
Check the correct polarity + and - of the battery matching the player.
Try a new battery when the RESET won't work.
To switch ON the player, press the play/pauze/stop button >|| .
For switching OFF, press the >|| button for at least 3 seconds.
There's a manual for the MP300 on this site:
http://www.cobyusa.com/files/manuals/MP300_MN.pdf : pdf files can be read with Adobe Reader.
Jul 18, 2010 | Coby MP300 MP3 Player
My mp3 player doesn't turn on even if I charge it. Do you think I need a new battery?
Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, to switch the player to MSC mode
1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Skip this step if you think it is charged. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary. To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 30, 2010 | SanDisk Sansa m230 MP3 Player
I have a Sansa c200 that will not turn on, although the light ring is on. When I plug it into the usb port on my computer it does not recognize it either. Thanks!
First try and reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
Jan 30, 2010 | SanDisk Sansa c200 MP3 Player
My mp3 dosent want to turn on and its charged
Jan 30, 2010 | SanDisk Sansa c250 (2 GB) MP3 Player...
I use my Sansa only during my workout. I fully charge the battery before and within 20 minutes it stops playing. The battery shows it is 3/4 full but I can't get it to play. It just shuts off!
Jan 30, 2010 | SanDisk Sansa e250 MP3 Player
My sandisk sansa clip 1gb wont turn on
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
Jan 29, 2010 | SanDisk Sansa Clip MP3 Player
Sansa MP3 not working
Try these steps:
SOLUTION 1 - Reset the device.
SOLUTION 2 - Power cycle the device.
1. Connect the device to the PC.
1. Disconnect the player from the PC.
Jan 18, 2009 | SanDisk Sansa m240 MP3 Player
BATTERY LOW, POWERING DOWN! SANSA M240
Hey,
Try these steps, if they aren't of any help, you may have to have the vendor replace your mp3 player.
Jan 16, 2009 | SanDisk Sansa m240 MP3 Player
RCA S1000 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
