Question about Sony Playstation 3 (PS3) Console
PS3 won't work after installing MGS4?
I got a used (but barely) PS3. Very good condition. It didn't come with the cables, so I bought my own AC chord, power chord, and controller.
I set it up and it was fine, while I was waiting for my controller, it turned on and the sound and screen was working (had the "please connect controller" screen on.)
Once I got my controller, I hooked it up, and installed MGS4. Had absolutely no problems during installation or during set-up of my PS3.
After I installed it, and pressed start, the screen turned off. It wouldn't load, I waited for a few minutes and pressed the Playstation button and turned off the system through that (so I guess the screen was working, just not the game.)
I turned it back on, and I didn't get the screen. Any screen at all. I checked all of my cables, the AC cables. Everything's plugged in. I noticed that when I held down the power button, it didn't turn off, even though it was green. Also, my controller didn't recognize it was plugged in (even when wireless, wouldn't be recognized.)
I'm scared my PS3 is broken. What do I do?
  • giai Sep 25, 2008
    I first turned it off by pressing the Playstation button on the controller, and selecting "turn off the system." Then, it just stopped working.
    I tried what you said and this is what happened:
    It did beep, and the screen did flicker (so I suspect the video is working correctly.)
    The screen still, however, won't power on. ):
Nope, I don't have the original. The guy who came here to look at it said it's broken, and the man who sold it to me said he's going to get me a new one.
Thanks for your help!
Posted on Sep 26, 2008
    Sergeant:
  • 359 Answers
How did you turn it off? Did you use the"hard switch" in the back of the ps3, or the soft power button in front?
My ps3 locks up on occasion, and have to turn it off with the hard switch in the back.
If that doesn't work try this:
Turn off the ps3 with the hard switch, then hold your finger on the soft power button in the front while turning the hard switch to the on position. Hold your finger on the front power button for about 10 secs, this should reset your vid settings.
Hopefully this is helpful to you.
Posted on Sep 25, 2008
  • Daniel Jenkins
    Daniel Jenkins Sep 26, 2008
    do you have the original yellow/red/white vid connector the ps3 came with?? If so swap out whatever you got going on there with the original cable. If you are already using the original cable I suspect perhaps your tv input has gone out. Try another input on your tv.
So i have had a ps3 for about 2 years now and the hdmi chord worked fine for 1 year and then all of a sudden i started lossing signal from the tv. If i wiggle the hdmi chord the picture will sometimes come...
Hi friend, see since your regular (component/composite) chord worked well so the problem is with your HDMI chord. It is losing connection with some internal wire try to use another HDMI cable if it still not works so problem may be with your HDMI port.
Composite/component cable works fine but the cost of graphics..... but still HDMI graphics are just too good...
Hope it will work for you.
Jul 09, 2009 | Video Game Consoles & Games
While playing MGS4, or watching DVDs in my PS3, the lower half of my LCD TV is a shade greyer than the upper half. I am running 1080p through an hdmi to my vizio 32" lcd tv that is full 1080p compatible.
Hi:
1) have you tried using another hdmi cable?
2) are you sure that both ends of the hdmi cable are firmly fitted, such that there is no strain on the cable?
3) have you set the resolution to 'only 1080p'? i.e. make sure 720p and 1080i are unticked, in the Display Settings section, under System Settings in the XMB
Hope this helps,
Please leave feedback if everything is working.
Jan 12, 2009 | Sony Playstation 3 (PS3) Console
Ps3 hdmi sound problems
its the auto select on your tv or receiver just turn them off then back on it worked for me
Oct 01, 2008 | Sony PlayStation® 3 (60 GB) Console
PS3 HDMI & AV outputs not working?!?!?!?
change the sound output to HDMI? does the sound work on just like a normal tv channel?
Sep 03, 2008 | Sony Playstation 3 (PS3) Console
PS3 problem
I really wish I had a concrete answer for you. It may just be a coincedence that it happens only when you play that game. I have had that problem before myself, but it would happen with different games at different times of the day. As you know most of the popular games like MGS4 and COD4 are made and supported by diffent companies. This also means that the servers are in different locations and have a varied amount of people on each server. MGS4 is a newer game and I also had problems with the online play with that game as many people have.
As for a soultion. Some games require a stronger signal strength then others due to the amount of MB being transfered. I would try to use a shorter Ethernet cable if using a wired connection, or moving closer to your WiFi router if using WiFi, and completely resetting the network configuration. I know thats a pian, but if it works, it will be worth it! I really hope this helps you!! Good luck.
Aug 05, 2008 | Sony Playstation 3 (PS3) Console
My tv wont pick up my ps3
the tv probbaly cant support and if not just dont use the hdmi cable
Jul 06, 2008 | Sony Playstation 3 (PS3) Console
MGS4 crashing PS3
ok there are a few ways ti fix this...turn off your console and switch back on so its in standby mode "red light on" then push the power button and hold it down till you hear a beep and it turns off then swith it back on and this will have reset it back to factory settings.....let me now if that dose not work
Jun 19, 2008 | Sony Playstation 3 (PS3) Console
MGS4 crashed my ps3
I would say to replace the blue ray drive. It's problaly a faulty drive.
Sony Playstation 3 (PS3) Console Logo
184 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
