Question about HP Officejet 4315v All-In-One InkJet Printer
Bought long ago and I cannot seem to put these replacement cartridges into ink port; wrong size?
Ink cartridges
    Guru:
  • 558 Answers
Printer top cover from the middle to be pull upward and it will open the cartdridge rack to put in.
Regards
Ellin
Posted on Sep 26, 2008
Pixma i1200 it says cartridge is in wrong try several times also bottom light flashing
u may need to buy canon ink cartridges as some printers will not take generic ink or check to make sure u bought the right size for ur printer
Jul 26, 2010 | Canon Office Equipment & Supplies
Loading ink cartridges
what are the numbers mentioned over the cartridges.
Jul 03, 2008 | Canon PIXMA iP1600 Printer
The window says that the wrong ink cartridge is installed and when I remove it and replace it it says remove and replace cartridge. I have put 2 new cartridges in and they are the right ones. It will not...
sometimes when replacing ink cartridges some idiot that filled them to begin with doesnt reset the calibration they just shove the ink in and box em up!!
its not your printer its who you bought the ink from
Jan 14, 2010 | HP PSC 950 All-In-One InkJet Printer
"WRONG CARTRIDGE" continues to flash on the screen.
I have experienced the "Wrong Cartridge" error about 4 times in four years. I have never bought a replacement print head. I do occasional printing each week. Typically the problem occurs after a color cartridge goes empty and the ink dried to the print head. The solution for me has been to remove the cartridges, remove the print head, place the print head in hot water in the kitchen sink (softens water based ink that has hardened)and then use a Q-Tip or tissue paper to clean the print head until it is nice and shiny. Reinstall the print head, insert ink cartridges that are not empty, let the printer cycle through a self-test, use the set button to accept vertical and horizontal print patterns and you'll be good to go!
If that doesn't fix it, you'll need to replace the printhead ($49-69 depending on where you buy it.
Oct 11, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Changed color cartridge and getting error
I had the same problem with my X8300 printer. As the printer was less than a year old Lexmark sent me a new printer. I will keep this printer until it to goes wrong and then buy another brand. Lexmark - cheap and nasty, I am afraid.
Ivanhoe.
Nov 13, 2008 | Lexmark X5495 Printer
Cannot recognize ink cartridge
I have about 6 canon printers with a 3in 1 using PG40 and CL41. I have never encountered the problem you have. I have looked into some other sites and noticed a number if CLI-8 cartridges being replaced by Canon. I think there are only 2 probable problem areas, he cartridge or the software you are using. I suggest you call up Canon and complain about this problem. Seems like you got the printer 6 months or so ago. You should able to get to do something like replace the printer or cartridges. I'm assuming that you don't refill or have your cartridges refilled so the contact points should not be messy w/ ink. You can try cleaning the contact points on the cartridges and printer. But I'd call Canon and explain to them the situation and see if they can solve your problem. Solve I'm implying is to replace your cartridges or printer. Let me know if this helps.
Jul 22, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Print cartridge has failed
try to have your cartrige replaced... it must be under warranty
Jan 18, 2008 | HP DeskJet 5550 InkJet Printer
New ink cartridge won't work.
Guys I had this problem with black ink. It appears that the internal print head ports were clogged with ink. Try removing the print head and washing it in alcohol- when I did this i had clumps of congealed ink coming out of the tiny ports. The print head has two small screws underneath that I also removed and cleaned the ports inside by use of a syringe and alcohol. After I put the print head back together, dried it and ran an auto alignment - it all seems good now.
Jan 13, 2008 | Canon Pixma MP500 All-In-One InkJet...
Change ink cartridge
I just did it a few minutes ago and it's pretty simple. Just grab the thing right in the center, above the print tray (there's a little handle) and pull the top up. The ink carts will be right in there (towards you, on the right) just pull the one you need to replace out, directly towards you, and then pop the new one in. There are little notches on it so you can't put it in backwards/upside-down or anything, and there's no latch or anything physically holding the cartridges down
Oct 06, 2007 | Office Equipment & Supplies
HP Officejet 4315v All-In-One InkJet Printer Logo
29 people viewed this question
Seeker5211
Seeker5211
